    MMM-Sunrise-Sunset
    44 Posts 9 Posters 26.1k Views 10 Watching
      mrdenmark
      just added it,thanks for your work, a couple of issues i found-
      it doesn’t seem to account for southern hemisphere or timezones or something as i get sunrise at 5.36 pm sunset at 7.23 am and solar noon at 12.30 am,also,in my config inline or list makes no difference,-its always inline.
      heres my config-{
      module: “MMM-Sunrise-Sunset”,
      position: “top_left”,
      latitude: “-44.57”,
      longitude: “168.50”,
      Layout: “list”,
      vblokeV 1 Reply Last reply Reply Quote 0
      • vblokeV Offline
        vbloke Module Developer @mrdenmark
        @mrdenmark it appears that the API doesn’t like the Southern Hemisphere…
        http://api.sunrise-sunset.org/json?lat=-44.57&lng=168.50&date=today
        Is that config exactly as it appears in your config file? layout should be all lowercase.
          mrdenmark @vbloke
          @vbloke i changed the config file to lowercase,that fixed the layout
          as for the api?not sure what the options are,i’ll see if i can an alternative,
          thanks for your help
          • vblokeV Offline
            @mrdenmark the API returns all dates in UTC, so I may look at putting a time zone offset option in the config, or if you feel confident doing that yourself, feel free to try.
              mrdenmark
              would it be possible to add a line with the day length?i’m not sure how to go about adding a time offset,i’ll do some research
              • vblokeV Offline
                @mrdenmark if you update the module now, it should account for the timezone if you set it in your config. From your latitude/longitude, yours (I think) would be “Pacific/Auckland”.
                Try this:
                  module: "MMM-Sunrise-Sunset",
                	latitude: "-44.57",
                	longitude: "168.50",
                	timezone: "Pacific/Auckland",
                	layout: "list"
                  mrdenmark
                  worked,cheers!
                    sdetweil @vbloke
                    @vbloke you can get the timezone from the lat/lng
                    http://www.geonames.org/export/web-services.html#timezone
                    https://stackoverflow.com/questions/16086962/how-to-get-a-time-zone-from-a-location-using-latitude-and-longitude-coordinates
                    • vblokeV Offline
                      https://github.com/prydonian/MMM-Sunrise-Sunset
                      Made a fairly big update using a different API that needs a free key.
                      https://ipgeolocation.io/signup.html
                      It now gives you moonrise and moonset times and day length.
                      • H Offline
                        henry2man
                        I tried this module but activating this causes my MM to show nothing. I had no error messages on MM logs (in my case, a docker server-only instance) and nor on my Chrome console.
                        In other words it looks that the IPGeo free key expires in 1 day…
                        vblokeV P 2 Replies Last reply Reply Quote 0
                        • vblokeV Offline
                          vbloke Module Developer @henry2man
                          @henry2man the API is limited to 1000 calls per day. It doesn’t appear to expire after a day.
                          Can you post the config for the module?
                          it should look like this:
                                position: "bottom_bar",
                          		apiKey: "API_KEY",
                          		latitude: "123.123",
                          		longitude: "23.456",
                          		layout: "inline"
                          • H Offline
                            henry2man
                            I removed the config but seemed like yours. I followed the README from master. I’ll try again later, but also I’ve reviewed this API
                            https://api.sunrise-sunset.org/json?lat=36.7201600&lng=-4.4203400&formatted=0
                            It has enough information and seems to be free.
                            What do you think?
                            • vblokeV Offline
                              @henry2man that’s the one I was using before, but it required a lot of work to get the time in your local time zone as all times were returned as UTC.
                              The new API uses your location to format the time automatically.
                              H Mykle1M 2 Replies Last reply Reply Quote 0
                              • H Offline
                                henry2man @vbloke
                                @vbloke In this link there is a simple way to get a ISO 8601 into your local timezone --> https://stackoverflow.com/a/31453408
                                var utcDate = '2011-06-29T16:52:48.000Z';  // ISO-8601 formatted date returned from server
                                var localDate = new Date(utcDate);
                                api.sunrise-sunset.org can return ISO 8601 dates using
                                formatted=0
                                parameter…
                                If date parsing is the major issue & this solution works I think this approach is simpler. Even you can default the URL and simply configure lat/long & style (inline/list)
                                Just my 2 cents…
                                  Mykle1 Project Sponsor Module Developer @vbloke
                                  @vbloke
                                  This is right out of my MMM-SunRiseSet module.
                                  Feel free to use it if you like. :thumbsup:
                                  // sunrise set to local time using moment
                                     var sunrise = document.createElement("div");
                                     sunrise.classList.add("small", "bright", "sunrise");
                                     sunrise.innerHTML = "Sunrise is at " + moment(SunRiseSet.sunrise).local().format("h:mm a") + " &nbsp &nbsp "
                                  + "Sunset is at " + moment(SunRiseSet.sunset).local().format("h:mm a");
                                     wrapper.appendChild(sunrise);
                                    pugsly @henry2man
                                    @henry2man
                                    I am having the same problem, whenever I put it in my config the display is blank.
                                      sdetweil @pugsly
                                      @pugsly not in config… you have to edit the actual module code
                                        pugsly @sdetweil
                                        @sdetweil Not sure I know what you mean. When I put this in my config the screen is all blank:
                                                header: "Sunrise",
                                                    latitude: "39.2907",
                                                    longitude: "-75.6344",
                                                    apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                                    layout: "inline"
                                          sdetweil @pugsly
                                          @pugsly open the developers window on your blank screen MM, using ctrl-shift-i on the keyboard… select the tab labeled console and scroll up to find any errors
                                            pugsly @sdetweil
                                            Uncaught ReferenceError: $ is not defined
                                            at Class.updateSun (MMM-Sunrise-Sunset.js:33)
                                            at Class.start (MMM-Sunrise-Sunset.js:12)
                                            at startModules (loader.js:55)
                                            at loader.js:40
                                            at HTMLLinkElement.stylesheet.onload (loader.js:200)
