    MMM-Sunrise-Sunset
    44 Posts 9 Posters 28.1k Views 10 Watching
      mrdenmark
      would it be possible to add a line with the day length?i’m not sure how to go about adding a time offset,i’ll do some research
      vblokeV 1 Reply Last reply
      • vblokeV
        vbloke Module Developer @mrdenmark
        @mrdenmark if you update the module now, it should account for the timezone if you set it in your config. From your latitude/longitude, yours (I think) would be “Pacific/Auckland”.
        Try this:
          module: "MMM-Sunrise-Sunset",
        	latitude: "-44.57",
        	longitude: "168.50",
        	timezone: "Pacific/Auckland",
        	layout: "list"
          mrdenmark
          worked,cheers!
            sdetweil @vbloke
            @vbloke you can get the timezone from the lat/lng
            http://www.geonames.org/export/web-services.html#timezone
            https://stackoverflow.com/questions/16086962/how-to-get-a-time-zone-from-a-location-using-latitude-and-longitude-coordinates
            • vblokeV
              https://github.com/prydonian/MMM-Sunrise-Sunset
              Made a fairly big update using a different API that needs a free key.
              https://ipgeolocation.io/signup.html
              It now gives you moonrise and moonset times and day length.
              • H
                henry2man
                I tried this module but activating this causes my MM to show nothing. I had no error messages on MM logs (in my case, a docker server-only instance) and nor on my Chrome console.
                In other words it looks that the IPGeo free key expires in 1 day…
                vblokeV P 2 Replies Last reply
                • vblokeV
                  vbloke Module Developer @henry2man
                  @henry2man the API is limited to 1000 calls per day. It doesn’t appear to expire after a day.
                  Can you post the config for the module?
                  it should look like this:
                        position: "bottom_bar",
                  		apiKey: "API_KEY",
                  		latitude: "123.123",
                  		longitude: "23.456",
                  		layout: "inline"
                  • H
                    henry2man
                    I removed the config but seemed like yours. I followed the README from master. I’ll try again later, but also I’ve reviewed this API
                    https://api.sunrise-sunset.org/json?lat=36.7201600&lng=-4.4203400&formatted=0
                    It has enough information and seems to be free.
                    What do you think?
                    • vblokeV
                      @henry2man that’s the one I was using before, but it required a lot of work to get the time in your local time zone as all times were returned as UTC.
                      The new API uses your location to format the time automatically.
                      H Mykle1M 2 Replies Last reply
                      • H
                        henry2man @vbloke
                        @vbloke In this link there is a simple way to get a ISO 8601 into your local timezone --> https://stackoverflow.com/a/31453408
                        var utcDate = '2011-06-29T16:52:48.000Z';  // ISO-8601 formatted date returned from server
                        var localDate = new Date(utcDate);
                        api.sunrise-sunset.org can return ISO 8601 dates using
                        formatted=0
                        parameter…
                        If date parsing is the major issue & this solution works I think this approach is simpler. Even you can default the URL and simply configure lat/long & style (inline/list)
                        Just my 2 cents…
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @vbloke
                          @vbloke
                          This is right out of my MMM-SunRiseSet module.
                          Feel free to use it if you like. :thumbsup:
                          // sunrise set to local time using moment
                             var sunrise = document.createElement("div");
                             sunrise.classList.add("small", "bright", "sunrise");
                             sunrise.innerHTML = "Sunrise is at " + moment(SunRiseSet.sunrise).local().format("h:mm a") + " &nbsp &nbsp "
                          + "Sunset is at " + moment(SunRiseSet.sunset).local().format("h:mm a");
                             wrapper.appendChild(sunrise);
                            pugsly @henry2man
                            @henry2man
                            I am having the same problem, whenever I put it in my config the display is blank.
                              sdetweil @pugsly
                              @pugsly not in config… you have to edit the actual module code
                              P 1 Reply Last reply
                                pugsly @sdetweil
                                @sdetweil Not sure I know what you mean. When I put this in my config the screen is all blank:
                                        header: "Sunrise",
                                            latitude: "39.2907",
                                            longitude: "-75.6344",
                                            apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                            layout: "inline"
                                S 2 Replies Last reply
                                  sdetweil @pugsly
                                  @pugsly open the developers window on your blank screen MM, using ctrl-shift-i on the keyboard… select the tab labeled console and scroll up to find any errors
                                    pugsly @sdetweil
                                    Uncaught ReferenceError: $ is not defined
                                    at Class.updateSun (MMM-Sunrise-Sunset.js:33)
                                    at Class.start (MMM-Sunrise-Sunset.js:12)
                                    at startModules (loader.js:55)
                                    at loader.js:40
                                    at HTMLLinkElement.stylesheet.onload (loader.js:200)
                                      sdetweil @pugsly
                                      @pugsly said in MMM-Sunrise-Sunset:
                                      this module depends on jquery library being installed for this module, but its not…,
                                      I am working on instructions for you… hang on
                                      do
                                      cd ~/MagicMirror/modules/MMM-Sunrise-Sunset
                                      npm install jquery
                                      # note the trailing dot (.) on the next line
                                      cp node_modules/jquery/dist/jquery.js .
                                      then start your mirror again
                                      P D 2 Replies Last reply
                                        pugsly @sdetweil
                                        @sdetweil said in MMM-Sunrise-Sunset:
                                        Slightly better, its displaying now but just says ‘Loading’
                                          sdetweil @pugsly
                                          @pugsly ok, open the developers window again
                                          this usually means that the api key is wrong … the api isn’t returning data
                                            pugsly @sdetweil
                                            Its not passing the API key in the HTML request.
                                            https://api.ipgeolocation.io/astronomy?apiKey=&lang=en&lat=39.2907&long=-75.6344 401
