    Alexa Goes Handsfree!
    23 Posts 9 Posters 23.5k Views 8 Watching
    • MichMichM
      MichMich
      Nice! Time to connect a microphone to my Mirror! ;)
        cyberphox @KirAsh4
        @KirAsh4 saw this the other day…but was never able to get Amazon’s way of it going using Java. Always getting an error with my USB sound device. Gonna try NovaSpirit’s method and might live with the button for now
          d3r
          I’ve had the last version running since last Thursday. It’s really great now that it’s headless. I’m using snowboy and changed my wakeword to “Hey Jarvis” , I’ve used it every day since I installed it to trigger my hue lights via ifttt. Now to find a way to display the alexa cards on mm2 and that would be perfect.
          Edit:
          Didn’t read the article. Thought this was about the recent changes were we no longer have to click the button to activate it on the pi anymore. Anyways, I can’t really code yet and really want to do something with this as amazon have a lot of documentation online. My problem is work and personal stuff is getting on the way.
          bheplerB 1 Reply Last reply
          • W
            WeedWood
            Hey is there a modul for it?
            • bheplerB
              bhepler Module Developer @d3r
              @d3r Wait, what? You can use Alexa’s voice service to activate on whatever phrase you like?
              Oh, this is too awesome. My wife and were trying to get our echo to wake on “Hey Asshole” (it’s a literary reference, honest) and it wouldn’t let us. I’m going to get to work on a new mirror…
                d3r
                @bhepler Are you running it from your pi or do you have the echo/dot?
                If you are using the pi then yes you can customize the wake word which will trigger it into listening mode.
                C 1 Reply Last reply
                • KirAsh4K
                  KirAsh4 Moderator
                  “Hey Dingdong!”
                  “Yow Tweedledumb!”
                  Or make it interactive:
                  “Hey Cheech!”
                  “Yes Chong?”
                    darrene
                    I’ve jsut set up an Amazon dev account and installing the Alexa pi code to have a play with.
                    During the install, I see
                    Configuration file ‘/etc/lightdm/lightdm.conf’
                    ==> Modified (by you or by a script) since installation.
                    ==> Package distributor has shipped an updated version.
                    What would you like to do about it ? Your options are:
                    Y or I : install the package maintainer’s version
                    N or O : keep your currently-installed version
                    D : show the differences between the versions
                    Z : start a shell to examine the situation
                    The default action is to keep your current version.
                    *** lightdm.conf (Y/I/N/O/D/Z) [default=N] ?
                    I think I should answer ‘Y’ to keep the installer happy, but thought it worth checking - @d3r can I ask what you chose?
                    D 1 Reply Last reply
                      d3r @darrene
                      @darrene I would say press D to see what the difference is then you’ll have a better idea on how to proceed.
                      Edit:
                      I just ran an update on my pi and got the same prompt. lightdm is a display manager and not directly related to alexa.
                      https://wiki.debian.org/LightDM
                        darrene
                        Ah, thtat’s great. Thanks @d3r.
                        All good now
                          d3r @darrene
                          @darrene Nice. Alexa is working now?
                            darrene @d3r
                            @d3r not quite - I’m almost there but trying to login to my AWS mirror profile after authorising it and I’m failing their ridiculous ‘type the characters you see in this image’ challenge :)
                            Edit: At last! through…
                              darrene
                              It’s awesome :)
                              I’ve had Alexa tell me the day, a joke and asked her a maths question.
                              A quick demo (YouTube)
                              The detection is spot on and the response time is pretty acceptable
                              The sooner this can get made into a module the better :)
                              • KirAsh4K
                                KirAsh4 Moderator
                                The changes to the lightdm config file is probably what it’s warning you about. Remember during the MM installation, you should’ve edited that file to turn off the screen blanking. So you should always do a comparison between what your file looks like and what the vendor is releasing and apply the changes as needed.
                                  darrene
                                  That’s what it was. Thanks @KirAsh4!
                                  • MichMichM
                                    MichMich
                                    Didn’t look into this very much, so maybe one of you can answer this: is it possible to let Alexa execute commands or code? So we can incorporate it into MagicMirror²?
                                      darrene @MichMich
                                      I don’t think it can from what I’ve seen @MichMich - I could be wrong, but it isn’t obvious that it could.
                                      Running the Alexa sample requires 3 terminal sessions -
                                      one runs the companion service which stores the application token information and runs a listener on port 3000
                                      one runs the java client under maven
                                      One runs the wake word agent, running one of two engines - kitt_ai or sensory (I opted for kitt_ai)
                                      I can’t tell at the moment, what information is returned by AVS, so it’s difficult to know if and how usable it is. It does support IFTTT however. Combining it with the MMM-IFTTT module, whilst not elegant, may be a workaround?
                                      For what it’s worth, the install, whilst lengthy was fully automated and incredibly trouble free - it worked straight out of the box on a fresh Raspian install which already had a barebones MagicMirror2 install.
                                      Also of note, every time I need to restart the java client, I am required to re-authenticate my device to get a new bearer/autentication token. These tokens do not seem to last that long and the authentication process involves logging into Amazon through a web page with an image security verification. No doubt that’s down to how this sample is implemented but might be worth knowing about
                                        d3r
                                        It is possible to tell alexa to execute the codes. There are several projects using aws lamda to process the codes. This guy for example did it with his mirror.
                                        [https://forum.magicmirror.builders/topic/641/the-mystic-mirror-an-alexa-powered-magic-mirror](alexa mirror)
                                          carteblanche @d3r
                                          @d3r said in Alexa Goes Handsfree!:
                                          How did you customize the wake word? I’m using the Alexa AVS sample app on my Rpi3 which uses snowboy as the wakeword agent and everything is working great, but would love it if I didn’t have to use the name “alexa”!
                                            d3r @carteblanche
                                            @carteblanche [https://groups.google.com/a/kitt.ai/forum/m/#!topic/snowboy-discussion/UIX2eK4ScjI](Recompile for custom wake word)
                                            You need to create your own voice model and recompile the code. Check the above link. It is pretty straight foward though I found that I get lots of false hits but that’s because my model number doesn’t have a lot of samples.
