    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 285.8k Views 35 Watching
      dnovacik
      Don’t forget that Strava is switching to using refresh tokens from 15th October 2019 and won’t be supporting forever tokens anymore. I started writing a little Strava api library in js, currently with only 2 endpoints and going to add up more ofc.
      https://github.com/dnovacik/strava-minimal-api
      • lavolp3L
        lavolp3 Module Developer @dnovacik
        @dnovacik Well this module uses the strava-v3 nodejs library by unboundev.
        github link.
        I guess that is where the new token procedure should be implemented isn’t it?
        Care to take a look?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • I
          ianperrin @lavolp3
          @dnovacik
          The develop branch for the module contains the changes to support the new authentication approach - I’ll merge that back into the master branch in the coming weeks so the module can continue to be used
          @lavolp3
          I extended the Strava-v3 package (see https://github.com/ianperrin/MMM-Strava/blob/develop/strava_api.js) to support the new authentication methods. I guess these could be incorporated into a pull request for the core package now that it is active again ;)
          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
            dnovacik
            @ianperrin gj then, can’t wait to try out the module!
            • Z
              zolabus
              I can’t use the module anymore
              If I try to reauthorize i have this error
              {“message”:“Bad Request”,“errors”:[{“resource”:“Authorize”,“field”:“scope”,“code”:“invalid”}]}
              Any help please?
              • I
                ianperrin @zolabus
                @zolabus said in MMM-Strava:
                Any help please?
                @zolabus - I’ve just released version 2.0.0 of the plugin which is available via the Master branch. Can you try this version?
                When updating please make sure you run npm install --production from the MMM-Strava directory.
                If you continue to get these errors, please check the Authorization Callback Domain in your Strava API Settings (https://www.strava.com/settings/api) matches the IP address/URL used to access MagicMirror
                Z 1 Reply Last reply Reply Quote 0
                • Z
                  zolabus @ianperrin
                  @ianperrin
                  Hi I updated the module
                  When I restart the Magic Mirror I receive this
                  MMM-Strava: “Received notification: SET_CONFIG”
                  MMM-Strava: “Legacy config in use for module_14_MMM-Strava”
                  MMM-Strava: “Getting data for module_14_MMM-Strava”
                  MMM-Strava: “Access token not found for module_14_MMM-Strava”
                  • Z
                    zolabus @zolabus
                    @ianperrin
                    Issue resolved thanks
                      MisterT
                      Hi everybody,
                      I posted in troubleshooting section but i don’t know if it’s visible. That’s why i post here. I don’t understand the step 2 and the step 5 in Tutorial about MMM-Strava. I have a ID and a secret but i don’t know what i write in case:
                      APi Name
                      Category
                      Club
                      WebSite
                      Description
                      and Callback domain
                      In Website and Callback domain what i write?
                      In callback domain, i put my IP to my magic mirror like 192.128.1.99:8080 but nothing happen
                      Can anybody help me please?
                      • I
                        ianperrin @MisterT
                        @MisterT
                        When creating your Strava API Application in Step 2, the key value is the Authorisation Callback Domain. This needs to the IP address or domain name you use to access the MagicMirror otherwise subsequent steps will fail. So in your case it looks like you should use 192.128.1.99
                        Once the API Application is created, add the module to your config.js file with the client_id and client_secret then restart the mirror.
                        The module should then state Client id unauthorised and provide a link to the authorisation process. At which point you should be able to follow step 5
                        Here’s two screenshots which might help:
                        Strava API Settings
                        Strava API id and secret
                          MisterT
                          ok thanks ianperrin for your help
                          Step 2 is ok because on magic mirror, i have the link on magic mirror : client unauthorized see /MMM-Strava/auth/
                          but now in step 5, i make:
                          in webpage, and magic mirror starting i put
                          http://192.128.1.99:8080/MMM-Strava/Oauth/
                          but nothing happen. The webpage says:
                          host unreachable
                          ERR_CONNECTION_REFUSED
                          have you an idea?
                          • I
                            ianperrin @MisterT
                            @MisterT is it possible you’re typing in the wrong url. Try using
                            http://192.128.1.99:8080/MMM-Strava/auth/ or simply clicking the link displayed by the module on the mirror.
                            If that fails, are you able to access your mirror via http://192.128.1.99:8080/ ?
                            Finally, can you make sure you ran npm install --production in step 1 and restarted the mirror?
                              MisterT
                              hI @ianperrin
                              It Works !!!
                              Nice explanations.
                              My mistake is when i launched a webpage to write the url i stoped the MM by Ctrl+Q. Now with MM start and a webpage opened. Everything is alright
                              Thanks for your help
                                MisterT
                                hI @ianperrin
                                I have another problem with MMM-Strava.
                                I use it with MMM-Pages and MMM-Pages indicator. When i place the module in the config.js MMM-Pages settings, the Rotation of MMM-Pages doesn’t work and i have a error on Magic mirror when i press CTRL+SHIFT+i.
                                See Thread below for mox explanations
                                MMM-Pages no rotate
                                Have you an idea?
                                • I
                                  ianperrin @MisterT
                                  @MisterT thanks for the report.
                                  I don’t have any experience with MMM-Pages so will have to install it and take a look if I experience the same issues.
                                  Have you any idea what might be causing it?
                                  • I
                                    ianperrin
                                    An updated BETA version of MMM-Strava is available which includes a chartType option to toggle between classic bar chart and a new radial histogram
                                    Below is a sample config and screenshot - note the histogram will display in grayscale, colours can be achieved using custom.css
                                    	module: "MMM-Strava",
                                    	header: 'Strava Radial Chart',
                                    		client_id: "xxxxx",
                                    		client_secret: "xxxxx",
                                    		mode: "chart",
                                    		chartType: "radial",
                                    		period: "ytd"
                                    Please report any comments/issues here, or on github
                                    W 1 Reply Last reply Reply Quote 1
                                      MisterT @ianperrin
                                      @ianperrin thx for your reply, I’m the noob in .js but i tried to understand the problem and the report is about “toLowerCase”. In MMM-Strava.js, if i modify the three config lines witch contain the synthax “toLowercase”, the result on Magic Mirror is a rotation of MMM-Pages but a message “Undefined” for MMM-Strava
                                          this.config.mode = this.config.mode.toLowerCase();
                                          this.config.period = this.config.period.toLowerCase();
                                          this.config.chartType = this.config.chartType.toLowerCase();
                                      hope these light explanations can help you :face_screaming_in_fear:
                                      • I
                                        ianperrin @MisterT
                                        @MisterT can you post the modified versions of these lines which enabled MMM-pages to rotate, but caused the undefined error for MMM-Strava?
                                        I’m also curious about the error you posted in the other thread as it seems to refer to a style sheet included by another module…
                                          MisterT @ianperrin
                                          @ianperrin i don’t know what i write and the meaning but if i modified these 2 lines (i don’t have the third line), i have MM rotation but undefined on MMM-Strava
                                             this.config.mode = this.config.mode.toLowerCase().mode;
                                            this.config.period = this.config.period.toLowerCase().period;
                                          The other error in wallberry module is a css error but i don’t think that it’s the problem of rotation because MMM-pages works with this error
                                          • I
                                            ianperrin @MisterT
                                            @MisterT I’ve just pushed an update to the module which may have fixed it. Can you update the module and let me know how it works out?
                                            • 5 / 7
