    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 282.0k Views 35 Watching
      dnovacik
      @ianperrin gj then, can’t wait to try out the module!
      • Z Offline
        zolabus
        I can’t use the module anymore
        If I try to reauthorize i have this error
        {“message”:“Bad Request”,“errors”:[{“resource”:“Authorize”,“field”:“scope”,“code”:“invalid”}]}
        Any help please?
        • I Offline
          ianperrin @zolabus
          @zolabus said in MMM-Strava:
          Any help please?
          @zolabus - I’ve just released version 2.0.0 of the plugin which is available via the Master branch. Can you try this version?
          When updating please make sure you run npm install --production from the MMM-Strava directory.
          If you continue to get these errors, please check the Authorization Callback Domain in your Strava API Settings (https://www.strava.com/settings/api) matches the IP address/URL used to access MagicMirror
          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
          Z 1 Reply Last reply Reply Quote 0
          • Z Offline
            zolabus @ianperrin
            @ianperrin
            Hi I updated the module
            When I restart the Magic Mirror I receive this
            MMM-Strava: “Received notification: SET_CONFIG”
            MMM-Strava: “Legacy config in use for module_14_MMM-Strava”
            MMM-Strava: “Getting data for module_14_MMM-Strava”
            MMM-Strava: “Access token not found for module_14_MMM-Strava”
            • Z Offline
              zolabus @zolabus
              @ianperrin
              Issue resolved thanks
                MisterT
                Hi everybody,
                I posted in troubleshooting section but i don’t know if it’s visible. That’s why i post here. I don’t understand the step 2 and the step 5 in Tutorial about MMM-Strava. I have a ID and a secret but i don’t know what i write in case:
                APi Name
                Category
                Club
                WebSite
                Description
                and Callback domain
                In Website and Callback domain what i write?
                In callback domain, i put my IP to my magic mirror like 192.128.1.99:8080 but nothing happen
                Can anybody help me please?
                • I Offline
                  ianperrin @MisterT
                  @MisterT
                  When creating your Strava API Application in Step 2, the key value is the Authorisation Callback Domain. This needs to the IP address or domain name you use to access the MagicMirror otherwise subsequent steps will fail. So in your case it looks like you should use 192.128.1.99
                  Once the API Application is created, add the module to your config.js file with the client_id and client_secret then restart the mirror.
                  The module should then state Client id unauthorised and provide a link to the authorisation process. At which point you should be able to follow step 5
                  Here’s two screenshots which might help:
                  Strava API Settings
                  Strava API id and secret
                    MisterT
                    ok thanks ianperrin for your help
                    Step 2 is ok because on magic mirror, i have the link on magic mirror : client unauthorized see /MMM-Strava/auth/
                    but now in step 5, i make:
                    in webpage, and magic mirror starting i put
                    http://192.128.1.99:8080/MMM-Strava/Oauth/
                    but nothing happen. The webpage says:
                    host unreachable
                    ERR_CONNECTION_REFUSED
                    have you an idea?
                    • I Offline
                      ianperrin @MisterT
                      @MisterT is it possible you’re typing in the wrong url. Try using
                      http://192.128.1.99:8080/MMM-Strava/auth/ or simply clicking the link displayed by the module on the mirror.
                      If that fails, are you able to access your mirror via http://192.128.1.99:8080/ ?
                      Finally, can you make sure you ran npm install --production in step 1 and restarted the mirror?
                        MisterT
                        hI @ianperrin
                        It Works !!!
                        Nice explanations.
                        My mistake is when i launched a webpage to write the url i stoped the MM by Ctrl+Q. Now with MM start and a webpage opened. Everything is alright
                        Thanks for your help
                          MisterT
                          hI @ianperrin
                          I have another problem with MMM-Strava.
                          I use it with MMM-Pages and MMM-Pages indicator. When i place the module in the config.js MMM-Pages settings, the Rotation of MMM-Pages doesn’t work and i have a error on Magic mirror when i press CTRL+SHIFT+i.
                          See Thread below for mox explanations
                          MMM-Pages no rotate
                          Have you an idea?
                          • I Offline
                            ianperrin @MisterT
                            @MisterT thanks for the report.
                            I don’t have any experience with MMM-Pages so will have to install it and take a look if I experience the same issues.
                            Have you any idea what might be causing it?
                            • I Offline
                              ianperrin
                              An updated BETA version of MMM-Strava is available which includes a chartType option to toggle between classic bar chart and a new radial histogram
                              Below is a sample config and screenshot - note the histogram will display in grayscale, colours can be achieved using custom.css
                              	module: "MMM-Strava",
                              	header: 'Strava Radial Chart',
                              		client_id: "xxxxx",
                              		client_secret: "xxxxx",
                              		mode: "chart",
                              		chartType: "radial",
                              		period: "ytd"
                              Please report any comments/issues here, or on github
                              W 1 Reply Last reply Reply Quote 1
                                MisterT @ianperrin
                                @ianperrin thx for your reply, I’m the noob in .js but i tried to understand the problem and the report is about “toLowerCase”. In MMM-Strava.js, if i modify the three config lines witch contain the synthax “toLowercase”, the result on Magic Mirror is a rotation of MMM-Pages but a message “Undefined” for MMM-Strava
                                    this.config.mode = this.config.mode.toLowerCase();
                                    this.config.period = this.config.period.toLowerCase();
                                    this.config.chartType = this.config.chartType.toLowerCase();
                                hope these light explanations can help you :face_screaming_in_fear:
                                • I Offline
                                  ianperrin @MisterT
                                  @MisterT can you post the modified versions of these lines which enabled MMM-pages to rotate, but caused the undefined error for MMM-Strava?
                                  I’m also curious about the error you posted in the other thread as it seems to refer to a style sheet included by another module…
                                    MisterT @ianperrin
                                    @ianperrin i don’t know what i write and the meaning but if i modified these 2 lines (i don’t have the third line), i have MM rotation but undefined on MMM-Strava
                                       this.config.mode = this.config.mode.toLowerCase().mode;
                                      this.config.period = this.config.period.toLowerCase().period;
                                    The other error in wallberry module is a css error but i don’t think that it’s the problem of rotation because MMM-pages works with this error
                                    • I Offline
                                      ianperrin @MisterT
                                      @MisterT I’ve just pushed an update to the module which may have fixed it. Can you update the module and let me know how it works out?
                                        MisterT @ianperrin
                                        @ianperrin, i update your module and…tada it works :thumbs_up: great job
                                        MMM-Pages rotate and MMM Strava is visible
                                        Everything is good now
                                        I also try your other update about radial chart vizualisation and it’s great. I tested with year to date for bike and run and its’awesome. Just 2 remark:
                                        • In my opinion the radial gaphic it’s just a little too big and the graphic overlaps the other module.
                                        • I think we need informations about custom css in order to display colors about kilometers like for exemple:
                                          less 10 km for running in a month : red color
                                          from 10 to 30 km for running in a month: orange color
                                          over 30 km for running in a month : green color
                                        see you next time
                                        I 2 Replies Last reply Reply Quote 0
                                        • I Offline
                                          ianperrin @MisterT
                                          @MisterT - Great to hear it’s working now 👍
                                          • I Offline
                                            ianperrin @MisterT
                                            @MisterT said in MMM-Strava:
                                            I’m working on making the chart size customisable - watch out for further updates
                                            I like the idea of colouring the bars based on a target. Will think about this one.
                                            In the meantime, to customise the colours of each bar in the radial chart, add the following to the custom.css file in ~/MagicMirror/css.
                                            .MMM-Strava svg path.bar.interval-1 {
                                              fill: #67b7dc;
                                            .MMM-Strava svg path.bar.interval-2 {
                                              fill: #6794dc;
                                            .MMM-Strava svg path.bar.interval-3 {
                                              fill: #6771dc;
                                            .MMM-Strava svg path.bar.interval-4 {
                                              fill: #8067dc;
                                            .MMM-Strava svg path.bar.interval-5 {
                                              fill: #a367dc;
                                            .MMM-Strava svg path.bar.interval-6 {
                                              fill: #c767dc;
                                            .MMM-Strava svg path.bar.interval-7 {
                                              fill: #dc67ce;
                                            .MMM-Strava svg path.bar.interval-8 {
                                              fill: #dc67ab;
                                            .MMM-Strava svg path.bar.interval-9 {
                                              fill: #dc6788;
                                            .MMM-Strava svg path.bar.interval-10 {
                                              fill: #dc6967;
                                            .MMM-Strava svg path.bar.interval-11 {
                                              fill: #dc8c67;
                                            .MMM-Strava svg path.bar.interval-12 {
                                              fill: #dcaf67;
                                            Note: As the radial chart is in beta, the css classes may be subject to change.
                                            • 5 / 7
