    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 290.0k Views 35 Watching
    • I
      ianperrin @MisterT
      @MisterT
      When creating your Strava API Application in Step 2, the key value is the Authorisation Callback Domain. This needs to the IP address or domain name you use to access the MagicMirror otherwise subsequent steps will fail. So in your case it looks like you should use 192.128.1.99
      Once the API Application is created, add the module to your config.js file with the client_id and client_secret then restart the mirror.
      The module should then state Client id unauthorised and provide a link to the authorisation process. At which point you should be able to follow step 5
      Here’s two screenshots which might help:
      Strava API Settings
      Strava API id and secret
      “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
        MisterT
        ok thanks ianperrin for your help
        Step 2 is ok because on magic mirror, i have the link on magic mirror : client unauthorized see /MMM-Strava/auth/
        but now in step 5, i make:
        in webpage, and magic mirror starting i put
        http://192.128.1.99:8080/MMM-Strava/Oauth/
        but nothing happen. The webpage says:
        host unreachable
        ERR_CONNECTION_REFUSED
        have you an idea?
        I 1 Reply Last reply
        • I
          ianperrin @MisterT
          @MisterT is it possible you’re typing in the wrong url. Try using
          http://192.128.1.99:8080/MMM-Strava/auth/ or simply clicking the link displayed by the module on the mirror.
          If that fails, are you able to access your mirror via http://192.128.1.99:8080/ ?
          Finally, can you make sure you ran npm install --production in step 1 and restarted the mirror?
            MisterT
            hI @ianperrin
            It Works !!!
            Nice explanations.
            My mistake is when i launched a webpage to write the url i stoped the MM by Ctrl+Q. Now with MM start and a webpage opened. Everything is alright
            Thanks for your help
              MisterT
              hI @ianperrin
              I have another problem with MMM-Strava.
              I use it with MMM-Pages and MMM-Pages indicator. When i place the module in the config.js MMM-Pages settings, the Rotation of MMM-Pages doesn’t work and i have a error on Magic mirror when i press CTRL+SHIFT+i.
              See Thread below for mox explanations
              MMM-Pages no rotate
              Have you an idea?
              • I
                ianperrin @MisterT
                @MisterT thanks for the report.
                I don’t have any experience with MMM-Pages so will have to install it and take a look if I experience the same issues.
                Have you any idea what might be causing it?
                M 1 Reply Last reply
                • I
                  ianperrin
                  An updated BETA version of MMM-Strava is available which includes a chartType option to toggle between classic bar chart and a new radial histogram
                  Below is a sample config and screenshot - note the histogram will display in grayscale, colours can be achieved using custom.css
                  	module: "MMM-Strava",
                  	header: 'Strava Radial Chart',
                  		client_id: "xxxxx",
                  		client_secret: "xxxxx",
                  		mode: "chart",
                  		chartType: "radial",
                  		period: "ytd"
                  Please report any comments/issues here, or on github
                  W 1 Reply Last reply
                    MisterT @ianperrin
                    @ianperrin thx for your reply, I’m the noob in .js but i tried to understand the problem and the report is about “toLowerCase”. In MMM-Strava.js, if i modify the three config lines witch contain the synthax “toLowercase”, the result on Magic Mirror is a rotation of MMM-Pages but a message “Undefined” for MMM-Strava
                        this.config.mode = this.config.mode.toLowerCase();
                        this.config.period = this.config.period.toLowerCase();
                        this.config.chartType = this.config.chartType.toLowerCase();
                    hope these light explanations can help you :face_screaming_in_fear:
                    • I
                      ianperrin @MisterT
                      @MisterT can you post the modified versions of these lines which enabled MMM-pages to rotate, but caused the undefined error for MMM-Strava?
                      I’m also curious about the error you posted in the other thread as it seems to refer to a style sheet included by another module…
                        MisterT @ianperrin
                        @ianperrin i don’t know what i write and the meaning but if i modified these 2 lines (i don’t have the third line), i have MM rotation but undefined on MMM-Strava
                           this.config.mode = this.config.mode.toLowerCase().mode;
                          this.config.period = this.config.period.toLowerCase().period;
                        The other error in wallberry module is a css error but i don’t think that it’s the problem of rotation because MMM-pages works with this error
                        • I
                          ianperrin @MisterT
                          @MisterT I’ve just pushed an update to the module which may have fixed it. Can you update the module and let me know how it works out?
                            MisterT @ianperrin
                            @ianperrin, i update your module and…tada it works :thumbs_up: great job
                            MMM-Pages rotate and MMM Strava is visible
                            Everything is good now
                            I also try your other update about radial chart vizualisation and it’s great. I tested with year to date for bike and run and its’awesome. Just 2 remark:
                            • In my opinion the radial gaphic it’s just a little too big and the graphic overlaps the other module.
                            • I think we need informations about custom css in order to display colors about kilometers like for exemple:
                              less 10 km for running in a month : red color
                              from 10 to 30 km for running in a month: orange color
                              over 30 km for running in a month : green color
                            see you next time
                            I 2 Replies Last reply
                            • I
                              ianperrin @MisterT
                              @MisterT - Great to hear it’s working now 👍
                              • I
                                ianperrin @MisterT
                                @MisterT said in MMM-Strava:
                                I’m working on making the chart size customisable - watch out for further updates
                                I like the idea of colouring the bars based on a target. Will think about this one.
                                In the meantime, to customise the colours of each bar in the radial chart, add the following to the custom.css file in ~/MagicMirror/css.
                                .MMM-Strava svg path.bar.interval-1 {
                                  fill: #67b7dc;
                                .MMM-Strava svg path.bar.interval-2 {
                                  fill: #6794dc;
                                .MMM-Strava svg path.bar.interval-3 {
                                  fill: #6771dc;
                                .MMM-Strava svg path.bar.interval-4 {
                                  fill: #8067dc;
                                .MMM-Strava svg path.bar.interval-5 {
                                  fill: #a367dc;
                                .MMM-Strava svg path.bar.interval-6 {
                                  fill: #c767dc;
                                .MMM-Strava svg path.bar.interval-7 {
                                  fill: #dc67ce;
                                .MMM-Strava svg path.bar.interval-8 {
                                  fill: #dc67ab;
                                .MMM-Strava svg path.bar.interval-9 {
                                  fill: #dc6788;
                                .MMM-Strava svg path.bar.interval-10 {
                                  fill: #dc6967;
                                .MMM-Strava svg path.bar.interval-11 {
                                  fill: #dc8c67;
                                .MMM-Strava svg path.bar.interval-12 {
                                  fill: #dcaf67;
                                Note: As the radial chart is in beta, the css classes may be subject to change.
                                R 1 Reply Last reply
                                  mattx38
                                    matt216
                                    Hi there. Icons. Recently updated my config to include ‘hike’ activity, and it does, but without the nice little icon beside (like the little shoe beside run activities, and bike beside cycle activities). In ‘chart’ mode. Any ideas?
                                    • H
                                      huso15
                                      why am I getting this error?
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-Strava $ npm install --production
                                      audited 1631 packages in 19.838s
                                      73 packages are looking for funding
                                      run npm fund for details
                                      found 0 vulnerabilities
                                      – how do I fix this funding issue? I don’t have any luck with “nom fund”.
                                      I’m also having difficulties connecting to http://localhost:8080/MMM-Strava/auth/ and I’m thinking it’s because of this funding. Any help would be appreciated.
                                      Thank you!
                                      • W
                                        Wilson101 @ianperrin
                                        @ianperrin hello i have tried to run this i am a complete beginner learning as i am going, however trying to get this radial version which i think looks really cool it gets stuck, i launch my magic mirror and then it gets stuck on the “loading…” process
                                          ruudvddries @ianperrin
                                          @ianperrin Is it possible to shrink the radial display from the current 500px width to something smaller. Like 300px?
                                          The radial display for strava is awesome. With its default size it somewhat messes up my MagicMirror layout.
                                          I already tried some CSS and JS adaptions but it not yet helped to achieve what I wanted. Any help is welcome!
                                          Greetings,
                                          Ruud
                                          • thymonT
                                            thymon
                                            Hello
                                            Today I have an error message on display :
                                            502 - undefined
                                            Any idea for this ?
                                            • 5 / 7
