    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
    • L
      lotusvball @Guest
      @Sean Just emailed it. from sabard@gmail.com
        code999 @wegz15
        @wegz15 Hey!! your layout is the exact one I have been trying to do for many hours over the last months. May you please paste the code you used to make it looks like that? thx ( the doc’s are confusing and do not show where the part of the codes go to make it work. i liked the first Ext docs better.)
          rookiepilot
          Did anybody else’s MMM-CalendarExt2 module break after daylight savings? (Sunday November 3rd). Both my “MMM-MyCalendar” AND “MMM-CalendarExt2” modules are showing events on the wrong days now. The problem seems to only occur with reoccurring events; they usually show up one day earlier. Rebooting does not correct the issue. I hope someone can figure this out soon 😞
            code999
            Hi All,
            So I have been trying to figure out how to make the calendar smaller. It is over lapping other modules. I have read the docs but I am unclear on how it all comes together to work. Please help.
              code999 @code999
              @code999 I guess no one knows how to do this? Everything I try it does not change what I want.
                A Former User @code999
                @code999
                Too ambiguous. What you tried and what you expected as a result? It would be nice to understand with an image about where is an issue and how to change it.
                You can customize CSS to adjust the size of almost every element, and you can adjust some height-related values on the configuration. And, there be some brief information about the HTML structure and CSS selectors on docs. e.g) https://github.com/eouia/MMM-CalendarExt2/wiki/4.-Styling
                So, what is your issue?
                  code999 @Guest
                  @Sean sorry about me not able to explain what I am trying to do. this is how it looks now. 0_1573232750888_before edit.JPG I want to move it to the right and shrink it so it does not overlap the other modules. 0_1573232901007_trying to do.JPG
                  Thanks for your help.
                  M ? 2 Replies Last reply Reply Quote 0
                    mrdenmark
                      mrdenmark @code999
                      @code999
                      try position top_right instead of full_screen and see how that looks, you can then have a dig around the files and see if you can alter the size by specifying the size % or pixels
                        mrdenmark
                        @Sean ,
                        can this module work with mmm-keybindings?i’d like to use the spacebar or similar to cycle through scenes
                          @code999
                          Which position did you set for the view? put the view in a proper position, then, add this into your css/custom.css
                          .CX2 {
                            width: 800px;
                          Or any size you want.
                            A Former User @mrdenmark
                            @mrdenmark
                            https://github.com/eouia/MMM-CalendarExt2/wiki/3.-Usage
                            If your module can emit customized notifications(e.g: CALEXT2_SCENE_NEXT or somethings), possible.
                            Or you can use MMM-NotificationTrigger to translate or relay original notification to specific customized target notification.
                              jani.karna
                              Hi! I’m trying to modify css. I created css/custom.css in MagicMirror/modules/MMM-CalendarExt2/ and tried doing modifications but none of them seem to do anything. Permissions for dir and file are 777.
                              Is there something I’m not understanding here?
                              for example I tried this in custom.css but it doesn’t work. This only works in MMM-CalendarExt.css file.
                              .CX2 .weekSlot.seq_0 .cellSlot .slotSubTitle {
                                position:relative;
                                top:-30px;
                                left:40%;
                              Also, how can I get month calendar to only show 4 weeks instead of 5?
                                A Former User @jani.karna
                                @jani-karna
                                You don’t need to create your own css/custom.css under module directory. That file locates under your MagicMirror directory. css/custom.css is a global common file to be used by all the modules.
                                  jani.karna
                                  Oh, I see. Some modules seem to have their own directory, like MMM-CalendarExt for example. But I’ll use MagicMirror directory instead and try with that.
                                  How about the other question? How can I get month calendar to show 4 weeks instead of 5?
                                    @jani-karna
                                    MMM-CalendarExt was so an early and old module, so it has an improper structure. I’ll deprecate the css in some days.
                                    For your Second Question.
                                    month view could have 4~6 weeks in a table by the days. If you want to fix 4 weeks, use week view instead month
                                      jani.karna
                                      I’m not sure I understood. Is month view possible to set to show 4 weeks? I also changed to week mode but it only shows 3 weeks instead of 4.
                                        @jani-karna
                                        You can set how many weeks to be shown with slotCount in week view.
                                          jani.karna
                                          @Sean
                                          Thank you, that did the job.
                                          Sorry to bother you with one more question: I have 1 scene and 1 view and 3 calendars. All of the calendars are in same week view. I’m trying to have all the 3 calendars to be visible at the same time in week view without rotating between them. I thought this is default with just one scene and one view.
                                            @jani-karna
                                            ??? You mean your calendars are not shown in one week view? As you said, that is the default unless you set separate views.
                                            If all of your events are not shown in a view, it might be maxItems issue. It is limited as max 100 events by default for the performance. In that case, you can set bigger value to maxItems of view.
                                            • 24
                                            • 25
                                            • 4 / 25
