    MMM-GooglePhotos
    294 Posts 56 Posters 381.9k Views 59 Watching
      [[global:former-user]] @gonzonia
      @gonzonia
      well, the error log is saying just network problem. However I’m not in front of machine at this moment, but i’ll check this tomorrow
      • G Offline
        gonzonia
        Thanks. Seems to be working now. Like I said, it starts out that way and then eventually loads fine. The album has about 900 photos I’m showing randomly. Trying to decide if I want them fullscreen or not…
        • G Offline
          gonzonia @Guest
          @Sean It’s weird. I had it working. I went to adjust the settings (sizing didn’t look good) and then it stopped. Getting the network error consistently.
          This is my latest config. I’ve tried various configurations of showWidth/showHeight and originalWidthPx/originalHeightPx
            module: "MMM-GooglePhotos",
              albumId: ["XXX"], // your album id(s) from result of
             refreshInterval: 1000*60,
              scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
              //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
              sort: "random", //'time', 'reverse', 'random'
              showWidth: "800", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
              showHeight: "600",
              originalWidthPx: 1920, // original size of loaded image. (related with image quality)
              originalHeightPx: 1080, // Bigger size gives you better quality, but can give you network burden.
              mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
              //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
            @gonzonia
            There is nothing related to your network issue on this module. (At least, I think so)
            I carefully guess these things;
            1. WLAN sleeping feature might be activated in your RPI.
            2. Your other module or other background process would make this.
            G 2 Replies Last reply Reply Quote 0
            • G Offline
              gonzonia @Guest
              @Sean
              This module is the only one not working. though and you can see in the error I posted earlier it directly references the “photoslibrary.googleapis.com” which is why I suspected this module.
              Currently I’m not running over wifi so it’s not that it’s sleeping.
              I’ll keep trying things and see if I can find something with some consistency. Thanks for checking.
              • G Offline
                gonzonia @Guest
                @Sean I’m starting to think the network error is irrelevant.
                I am seeing the error sometimes not related to googleapis.com. In those cases the CalendarExt2 data isn’t fully loaded, I refresh and all seems good.
                The config below seems to work.
                  position: "fullscreen_below",
                    albumId: ["AD8YTEgKjrQhxAA_30358v4J7I7CXoa1_QIgcebrp1qLcFUvsIU5Hql3wPIvUDesZ72DYwbEhxSz"], // your album id(s) from result of `auth_and_test.js`
                    showWidth: "100%", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                    showHeight: "100%",
                Change to
                showWidth: "800",
                showHeight: "600",
                originalWidthPx: 800,
                originalHeightPx: 600,
                and it doesn’t
                  @gonzonia
                  Hmmmm…
                  With your config (but change albumId - I cannot use your albumId), I can display.
                  Here is mine.
                      sort: "random",
                      showWidth: "800px",
                      showHeight: "600px",
                      mode: "hybrid",
                      albumId: ["AJQR3DjzfO6BkH5eSY1e6Dm3m49QVOmpmXgPy6BOecEwg-f_82H_UJ1v-dvzVIjuezDmb_snettC"],
                    mosheva
                    For some reason noting is showing on the MagicMirror… I’ve pass the Auth test but still nothing is happening…
                    Here’s the test results:
                    Messages : ABzt7NwkIe_XeUgaOezo-5u4fVUn5Gj7xhp1NfzTvGkZPLsd6Lw_99kXfEe1IOXnglPms7POrP4c
                    July 29, 2018 : ABzt7Nx3bEIkcn3tX2FFVXsH2fzQVC4Os0CJhfS61mv6pvZSCXoMZymEaf-eZBBL08Lqw0_1fLSC
                    July 29, 2018 : ABzt7NwUwbPw1vqCOC70DXZ0UuD8ajeummvi6bRvmEDl7TYDqVcQcHT9EfJfZj2St0TunweaEogm
                    July 29, 2018 : ABzt7NzW5C6q_Z7A5tTgnGYkRfCvCb8KWMOYwmUDSPPco8JN9rFDRU-epLrkGyi-OSde2W0T25nB
                    July 29, 2018 : ABzt7NyzrxVgSSQ71mMfiRkgnQ_ZbNL5chnZW49kkWE4reAdfakLBb5NJKz24pEYRH7uKlKIRvEQ
                    July 29, 2018 : ABzt7NwyHnIh7XavY1dbWmsPQqHd34dwJzf0qpGGnZ6GnAiSRAdeooTjkZGPrxHMq0JwNw73AgiK
                    July 29, 2018 : ABzt7NwVG_h0xWe01FlxcIdIzpTE6FoHnhWmOpiZf8lXQXxT-em4UIv_nR9RTbggkEqLuBqsPI4w
                    July 29, 2018 : ABzt7NwAVoSsujJwotfz02G3sYbIFIEXh0aT3JjkeIeHvE_ztZJFFIQt0z9W0gLSQQNT_ZQtThrb
                    July 29, 2018 : ABzt7NxopVxxPrdyilZ3q6OWmDeGEWgdt_KkPEUEYR-ttFS1EFBv37JtPI8E7-JodnNUI7P5N_H_
                    July 29, 2018 : ABzt7NxbTlUlq0jiUBuNVNLLJt5dRYvIscSCRm0XUiJJEhfzrrRiem0OyuD0dj-cXZ9RNc_gsGal
                    July 29, 2018 : ABzt7NzsLXU8kvxF8HZnXCBOVzInUhys3dFh5CEmF8YVgiQhWg8Qdv7LHSmF3pnV_EK–jfGTtTW
                    July 29, 2018 : ABzt7Ny0jW0phJcKPrrCBdmbGKSkAKdXTFFNEAkdiO8apGut1FhIjonLWioEccQrtVSI-490XiPB
                    July 29, 2018 : ABzt7Nz_iEDYQ4YDVE2BovRN3Ow6jDW7b9Ziu0ayQZqe6JKNSLS3UEUtn4O3A2ugn7BsucrBxR34
                    July 29, 2018 : ABzt7NzRGIFYYRr2q7EmGopEiXVyUmV4MS-B0PDdnoC0a5nt2nmr00PgjxAxryOa51kCpRw2bUvQ
                    and here’s my config… (the size is just for testing)
                    module: “MMM-GooglePhotos”,
                    position: “top_left”,
                    albumId: “ABzt7NwkIe_XeUgaOezo-5u4fVUn5Gj7xhp1NfzTvGkZPLsd6Lw_99kXfEe1IOXnglPms7POrP4c”, // your album id(s) from result of auth_and_test.js
                    refreshInterval: 100060,
                    scanInterval: 1000
                    		showWidth: "1001px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                    		showHeight: "1001px",
                    		originalWidthPx: 1001, // original size of loaded image. (related with image quality)
                    		originalHeightPx: 1001, // Bigger size gives you better quality, but can give you network burden.
                    		opacity: 1, // target "opacity" property (https://www.w3schools.com/cssref/css3_pr_opacity.asp)
                    		mode: "contain", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                    Hope you will be able to help me out…
                      [[global:former-user]] @mosheva
                      @mosheva
                      What log says?
                      • G Offline
                        guythnick
                        I would have thought this had been asked, but I could not find it in this thread:
                        Is there any way to set the length of time (speed) the pictures will show for? I am using basically default settings in an album with 217 pictures, and the rate they display is very quick. Sometimes they will pop up several times a second, and then slow back down to around 10 seconds per picture. I would rather set it for 30 or even 60 seconds before it rotates. Is this possible?
                          mrdenmark @guythnick
                          @guythnick
                          Try changing scaninterval and refreshinterval in the config
                          • G Offline
                            guythnick @mrdenmark
                            @mrdenmark
                            My settings are as follows:
                            So, that should be 1 minute and 10 minutes for refresh and scan intervals, respectively. I have tried changing this, and it does not affect the speed at which the individual pictures themselves transition.
                              MisterT
                              Hi @Sean, i have a question about MMM-GooglePhotos. It(s possible to display a lot of google photos locations ?
                              that’s to say i want to display like a mosaic of six google photos on a same page.
                              I try to add for exemple two MMM-google photos on my config.js with differents album paths but only one photo is shown.
                              Have you an idea ?
                                [[global:former-user]] @MisterT
                                @MisterT
                                No, impossible, sorry. It is not designed for that purpose.
                                  rogogu
                                  Hey, first thank you for this great module!
                                  Currently i have about 50 pictures in my google album and set the sorting to random. I think it all works as intendet but it would be nice if the pictures are only shown once until every picture in the album was displayed.
                                  Do you think this is possible? Like assigning a specific number to each photo, putting it in an array when it was displayed and before the next one is shown it checks the array if the next photo was already displayed.
                                  Greetings from Germany
                                  Robert
                                    sdetweil @rogogu
                                    @rogogu I would do it a different way, saves work…
                                    the list is already ramdomized, so the code just walks thru the list.
                                    I would add another parm, refreshAtEnd = true/false(default)
                                    if the parm is true, then do NOT start the timer in node_helper
                                    at refresh on end of list in true, then this.scanPhotos()
                                      rogogu @sdetweil
                                      @sdetweil okay this seems to do the job. but couldn´t this cause problems with the api limit or base url expiring when there are to many/less photos in the album? let´s say there are 100 photos and the refreshInterval is set to 1min. so it takes 100min before it scans the photos again…
                                        sdetweil @rogogu
                                        @rogogu maybe… could be why it refreshes even tho not done
                                        my code gets next image, and if not connected redoes the authentication…
                                        I get the list and then walk the list
                                        but it looks like code tries to handle that
                                          scanPhotos: function() {
                                            this.tempItems = []
                                            var auth = new Auth(this.authConfig)
                                            auth.on('ready', (client) => {
                                              this.accessToken = client.credentials.access_token
                                              this.getPhotos()
                                        • Alex2020A Offline
                                          Alex2020
                                          Mi è comparsa una scritta sul Mirror che è disponibile un aggiornamento del modulo MMM-GooglePhoto come si fa l’aggiornamento?Grazie.
                                            sdetweil @Alex2020
                                            @Alex2020 vai alla cartella del modulo nella finestra del terminale ed emetti, git pull. se il modulo ha un file package.json, eseguire anche ‘npm install’
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
