    MMM-GooglePhotos
    294 Posts 56 Posters 415.8k Views 59 Watching
      mcneilp
      If I have an album with a very large number of photos does it scan all of them? I switched to a small album and it loads nice and fast…but the large one never seems to get a photo. Is this a one time scan (for each time it starts up). Or will it always be super slow.
      Google Photos auto adds photos to albums based on who is in them, so its a shame to not be able to use one of these albums.
      M 1 Reply Last reply
        mcneilp @mcneilp
        @mcneilp If i let it run long enough it loads an image…but sometimes it goes blank for a while. I assume this is because its processing photos. Too bad it can’t just load a few at a time and run fast.
        ? 1 Reply Last reply
          A Former User @mcneilp
          @mcneilp
          Show me your config. And Google Photos has its API request limit for usage.
          • G
            gonzonia
            Sean,
            It seems you make my favorite modules. I’m trying to get the GooglePhotos to work and it does if I leave it long enough. On startup though nothing shows (makes it real hard to configure the appearance). I’m seeing this in the log. Is the album I chose too big? I’m using the config you posted for fullscreen (except I changed to mode: hybrid).
            Error: { Error: Client network socket disconnected before secure TLS connection was established
            at TLSSocket.onConnectEnd (_tls_wrap.js:1092:19)
            at Object.onceWrapper (events.js:273:13)
            at TLSSocket.emit (events.js:187:15)
            at endReadableNT (_stream_readable.js:1090:12)
            at process._tickCallback (internal/process/next_tick.js:63:19)
            code: ‘ECONNRESET’,
            path: null,
            host: ‘photoslibrary.googleapis.com’,
            port: 443,
            localAddress: undefined }
              A Former User @gonzonia
              @gonzonia
              well, the error log is saying just network problem. However I’m not in front of machine at this moment, but i’ll check this tomorrow
              G 1 Reply Last reply
              • G
                gonzonia
                Thanks. Seems to be working now. Like I said, it starts out that way and then eventually loads fine. The album has about 900 photos I’m showing randomly. Trying to decide if I want them fullscreen or not…
                • G
                  gonzonia @Guest
                  @Sean It’s weird. I had it working. I went to adjust the settings (sizing didn’t look good) and then it stopped. Getting the network error consistently.
                  This is my latest config. I’ve tried various configurations of showWidth/showHeight and originalWidthPx/originalHeightPx
                    module: "MMM-GooglePhotos",
                      albumId: ["XXX"], // your album id(s) from result of
                     refreshInterval: 1000*60,
                      scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
                      //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
                      sort: "random", //'time', 'reverse', 'random'
                      showWidth: "800", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                      showHeight: "600",
                      originalWidthPx: 1920, // original size of loaded image. (related with image quality)
                      originalHeightPx: 1080, // Bigger size gives you better quality, but can give you network burden.
                      mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                      //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
                    @gonzonia
                    There is nothing related to your network issue on this module. (At least, I think so)
                    I carefully guess these things;
                    1. WLAN sleeping feature might be activated in your RPI.
                    2. Your other module or other background process would make this.
                    G 2 Replies Last reply
                    • G
                      gonzonia @Guest
                      @Sean
                      This module is the only one not working. though and you can see in the error I posted earlier it directly references the “photoslibrary.googleapis.com” which is why I suspected this module.
                      Currently I’m not running over wifi so it’s not that it’s sleeping.
                      I’ll keep trying things and see if I can find something with some consistency. Thanks for checking.
                      • G
                        gonzonia @Guest
                        @Sean I’m starting to think the network error is irrelevant.
                        I am seeing the error sometimes not related to googleapis.com. In those cases the CalendarExt2 data isn’t fully loaded, I refresh and all seems good.
                        The config below seems to work.
                          position: "fullscreen_below",
                            albumId: ["AD8YTEgKjrQhxAA_30358v4J7I7CXoa1_QIgcebrp1qLcFUvsIU5Hql3wPIvUDesZ72DYwbEhxSz"], // your album id(s) from result of `auth_and_test.js`
                            showWidth: "100%", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                            showHeight: "100%",
                        Change to
                        showWidth: "800",
                        showHeight: "600",
                        originalWidthPx: 800,
                        originalHeightPx: 600,
                        and it doesn’t
                          @gonzonia
                          Hmmmm…
                          With your config (but change albumId - I cannot use your albumId), I can display.
                          Here is mine.
                              sort: "random",
                              showWidth: "800px",
                              showHeight: "600px",
                              mode: "hybrid",
                              albumId: ["AJQR3DjzfO6BkH5eSY1e6Dm3m49QVOmpmXgPy6BOecEwg-f_82H_UJ1v-dvzVIjuezDmb_snettC"],
                            mosheva
                            For some reason noting is showing on the MagicMirror… I’ve pass the Auth test but still nothing is happening…
                            Here’s the test results:
                            Messages : ABzt7NwkIe_XeUgaOezo-5u4fVUn5Gj7xhp1NfzTvGkZPLsd6Lw_99kXfEe1IOXnglPms7POrP4c
                            July 29, 2018 : ABzt7Nx3bEIkcn3tX2FFVXsH2fzQVC4Os0CJhfS61mv6pvZSCXoMZymEaf-eZBBL08Lqw0_1fLSC
                            July 29, 2018 : ABzt7NwUwbPw1vqCOC70DXZ0UuD8ajeummvi6bRvmEDl7TYDqVcQcHT9EfJfZj2St0TunweaEogm
                            July 29, 2018 : ABzt7NzW5C6q_Z7A5tTgnGYkRfCvCb8KWMOYwmUDSPPco8JN9rFDRU-epLrkGyi-OSde2W0T25nB
                            July 29, 2018 : ABzt7NyzrxVgSSQ71mMfiRkgnQ_ZbNL5chnZW49kkWE4reAdfakLBb5NJKz24pEYRH7uKlKIRvEQ
                            July 29, 2018 : ABzt7NwyHnIh7XavY1dbWmsPQqHd34dwJzf0qpGGnZ6GnAiSRAdeooTjkZGPrxHMq0JwNw73AgiK
                            July 29, 2018 : ABzt7NwVG_h0xWe01FlxcIdIzpTE6FoHnhWmOpiZf8lXQXxT-em4UIv_nR9RTbggkEqLuBqsPI4w
                            July 29, 2018 : ABzt7NwAVoSsujJwotfz02G3sYbIFIEXh0aT3JjkeIeHvE_ztZJFFIQt0z9W0gLSQQNT_ZQtThrb
                            July 29, 2018 : ABzt7NxopVxxPrdyilZ3q6OWmDeGEWgdt_KkPEUEYR-ttFS1EFBv37JtPI8E7-JodnNUI7P5N_H_
                            July 29, 2018 : ABzt7NxbTlUlq0jiUBuNVNLLJt5dRYvIscSCRm0XUiJJEhfzrrRiem0OyuD0dj-cXZ9RNc_gsGal
                            July 29, 2018 : ABzt7NzsLXU8kvxF8HZnXCBOVzInUhys3dFh5CEmF8YVgiQhWg8Qdv7LHSmF3pnV_EK–jfGTtTW
                            July 29, 2018 : ABzt7Ny0jW0phJcKPrrCBdmbGKSkAKdXTFFNEAkdiO8apGut1FhIjonLWioEccQrtVSI-490XiPB
                            July 29, 2018 : ABzt7Nz_iEDYQ4YDVE2BovRN3Ow6jDW7b9Ziu0ayQZqe6JKNSLS3UEUtn4O3A2ugn7BsucrBxR34
                            July 29, 2018 : ABzt7NzRGIFYYRr2q7EmGopEiXVyUmV4MS-B0PDdnoC0a5nt2nmr00PgjxAxryOa51kCpRw2bUvQ
                            and here’s my config… (the size is just for testing)
                            module: “MMM-GooglePhotos”,
                            position: “top_left”,
                            albumId: “ABzt7NwkIe_XeUgaOezo-5u4fVUn5Gj7xhp1NfzTvGkZPLsd6Lw_99kXfEe1IOXnglPms7POrP4c”, // your album id(s) from result of auth_and_test.js
                            refreshInterval: 100060,
                            scanInterval: 1000
                            		showWidth: "1001px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                            		showHeight: "1001px",
                            		originalWidthPx: 1001, // original size of loaded image. (related with image quality)
                            		originalHeightPx: 1001, // Bigger size gives you better quality, but can give you network burden.
                            		opacity: 1, // target "opacity" property (https://www.w3schools.com/cssref/css3_pr_opacity.asp)
                            		mode: "contain", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                            Hope you will be able to help me out…
                              A Former User @mosheva
                              @mosheva
                              What log says?
                              • G
                                guythnick
                                I would have thought this had been asked, but I could not find it in this thread:
                                Is there any way to set the length of time (speed) the pictures will show for? I am using basically default settings in an album with 217 pictures, and the rate they display is very quick. Sometimes they will pop up several times a second, and then slow back down to around 10 seconds per picture. I would rather set it for 30 or even 60 seconds before it rotates. Is this possible?
                                  mrdenmark @guythnick
                                  @guythnick
                                  Try changing scaninterval and refreshinterval in the config
                                  • G
                                    guythnick @mrdenmark
                                    @mrdenmark
                                    My settings are as follows:
                                    So, that should be 1 minute and 10 minutes for refresh and scan intervals, respectively. I have tried changing this, and it does not affect the speed at which the individual pictures themselves transition.
                                      MisterT
                                      Hi @Sean, i have a question about MMM-GooglePhotos. It(s possible to display a lot of google photos locations ?
                                      that’s to say i want to display like a mosaic of six google photos on a same page.
                                      I try to add for exemple two MMM-google photos on my config.js with differents album paths but only one photo is shown.
                                      Have you an idea ?
                                        A Former User @MisterT
                                        @MisterT
                                        No, impossible, sorry. It is not designed for that purpose.
                                          rogogu
                                          Hey, first thank you for this great module!
                                          Currently i have about 50 pictures in my google album and set the sorting to random. I think it all works as intendet but it would be nice if the pictures are only shown once until every picture in the album was displayed.
                                          Do you think this is possible? Like assigning a specific number to each photo, putting it in an array when it was displayed and before the next one is shown it checks the array if the next photo was already displayed.
                                          Greetings from Germany
                                          Robert
                                            sdetweil @rogogu
                                            @rogogu I would do it a different way, saves work…
                                            the list is already ramdomized, so the code just walks thru the list.
                                            I would add another parm, refreshAtEnd = true/false(default)
                                            if the parm is true, then do NOT start the timer in node_helper
                                            at refresh on end of list in true, then this.scanPhotos()
                                            R 1 Reply Last reply
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
