    MMM-GooglePhotos
    294 Posts 56 Posters 415.8k Views 59 Watching
      A Former User @gonzonia
      @gonzonia
      There is nothing related to your network issue on this module. (At least, I think so)
      I carefully guess these things;
      1. WLAN sleeping feature might be activated in your RPI.
      2. Your other module or other background process would make this.
      G 2 Replies Last reply
      • G
        gonzonia @Guest
        @Sean
        This module is the only one not working. though and you can see in the error I posted earlier it directly references the “photoslibrary.googleapis.com” which is why I suspected this module.
        Currently I’m not running over wifi so it’s not that it’s sleeping.
        I’ll keep trying things and see if I can find something with some consistency. Thanks for checking.
        • G
          gonzonia @Guest
          @Sean I’m starting to think the network error is irrelevant.
          I am seeing the error sometimes not related to googleapis.com. In those cases the CalendarExt2 data isn’t fully loaded, I refresh and all seems good.
          The config below seems to work.
            module: "MMM-GooglePhotos",
            position: "fullscreen_below",
              albumId: ["AD8YTEgKjrQhxAA_30358v4J7I7CXoa1_QIgcebrp1qLcFUvsIU5Hql3wPIvUDesZ72DYwbEhxSz"], // your album id(s) from result of `auth_and_test.js`
             refreshInterval: 1000*60,
              scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
              //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
              sort: "random", //'time', 'reverse', 'random'
              showWidth: "100%", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
              showHeight: "100%",
              originalWidthPx: 1920, // original size of loaded image. (related with image quality)
              originalHeightPx: 1080, // Bigger size gives you better quality, but can give you network burden.
              mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
              //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
          Change to
          showWidth: "800",
          showHeight: "600",
          originalWidthPx: 800,
          originalHeightPx: 600,
          and it doesn’t
          ? 1 Reply Last reply
            @gonzonia
            Hmmmm…
            With your config (but change albumId - I cannot use your albumId), I can display.
            Here is mine.
                sort: "random",
                showWidth: "800px",
                showHeight: "600px",
                mode: "hybrid",
                albumId: ["AJQR3DjzfO6BkH5eSY1e6Dm3m49QVOmpmXgPy6BOecEwg-f_82H_UJ1v-dvzVIjuezDmb_snettC"],
              mosheva
              For some reason noting is showing on the MagicMirror… I’ve pass the Auth test but still nothing is happening…
              Here’s the test results:
              Messages : ABzt7NwkIe_XeUgaOezo-5u4fVUn5Gj7xhp1NfzTvGkZPLsd6Lw_99kXfEe1IOXnglPms7POrP4c
              July 29, 2018 : ABzt7Nx3bEIkcn3tX2FFVXsH2fzQVC4Os0CJhfS61mv6pvZSCXoMZymEaf-eZBBL08Lqw0_1fLSC
              July 29, 2018 : ABzt7NwUwbPw1vqCOC70DXZ0UuD8ajeummvi6bRvmEDl7TYDqVcQcHT9EfJfZj2St0TunweaEogm
              July 29, 2018 : ABzt7NzW5C6q_Z7A5tTgnGYkRfCvCb8KWMOYwmUDSPPco8JN9rFDRU-epLrkGyi-OSde2W0T25nB
              July 29, 2018 : ABzt7NyzrxVgSSQ71mMfiRkgnQ_ZbNL5chnZW49kkWE4reAdfakLBb5NJKz24pEYRH7uKlKIRvEQ
              July 29, 2018 : ABzt7NwyHnIh7XavY1dbWmsPQqHd34dwJzf0qpGGnZ6GnAiSRAdeooTjkZGPrxHMq0JwNw73AgiK
              July 29, 2018 : ABzt7NwVG_h0xWe01FlxcIdIzpTE6FoHnhWmOpiZf8lXQXxT-em4UIv_nR9RTbggkEqLuBqsPI4w
              July 29, 2018 : ABzt7NwAVoSsujJwotfz02G3sYbIFIEXh0aT3JjkeIeHvE_ztZJFFIQt0z9W0gLSQQNT_ZQtThrb
              July 29, 2018 : ABzt7NxopVxxPrdyilZ3q6OWmDeGEWgdt_KkPEUEYR-ttFS1EFBv37JtPI8E7-JodnNUI7P5N_H_
              July 29, 2018 : ABzt7NxbTlUlq0jiUBuNVNLLJt5dRYvIscSCRm0XUiJJEhfzrrRiem0OyuD0dj-cXZ9RNc_gsGal
              July 29, 2018 : ABzt7NzsLXU8kvxF8HZnXCBOVzInUhys3dFh5CEmF8YVgiQhWg8Qdv7LHSmF3pnV_EK–jfGTtTW
              July 29, 2018 : ABzt7Ny0jW0phJcKPrrCBdmbGKSkAKdXTFFNEAkdiO8apGut1FhIjonLWioEccQrtVSI-490XiPB
              July 29, 2018 : ABzt7Nz_iEDYQ4YDVE2BovRN3Ow6jDW7b9Ziu0ayQZqe6JKNSLS3UEUtn4O3A2ugn7BsucrBxR34
              July 29, 2018 : ABzt7NzRGIFYYRr2q7EmGopEiXVyUmV4MS-B0PDdnoC0a5nt2nmr00PgjxAxryOa51kCpRw2bUvQ
              and here’s my config… (the size is just for testing)
              module: “MMM-GooglePhotos”,
              position: “top_left”,
              albumId: “ABzt7NwkIe_XeUgaOezo-5u4fVUn5Gj7xhp1NfzTvGkZPLsd6Lw_99kXfEe1IOXnglPms7POrP4c”, // your album id(s) from result of auth_and_test.js
              refreshInterval: 100060,
              scanInterval: 1000
              		showWidth: "1001px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
              		showHeight: "1001px",
              		originalWidthPx: 1001, // original size of loaded image. (related with image quality)
              		originalHeightPx: 1001, // Bigger size gives you better quality, but can give you network burden.
              		opacity: 1, // target "opacity" property (https://www.w3schools.com/cssref/css3_pr_opacity.asp)
              		mode: "contain", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
              Hope you will be able to help me out…
                A Former User @mosheva
                @mosheva
                What log says?
                • G
                  guythnick
                  I would have thought this had been asked, but I could not find it in this thread:
                  Is there any way to set the length of time (speed) the pictures will show for? I am using basically default settings in an album with 217 pictures, and the rate they display is very quick. Sometimes they will pop up several times a second, and then slow back down to around 10 seconds per picture. I would rather set it for 30 or even 60 seconds before it rotates. Is this possible?
                  M 1 Reply Last reply
                    mrdenmark @guythnick
                    @guythnick
                    Try changing scaninterval and refreshinterval in the config
                    G 1 Reply Last reply
                    • G
                      guythnick @mrdenmark
                      @mrdenmark
                      My settings are as follows:
                      So, that should be 1 minute and 10 minutes for refresh and scan intervals, respectively. I have tried changing this, and it does not affect the speed at which the individual pictures themselves transition.
                        MisterT
                        Hi @Sean, i have a question about MMM-GooglePhotos. It(s possible to display a lot of google photos locations ?
                        that’s to say i want to display like a mosaic of six google photos on a same page.
                        I try to add for exemple two MMM-google photos on my config.js with differents album paths but only one photo is shown.
                        Have you an idea ?
                          A Former User @MisterT
                          @MisterT
                          No, impossible, sorry. It is not designed for that purpose.
                            rogogu
                            Hey, first thank you for this great module!
                            Currently i have about 50 pictures in my google album and set the sorting to random. I think it all works as intendet but it would be nice if the pictures are only shown once until every picture in the album was displayed.
                            Do you think this is possible? Like assigning a specific number to each photo, putting it in an array when it was displayed and before the next one is shown it checks the array if the next photo was already displayed.
                            Greetings from Germany
                            Robert
                              sdetweil @rogogu
                              @rogogu I would do it a different way, saves work…
                              the list is already ramdomized, so the code just walks thru the list.
                              I would add another parm, refreshAtEnd = true/false(default)
                              if the parm is true, then do NOT start the timer in node_helper
                              at refresh on end of list in true, then this.scanPhotos()
                              R 1 Reply Last reply
                                rogogu @sdetweil
                                @sdetweil okay this seems to do the job. but couldn´t this cause problems with the api limit or base url expiring when there are to many/less photos in the album? let´s say there are 100 photos and the refreshInterval is set to 1min. so it takes 100min before it scans the photos again…
                                  sdetweil @rogogu
                                  @rogogu maybe… could be why it refreshes even tho not done
                                  my code gets next image, and if not connected redoes the authentication…
                                  I get the list and then walk the list
                                  but it looks like code tries to handle that
                                    scanPhotos: function() {
                                      this.tempItems = []
                                      var auth = new Auth(this.authConfig)
                                      auth.on('ready', (client) => {
                                        this.accessToken = client.credentials.access_token
                                        this.getPhotos()
                                  • Alex2020A
                                    Alex2020
                                    Mi è comparsa una scritta sul Mirror che è disponibile un aggiornamento del modulo MMM-GooglePhoto come si fa l’aggiornamento?Grazie.
                                      sdetweil @Alex2020
                                      @Alex2020 vai alla cartella del modulo nella finestra del terminale ed emetti, git pull. se il modulo ha un file package.json, eseguire anche ‘npm install’
                                      • Alex2020A
                                        Alex2020
                                        Salve mi compare un messaggio sul Mirror che ce una versione più recente come si aggiorna il modulo MMM-GooglePhotos ,come si fa l’aggiornamento?Grazie.
                                          Samwise
                                          my auth_and_test is not working. it worked like a year ago, but I haven’t used it since. I’m really new and don’t really know what I’m doing. this is what i get:
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
                                          (node:698) UnhandledPromiseRejectionWarning: Error: invalid_grant
                                          at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)
                                          at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:18:12)
                                          at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:201:11)
                                          at IncomingMessage.emit (events.js:198:15)
                                          at endReadableNT (_stream_readable.js:1139:12)
                                          at processTicksAndRejections (internal/process/task_queues.js:81:17)
                                          (node:698) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                                          (node:698) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                          Any suggestions?
                                          S ? 2 Replies Last reply
                                            sdetweil @Samwise
                                            @Samwise usually means the authentication code has expired.
                                            • 10
                                            • 14
                                            • 15
                                            • 8 / 15
