    Hi, there is a new Alexa Module
    98 Posts 13 Posters 79.8k Views 15 Watching
      pumpy266 @Stoffbeuteluwe
      Yes of course.
      First of all, does your mirror program actually start?
      If so, please run it.
      Now ask Alexa to discover new devices.
      Does it find anything?
      If it does, ask Alexa to “Turn on Page 1”
      What happens?
      In the meantime I will check my config against yours.
      Please post back the results of the above.
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @pumpy266
        @pumpy266 when I have MMM-AlexaControl in my config the screen stays black
          Yes, I understand that.
          Can Alexa find any devices?
            @pumpy266 no device’s found
              OK, try this please. Edit your config.js file to look like this:
                          module: 'MMM-pages',
                          modules:
                              [[ "weatherforecast", "newsfeed"],
                               [ "calendar", "compliments"]],
                          fixed: ["MMM-page-indicator"],
                          rotationTime:"0",
                          module: 'MMM-AlexaControl',
                          position: 'middle_center',
                          config:{
                          image: true,
                          pm2ProcessName: "mm",
                          vcgencmd: true,
                          pages:'2',
              Then put your WeatherForecast, newsfeed, calendar and compliments modules as per usual underneath this lot.
              Save the config, start MagicMirror (correcting any typos from the above) and ask Alexa to discover new devices.
                @pumpy266 i have copied your config but only black screen
                I can try what I want but still the same problem,
                my config don’t work with MMM-AlexaControl
                i have a Mac mini but normally that should be no problem
                  And does Alexa find anything?
                  StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                    @pumpy266 now config works …
                    i have done something wrong with installation
                    but no devices found
                      @pumpy266
                      now I have it …my devices where found
                      thank you very much for your help…
                      thank you thank you thank you
                      P FoziF 2 Replies Last reply Reply Quote 0
                        Hooray! :-) :-)
                        You may want to change the rotation time in the MMM-pages module, depending on what you want.
                        Great it’s worked for you.
                          @pumpy266
                          can you help me change the image size in css
                          I need a smaller size
                            For which module(s)?
                            What is the resolution of the monitor you are using?
                            Won’t be able to post a reply tonight as I currently have a broken limb and moving takes slightly longer than usual.
                            But post the details and I’ll take a look in the morning.
                              @pumpy266 I want to make the Alexa image from the MMM-AlexaControl module smaller in CSS but I don’t know how.
                              I have copied the css from the Module to my custom css and tried to change the size but nothing’s happened.
                                The logo doesn’t appear on mine at all, think it did once.
                                So try restarting the mirror or disabling it with image: false in the config.
                                As a guess, try adding this to the custom.css:
                                .module.MMM-AlexaControl{
                                .img{
                                height: 60;
                                width: 60;
                                There is a whole sub-forum on CSS, which I haven’t read.
                                Anyway, give the above a go and let us know what happens.
                                If no joy, please post the whole of your custom.css here.
                                  @pumpy266 Thank you for your help …:grinning_face: I will try tonight
                                  • FoziF Offline
                                    Fozi Project Sponsor @Stoffbeuteluwe
                                    @Stoffbeuteluwe I‘m struggling to make Alexa find my mirror as a new device. Can you explain shortly how you succeed?
                                    Thanks in advance,
                                    Fozi
                                      Stoffbeuteluwe Project Sponsor @Fozi
                                      @Fozi Install:
                                      MMM-Pages
                                      MMM-page-indicator
                                      MMM-AlexaControl
                                      than add the config post from @pumpy266 to your config and that’s it…
                                      Alexa discover devices…
                                      • FoziF Offline
                                        @Stoffbeuteluwe ok, I‘ll give it a try later this evening.
                                        Thanks,
                                        Fozi
                                          @pumpy266 now it works I forgot …px …for pixel
                                          thanks for helping :folded_hands_light_skin_tone:
                                          • T Offline
                                            tanvir586
                                            To use this module do i need an alexa device? Or it works with alexaPi/awesomealexa?
                                            • 1 / 5
