    Hi, there is a new Alexa Module
    98 Posts 13 Posters 75.0k Views 15 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @pumpy266
      @pumpy266
                  module: 'MMM-AlexaControl',
                  position: 'middle_center',
                  config:{
                  image: true,
                  pm2ProcessName: "mm",
                  vcgencmd: true,
                  notifications: [
                 port: 11101,
                 OnOff: true,
                 notification: [["NOTIFICATION ON", "PAYLOAD"],["NOTIFICATION OFF", "PAYLOAD"]]
                  module: 'MMM-pages',
                  modules:
                          [[ "weatherforecast", "newsfeed"],
                           [ "calendar", "compliments" ]],
                  fixed:   ["MMM-page-indicator"],
                 module: 'MMM-page-indicator',
                 position: 'bottom_bar',
                 pages: 2,
      can you help me …?
      i am a little bit confused with all this
        pumpy266 @Stoffbeuteluwe
        Yes of course.
        First of all, does your mirror program actually start?
        If so, please run it.
        Now ask Alexa to discover new devices.
        Does it find anything?
        If it does, ask Alexa to “Turn on Page 1”
        What happens?
        In the meantime I will check my config against yours.
        Please post back the results of the above.
          @pumpy266 when I have MMM-AlexaControl in my config the screen stays black
            Yes, I understand that.
            Can Alexa find any devices?
              @pumpy266 no device’s found
                OK, try this please. Edit your config.js file to look like this:
                            modules:
                                 [ "calendar", "compliments"]],
                            rotationTime:"0",
                            config:{
                            image: true,
                            vcgencmd: true,
                            pages:'2',
                Then put your WeatherForecast, newsfeed, calendar and compliments modules as per usual underneath this lot.
                Save the config, start MagicMirror (correcting any typos from the above) and ask Alexa to discover new devices.
                  @pumpy266 i have copied your config but only black screen
                  I can try what I want but still the same problem,
                  my config don’t work with MMM-AlexaControl
                  i have a Mac mini but normally that should be no problem
                    And does Alexa find anything?
                    StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                      @pumpy266 now config works …
                      i have done something wrong with installation
                      but no devices found
                        @pumpy266
                        now I have it …my devices where found
                        thank you very much for your help…
                        thank you thank you thank you
                        P FoziF 2 Replies Last reply Reply Quote 0
                          Hooray! :-) :-)
                          You may want to change the rotation time in the MMM-pages module, depending on what you want.
                          Great it’s worked for you.
                            @pumpy266
                            can you help me change the image size in css
                            I need a smaller size
                              For which module(s)?
                              What is the resolution of the monitor you are using?
                              Won’t be able to post a reply tonight as I currently have a broken limb and moving takes slightly longer than usual.
                              But post the details and I’ll take a look in the morning.
                                @pumpy266 I want to make the Alexa image from the MMM-AlexaControl module smaller in CSS but I don’t know how.
                                I have copied the css from the Module to my custom css and tried to change the size but nothing’s happened.
                                  The logo doesn’t appear on mine at all, think it did once.
                                  So try restarting the mirror or disabling it with image: false in the config.
                                  As a guess, try adding this to the custom.css:
                                  .module.MMM-AlexaControl{
                                  .img{
                                  height: 60;
                                  width: 60;
                                  There is a whole sub-forum on CSS, which I haven’t read.
                                  Anyway, give the above a go and let us know what happens.
                                  If no joy, please post the whole of your custom.css here.
                                    @pumpy266 Thank you for your help …:grinning_face: I will try tonight
                                    • FoziF Offline
                                      Fozi Project Sponsor @Stoffbeuteluwe
                                      @Stoffbeuteluwe I‘m struggling to make Alexa find my mirror as a new device. Can you explain shortly how you succeed?
                                      Thanks in advance,
                                      Fozi
                                        Stoffbeuteluwe Project Sponsor @Fozi
                                        @Fozi Install:
                                        MMM-Pages
                                        MMM-page-indicator
                                        MMM-AlexaControl
                                        than add the config post from @pumpy266 to your config and that’s it…
                                        Alexa discover devices…
                                        • FoziF Offline
                                          @Stoffbeuteluwe ok, I‘ll give it a try later this evening.
                                          Thanks,
                                          Fozi
                                            @pumpy266 now it works I forgot …px …for pixel
                                            thanks for helping :folded_hands_light_skin_tone:
                                            • 1 / 5
