    Hi, there is a new Alexa Module
    98 Posts 13 Posters 82.6k Views 15 Watching
      pumpy266 @Stoffbeuteluwe
      OK, try this please. Edit your config.js file to look like this:
                  module: 'MMM-pages',
                  modules:
                      [[ "weatherforecast", "newsfeed"],
                       [ "calendar", "compliments"]],
                  fixed: ["MMM-page-indicator"],
                  rotationTime:"0",
                  module: 'MMM-AlexaControl',
                  position: 'middle_center',
                  config:{
                  image: true,
                  pm2ProcessName: "mm",
                  vcgencmd: true,
                  pages:'2',
      Then put your WeatherForecast, newsfeed, calendar and compliments modules as per usual underneath this lot.
      Save the config, start MagicMirror (correcting any typos from the above) and ask Alexa to discover new devices.
      StoffbeuteluweS 1 Reply Last reply
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @pumpy266
        @pumpy266 i have copied your config but only black screen
        I can try what I want but still the same problem,
        my config don’t work with MMM-AlexaControl
        i have a Mac mini but normally that should be no problem
        P 1 Reply Last reply
          And does Alexa find anything?
          StoffbeuteluweS 2 Replies Last reply
          • StoffbeuteluweS
            @pumpy266 now config works …
            i have done something wrong with installation
            but no devices found
            • StoffbeuteluweS
              @pumpy266
              now I have it …my devices where found
              thank you very much for your help…
              thank you thank you thank you
              P FoziF 2 Replies Last reply
                Hooray! :-) :-)
                You may want to change the rotation time in the MMM-pages module, depending on what you want.
                Great it’s worked for you.
                • StoffbeuteluweS
                  @pumpy266
                  can you help me change the image size in css
                  I need a smaller size
                    For which module(s)?
                    What is the resolution of the monitor you are using?
                    Won’t be able to post a reply tonight as I currently have a broken limb and moving takes slightly longer than usual.
                    But post the details and I’ll take a look in the morning.
                    • StoffbeuteluweS
                      @pumpy266 I want to make the Alexa image from the MMM-AlexaControl module smaller in CSS but I don’t know how.
                      I have copied the css from the Module to my custom css and tried to change the size but nothing’s happened.
                        The logo doesn’t appear on mine at all, think it did once.
                        So try restarting the mirror or disabling it with image: false in the config.
                        As a guess, try adding this to the custom.css:
                        .module.MMM-AlexaControl{
                        .img{
                        height: 60;
                        width: 60;
                        There is a whole sub-forum on CSS, which I haven’t read.
                        Anyway, give the above a go and let us know what happens.
                        If no joy, please post the whole of your custom.css here.
                        • StoffbeuteluweS
                          @pumpy266 Thank you for your help …:grinning_face: I will try tonight
                          • FoziF
                            Fozi Project Sponsor @Stoffbeuteluwe
                            @Stoffbeuteluwe I‘m struggling to make Alexa find my mirror as a new device. Can you explain shortly how you succeed?
                            Thanks in advance,
                            Fozi
                            • StoffbeuteluweS
                              Stoffbeuteluwe Project Sponsor @Fozi
                              @Fozi Install:
                              MMM-Pages
                              MMM-page-indicator
                              MMM-AlexaControl
                              than add the config post from @pumpy266 to your config and that’s it…
                              Alexa discover devices…
                              FoziF 1 Reply Last reply
                              • FoziF
                                @Stoffbeuteluwe ok, I‘ll give it a try later this evening.
                                Thanks,
                                Fozi
                                • StoffbeuteluweS
                                  @pumpy266 now it works I forgot …px …for pixel
                                  thanks for helping :folded_hands_light_skin_tone:
                                  • T
                                    tanvir586
                                    To use this module do i need an alexa device? Or it works with alexaPi/awesomealexa?
                                      pumpy266
                                      I’m using a ‘real’ Alexa.
                                      Why not try it and let us all know?
                                      You can always uninstall it if it doesn’t work.
                                      Great that the image is how you wanted it.
                                        BD0G
                                        Similar situation here. Magic Mirror works and modules load on screen and then MMM-Pages takes over and switches to Page 1 as denoted by the circles at the bottom of the page. The screen does not display the modules after that.
                                        Installed MMM-AlexaControl
                                        MMM-Pages
                                        MMM-page-indicator
                                        Modified my config.js and checked it with npm run config:check.
                                        No syntax errors
                                        Alexa fails to find any new devices when using discovery through Alexa App or voice request “Alexa discover new devices” - Reports no new devices found. Same with app.
                                        Here are the relevant entries from my config.js
                                        			position: 'bottom_left',
                                        			config:{
                                        				image: true,
                                        				pm2ProcessName: "PM2",
                                        				vcgencmd: true,
                                        				pages:'3',
                                                    modules:
                                                        [[ "DarkSkyForecastforecast", "Lunartic"],
                                                         [ "DumpsterDay", "clock","calendar","updatenotification"]],
                                                    rotationTime:"0",
                                                module: 'MMM-page-indicator',
                                                position: 'bottom_bar',
                                                    pages: 3,
                                        FoziF StoffbeuteluweS 2 Replies Last reply
                                        • FoziF
                                          Fozi Project Sponsor @BD0G
                                          I have only MMM-AlexaControl installed, without Pages, as I want to control the Podcast2 module. But also here, the discovery of the mirror fails, as well in the Alexa app as by asking my Echo Dot to discover new devices. My config is the same as already provided here, just without the pages statement. I also changed the startport and switched of the 5GHz band on my routers, but no success. Am I missing something obvious but essential?
                                          • StoffbeuteluweS
                                            Stoffbeuteluwe Project Sponsor @BD0G
                                            @BD0G you have 2 Pages Not 3
                                            please change in config and try again
                                            B 1 Reply Last reply
                                            • 2 / 5
