    Hi, there is a new Alexa Module
    98 Posts 13 Posters 76.5k Views 15 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @pumpy266
      @pumpy266 when I have MMM-AlexaControl in my config the screen stays black
        pumpy266 @Stoffbeuteluwe
        Yes, I understand that.
        Can Alexa find any devices?
          @pumpy266 no device’s found
            OK, try this please. Edit your config.js file to look like this:
                        module: 'MMM-pages',
                        modules:
                            [[ "weatherforecast", "newsfeed"],
                             [ "calendar", "compliments"]],
                        fixed: ["MMM-page-indicator"],
                        rotationTime:"0",
                        module: 'MMM-AlexaControl',
                        position: 'middle_center',
                        config:{
                        image: true,
                        pm2ProcessName: "mm",
                        vcgencmd: true,
                        pages:'2',
            Then put your WeatherForecast, newsfeed, calendar and compliments modules as per usual underneath this lot.
            Save the config, start MagicMirror (correcting any typos from the above) and ask Alexa to discover new devices.
              @pumpy266 i have copied your config but only black screen
              I can try what I want but still the same problem,
              my config don’t work with MMM-AlexaControl
              i have a Mac mini but normally that should be no problem
                And does Alexa find anything?
                StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                  @pumpy266 now config works …
                  i have done something wrong with installation
                  but no devices found
                    @pumpy266
                    now I have it …my devices where found
                    thank you very much for your help…
                    thank you thank you thank you
                    P FoziF 2 Replies Last reply Reply Quote 0
                      Hooray! :-) :-)
                      You may want to change the rotation time in the MMM-pages module, depending on what you want.
                      Great it’s worked for you.
                        @pumpy266
                        can you help me change the image size in css
                        I need a smaller size
                          For which module(s)?
                          What is the resolution of the monitor you are using?
                          Won’t be able to post a reply tonight as I currently have a broken limb and moving takes slightly longer than usual.
                          But post the details and I’ll take a look in the morning.
                            @pumpy266 I want to make the Alexa image from the MMM-AlexaControl module smaller in CSS but I don’t know how.
                            I have copied the css from the Module to my custom css and tried to change the size but nothing’s happened.
                              The logo doesn’t appear on mine at all, think it did once.
                              So try restarting the mirror or disabling it with image: false in the config.
                              As a guess, try adding this to the custom.css:
                              .module.MMM-AlexaControl{
                              .img{
                              height: 60;
                              width: 60;
                              There is a whole sub-forum on CSS, which I haven’t read.
                              Anyway, give the above a go and let us know what happens.
                              If no joy, please post the whole of your custom.css here.
                                @pumpy266 Thank you for your help …:grinning_face: I will try tonight
                                • FoziF Offline
                                  Fozi Project Sponsor @Stoffbeuteluwe
                                  @Stoffbeuteluwe I‘m struggling to make Alexa find my mirror as a new device. Can you explain shortly how you succeed?
                                  Thanks in advance,
                                  Fozi
                                    Stoffbeuteluwe Project Sponsor @Fozi
                                    @Fozi Install:
                                    MMM-Pages
                                    MMM-page-indicator
                                    MMM-AlexaControl
                                    than add the config post from @pumpy266 to your config and that’s it…
                                    Alexa discover devices…
                                    • FoziF Offline
                                      @Stoffbeuteluwe ok, I‘ll give it a try later this evening.
                                      Thanks,
                                      Fozi
                                        @pumpy266 now it works I forgot …px …for pixel
                                        thanks for helping :folded_hands_light_skin_tone:
                                        • T Offline
                                          tanvir586
                                          To use this module do i need an alexa device? Or it works with alexaPi/awesomealexa?
                                            pumpy266
                                            I’m using a ‘real’ Alexa.
                                            Why not try it and let us all know?
                                            You can always uninstall it if it doesn’t work.
                                            Great that the image is how you wanted it.
                                            • 1 / 5
