    Please help me...........
    19 Posts 4 Posters 4.6k Views 4 Watching
      daegon-jjiya @lavolp3
      @lavolp3
      Ignored the error and finished the installation. However, after running the Magic Mirror, I want to test it, but as soon as the voice recognition function is turned on, it pops out and the following message appears.
      magicmirror@2.9.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.9.0
      Loading config …
      Loading module helpers …
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-AssistantMk2
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Starting module: newsfeed
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Connecting socket for: MMM-AssistantMk2
      Sockets connected & modules started …
      Launching application.
      Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
      [AMK2] Recipe is loaded: reboot.js
      [AMK2] Recipe is loaded: screen_onoff.js
      [AMK2] Recipe is loaded: shutdown.js
      [AMK2] Temporal storage directory is clearing.
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
      [HOTWORD] stops.
      [HOTWORD] Final Result: { detected: false }
      [HOTWORD] begins.
      [AMK2] assistant ready
      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.9.0 start: sh run-start.sh
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.9.0 start script.
      npm ERR! /home/pi/.npm/_logs/2019-11-14T03_53_11_525Z-debug.log
      I tried translating but it doesn’t make sense. If you know how, please answer.
        sdetweil @daegon-jjiya
        @daegon-jjiya said in Please help me...........:
        __atomic_store_8
        see this reply for the steps to recover… one of the libraries that module uses has a bug
        https://forum.magicmirror.builders/topic/11430/error-when-trying-to-run-mmm-assistantmk2/5
        D 2 Replies Last reply
          daegon-jjiya @sdetweil
          @sdetweil Thank you for answer. We are going to the link you tell us.
            I tried using the link above, but when I ran Red text and Magic Mirror, the following characters were displayed and the Magic Mirror screen did not appear.
            pi@raspberrypi:~ $ cd MagicMirror
            sh run-start.sh
            Loading config …
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
            Expected directory: electron-v3.0-linux-arm-glibc
            Found: [node-v64-linux-arm-glibc]
            This problem can often be fixed by running “npm rebuild” on the current system
            Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node’
            App threw an error during load
            at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
            at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:64:3)
            at Module._compile (internal/modules/cjs/loader.js:711:30)
            at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
            at Module.load (internal/modules/cjs/loader.js:620:32)
            at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
            at Function.Module._load (internal/modules/cjs/loader.js:551:3)
            at Module.require (internal/modules/cjs/loader.js:658:17)
            at require (internal/modules/cjs/helpers.js:20:18)
            at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
            Whoops! There was an uncaught exception…
            { Error: Failed to load gRPC binary module because it was not installed for the current system
            at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: ‘MODULE_NOT_FOUND’ }
            Shutting down server…
            Stopping module helper: updatenotification
            Stopping module helper: calendar
            Stopping module helper: newsfeed
            Stopping module helper: MMM-Hotword
            I think you need to know the order in order to follow the link mentioned above.
            If you have time, can you easily arrange the order of installing Magic Mirror MMM-HOTWARD and MMM-AssistantMK2?
            For the first time, it’s all new and hard But I want to finish it.
            You can only imitate while watching YouTube videos. But I want to give me and my children a new experience.
            please …
            • raspberry pi 3+
            • Raspbian Buster with desktop and recommended software 2019-09-26
            • Work directly on the board rather than remotely
            • The above specification is the environment I am working on.
            S Mykle1M 2 Replies Last reply
              @daegon-jjiya
              did you do this step
              npm rebuild
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @daegon-jjiya
                @daegon-jjiya
                Please read this. Many thanks.
                https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                  @sdetweil Only black screen appears. T,.T
                  D 1 Reply Last reply
                    daegon-jjiya @daegon-jjiya
                    @daegon-jjiya
                    thank you
                      Complete with lots of text and the same black screen appears.
                      > sh run-start.sh
                      Loading config ...
                      Loading module helpers ...
                      This problem can often be fixed by running "npm rebuild" on the current system
                      Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node'
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:64:3)
                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: 'MODULE_NOT_FOUND' }
                      Shutting down server...
                      It repeats even if you start from the beginning.
                      I’ll install it from the beginning though. Please let me know some notes during installation
                      Sorry and thank you
                        @daegon-jjiya sorry,I think we will have to wait for @Sean to help. He is the module author.
