    Please help me...........
    19 Posts 4 Posters 3.8k Views 4 Watching
      daegon-jjiya @sdetweil
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
      $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
      $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
      $$$$$$ $$ | _
      $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
      $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
      $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
      _
      | _
      | _
      | _
      $$ |_| _
      |_| _|_|_| __| _
      / _| _______|
      _
      ____/
      Updating packages …
      기존:1 http://archive.raspberrypi.org/debian buster InRelease
      받기:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
      받기:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
      내려받기 12.8 M바이트, 소요시간 36초 (352 k바이트/초)
      패키지 목록을 읽는 중입니다… 완료
      Installing helper tools …
      패키지 목록을 읽는 중입니다… 완료
      의존성 트리를 만드는 중입니다
      상태 정보를 읽는 중입니다… 완료
      build-essential is already the newest version (12.6).
      curl is already the newest version (7.64.0-4).
      git is already the newest version (1:2.20.1-2).
      unzip is already the newest version (6.0-23+deb10u1).
      wget is already the newest version (1.20.1-1.1).
      0개 업그레이드, 0개 새로 설치, 0개 제거 및 71개 업그레이드 안 함.
      Check current Node installation …
      Minimum Node version: v5.1.0
      Installed Node version: v10.15.2
      No Node.js upgrade necessary.
      Check current NPM installation …
      Minimum npm version: V6.0.0
      Installed npm version: V6.13.0
      No npm upgrade necessary.
      Cloning MagicMirror …
      'MagicMirror’에 복제합니다…
      remote: Enumerating objects: 331, done.
      remote: Counting objects: 100% (331/331), done.
      remote: Compressing objects: 100% (295/295), done.
      remote: Total 331 (delta 40), reused 198 (delta 22), pack-reused 0
      오브젝트를 받는 중: 100% (331/331), 662.32 KiB | 785.00 KiB/s, 완료.
      델타를 알아내는 중: 100% (40/40), 완료.
      Cloning MagicMirror Done!
      Installing dependencies …
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
      electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
      node ./download-chromedriver.js
      successfully dowloaded and extracted!
      electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
      node install.js
      Downloading tmp-5191-1-SHASUMS256.txt-3.0.13
      [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
      magicmirror@2.9.0 install /home/pi/MagicMirror
      cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
      added 82 packages from 57 contributors and audited 220 packages in 23.801s
      magicmirror@2.9.0 postinstall /home/pi/MagicMirror
      sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
      We’ll remove from the repository the css/custom.css
      This script apply git update-index --skip-worktree css/custom.css
      rm ‘css/custom.css’
      MagicMirror installation successful!
      magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
      cd fonts && npm install
      added 1 package from 1 contributor and audited 1 package in 7.296s
      npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
      added 1062 packages from 1314 contributors and audited 3479 packages in 369.335s
      7 packages are looking for funding.
      Run “npm fund” to find out more.
      Dependencies installation Done!
      Check plymouth installation …
      Splashscreen: Checking themes directory.
      Splashscreen: Create theme directory if not exists.
      Splashscreen: Theme copied successfully.
      Splashscreen: Changed theme to MagicMirror successfully.
      Do you want use pm2 for auto starting of your MagicMirror (y/N)?n
      Do you want to disable the screen saver? (y/N)?y
      We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
      The screen is dark or flickers even if the magic mirror is triggered by npm war.
      Can I ignore it and move on to the next step?
        daegon-jjiya @lavolp3
        @lavolp3 Yes, but no picture or flickers
        S lavolp3L 2 Replies Last reply Reply Quote 0
          sdetweil @daegon-jjiya
          @daegon-jjiya sounds like a bad hdmi cable
          • lavolp3L Offline
            lavolp3 Module Developer @daegon-jjiya
            @daegon-jjiya the installation was successful. From the software side you don’t have any errors yet (only “warnings” from npm that can be ignored for now).
            Flickering screen sounds like a hardware problem. How is your monitor connected?
            Run
            as described and let us know what happens.
            If it’s only a black screen after a minute or so run
            npm start dev
            and let us know if there are errors coming up in your console.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              @lavolp3
              Ignored the error and finished the installation. However, after running the Magic Mirror, I want to test it, but as soon as the voice recognition function is turned on, it pops out and the following message appears.
              magicmirror@2.9.0 start /home/pi/MagicMirror
              sh run-start.sh
              Starting MagicMirror: v2.9.0
              Loading config …
              Loading module helpers …
              Module helper loaded: MMM-Hotword
              Module helper loaded: MMM-AssistantMk2
              All module helpers loaded.
              Starting server on port 8080 …
              Server started …
              Starting module: newsfeed
              Connecting socket for: MMM-Hotword
              [HOTWORD] MMM-Hotword starts
              Connecting socket for: MMM-AssistantMk2
              Sockets connected & modules started …
              Launching application.
              Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
              Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              [AMK2] Recipe is loaded: hide_and_show_all_modules.js
              [AMK2] Recipe is loaded: reboot.js
              [AMK2] Recipe is loaded: screen_onoff.js
              [AMK2] Recipe is loaded: shutdown.js
              [AMK2] Temporal storage directory is clearing.
              [HOTWORD] begins.
              [HOTWORD] Detector starts listening.
              [HOTWORD] stops.
              [HOTWORD] Final Result: { detected: false }
              [HOTWORD] begins.
              [AMK2] assistant ready
              /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
              npm ERR! code ELIFECYCLE
              npm ERR! syscall spawn
              npm ERR! file sh
              npm ERR! errno ENOENT
              npm ERR! magicmirror@2.9.0 start: sh run-start.sh
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.9.0 start script.
              npm ERR! /home/pi/.npm/_logs/2019-11-14T03_53_11_525Z-debug.log
              I tried translating but it doesn’t make sense. If you know how, please answer.
                @daegon-jjiya said in Please help me...........:
                __atomic_store_8
                see this reply for the steps to recover… one of the libraries that module uses has a bug
                https://forum.magicmirror.builders/topic/11430/error-when-trying-to-run-mmm-assistantmk2/5
                  @sdetweil Thank you for answer. We are going to the link you tell us.
                    I tried using the link above, but when I ran Red text and Magic Mirror, the following characters were displayed and the Magic Mirror screen did not appear.
                    pi@raspberrypi:~ $ cd MagicMirror
                    sh run-start.sh
                    Loading config …
                    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                    Expected directory: electron-v3.0-linux-arm-glibc
                    Found: [node-v64-linux-arm-glibc]
                    This problem can often be fixed by running “npm rebuild” on the current system
                    Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node’
                    App threw an error during load
                    at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                    at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:64:3)
                    at Module._compile (internal/modules/cjs/loader.js:711:30)
                    at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                    at Module.load (internal/modules/cjs/loader.js:620:32)
                    at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                    at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                    at Module.require (internal/modules/cjs/loader.js:658:17)
                    at require (internal/modules/cjs/helpers.js:20:18)
                    at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
                    Whoops! There was an uncaught exception…
                    { Error: Failed to load gRPC binary module because it was not installed for the current system
                    at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: ‘MODULE_NOT_FOUND’ }
                    Shutting down server…
                    Stopping module helper: updatenotification
                    Stopping module helper: calendar
                    Stopping module helper: newsfeed
                    Stopping module helper: MMM-Hotword
                    I think you need to know the order in order to follow the link mentioned above.
                    If you have time, can you easily arrange the order of installing Magic Mirror MMM-HOTWARD and MMM-AssistantMK2?
                    For the first time, it’s all new and hard But I want to finish it.
                    You can only imitate while watching YouTube videos. But I want to give me and my children a new experience.
                    please …
                    • raspberry pi 3+
                    • Raspbian Buster with desktop and recommended software 2019-09-26
                    • Work directly on the board rather than remotely
                    • The above specification is the environment I am working on.
                    S Mykle1M 2 Replies Last reply Reply Quote 0
                      @daegon-jjiya
                      did you do this step
                      npm rebuild
                        Mykle1 Project Sponsor Module Developer @daegon-jjiya
                        @daegon-jjiya
                        Please read this. Many thanks.
                        https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
