    Please help me...........
    19 Posts 4 Posters 3.8k Views 4 Watching
      sdetweil @daegon-jjiya
      @daegon-jjiya
      what happens?
      maybe try the udpated installer
      https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
      you will have to erase the MagicMirror folder to start over
      cd ~
      rm -rf MagicMirror
        daegon-jjiya @sdetweil
        Thanks for the answer, but only the error indication for the same problem
          @daegon-jjiya can u show me the contents of ~/install.log please
          • lavolp3L Offline
            lavolp3 Module Developer
            @daegon-jjiya sorry i cant find the Error in your post. Seems the mirror had been installed successfully.
            Have you fully followed the described procedure in the readme?
            Have you tried to actually run it?
            cd MagicMirror && npm start
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              pi@raspberrypi:~ $
              pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
              $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
              $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
              $$$$$$ $$ | _
              $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
              $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
              $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
              _
              | _
              | _
              | _
              $$ |_| _
              |_| _|_|_| __| _
              / _| _______|
              _
              ____/
              Updating packages …
              기존:1 http://archive.raspberrypi.org/debian buster InRelease
              받기:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
              받기:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
              내려받기 12.8 M바이트, 소요시간 36초 (352 k바이트/초)
              패키지 목록을 읽는 중입니다… 완료
              Installing helper tools …
              패키지 목록을 읽는 중입니다… 완료
              의존성 트리를 만드는 중입니다
              상태 정보를 읽는 중입니다… 완료
              build-essential is already the newest version (12.6).
              curl is already the newest version (7.64.0-4).
              git is already the newest version (1:2.20.1-2).
              unzip is already the newest version (6.0-23+deb10u1).
              wget is already the newest version (1.20.1-1.1).
              0개 업그레이드, 0개 새로 설치, 0개 제거 및 71개 업그레이드 안 함.
              Check current Node installation …
              Minimum Node version: v5.1.0
              Installed Node version: v10.15.2
              No Node.js upgrade necessary.
              Check current NPM installation …
              Minimum npm version: V6.0.0
              Installed npm version: V6.13.0
              No npm upgrade necessary.
              Cloning MagicMirror …
              'MagicMirror’에 복제합니다…
              remote: Enumerating objects: 331, done.
              remote: Counting objects: 100% (331/331), done.
              remote: Compressing objects: 100% (295/295), done.
              remote: Total 331 (delta 40), reused 198 (delta 22), pack-reused 0
              오브젝트를 받는 중: 100% (331/331), 662.32 KiB | 785.00 KiB/s, 완료.
              델타를 알아내는 중: 100% (40/40), 완료.
              Cloning MagicMirror Done!
              Installing dependencies …
              npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
              npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
              electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
              node ./download-chromedriver.js
              successfully dowloaded and extracted!
              electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
              node install.js
              Downloading tmp-5191-1-SHASUMS256.txt-3.0.13
              [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
              magicmirror@2.9.0 install /home/pi/MagicMirror
              cd vendor && npm install
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
              added 82 packages from 57 contributors and audited 220 packages in 23.801s
              magicmirror@2.9.0 postinstall /home/pi/MagicMirror
              sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
              We’ll remove from the repository the css/custom.css
              This script apply git update-index --skip-worktree css/custom.css
              rm ‘css/custom.css’
              MagicMirror installation successful!
              magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
              cd fonts && npm install
              added 1 package from 1 contributor and audited 1 package in 7.296s
              npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
              added 1062 packages from 1314 contributors and audited 3479 packages in 369.335s
              7 packages are looking for funding.
              Run “npm fund” to find out more.
              Dependencies installation Done!
              Check plymouth installation …
              Splashscreen: Checking themes directory.
              Splashscreen: Create theme directory if not exists.
              Splashscreen: Theme copied successfully.
              Splashscreen: Changed theme to MagicMirror successfully.
              Do you want use pm2 for auto starting of your MagicMirror (y/N)?n
              Do you want to disable the screen saver? (y/N)?y
              We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
              The screen is dark or flickers even if the magic mirror is triggered by npm war.
              Can I ignore it and move on to the next step?
                daegon-jjiya @lavolp3
                @lavolp3 Yes, but no picture or flickers
                S lavolp3L 2 Replies Last reply Reply Quote 0
                  @daegon-jjiya sounds like a bad hdmi cable
                  • lavolp3L Offline
                    lavolp3 Module Developer @daegon-jjiya
                    @daegon-jjiya the installation was successful. From the software side you don’t have any errors yet (only “warnings” from npm that can be ignored for now).
                    Flickering screen sounds like a hardware problem. How is your monitor connected?
                    Run
                    as described and let us know what happens.
                    If it’s only a black screen after a minute or so run
                    npm start dev
                    and let us know if there are errors coming up in your console.
                      @lavolp3
                      Ignored the error and finished the installation. However, after running the Magic Mirror, I want to test it, but as soon as the voice recognition function is turned on, it pops out and the following message appears.
                      magicmirror@2.9.0 start /home/pi/MagicMirror
                      sh run-start.sh
                      Starting MagicMirror: v2.9.0
                      Loading config …
                      Loading module helpers …
                      Module helper loaded: MMM-Hotword
                      Module helper loaded: MMM-AssistantMk2
                      All module helpers loaded.
                      Starting server on port 8080 …
                      Server started …
                      Starting module: newsfeed
                      Connecting socket for: MMM-Hotword
                      [HOTWORD] MMM-Hotword starts
                      Connecting socket for: MMM-AssistantMk2
                      Sockets connected & modules started …
                      Launching application.
                      Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                      [AMK2] Recipe is loaded: reboot.js
                      [AMK2] Recipe is loaded: screen_onoff.js
                      [AMK2] Recipe is loaded: shutdown.js
                      [AMK2] Temporal storage directory is clearing.
                      [HOTWORD] begins.
                      [HOTWORD] Detector starts listening.
                      [HOTWORD] stops.
                      [HOTWORD] Final Result: { detected: false }
                      [HOTWORD] begins.
                      [AMK2] assistant ready
                      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
                      npm ERR! code ELIFECYCLE
                      npm ERR! syscall spawn
                      npm ERR! file sh
                      npm ERR! errno ENOENT
                      npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                      npm ERR! spawn ENOENT
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.9.0 start script.
                      npm ERR! /home/pi/.npm/_logs/2019-11-14T03_53_11_525Z-debug.log
                      I tried translating but it doesn’t make sense. If you know how, please answer.
                        @daegon-jjiya said in Please help me...........:
                        __atomic_store_8
                        see this reply for the steps to recover… one of the libraries that module uses has a bug
                        https://forum.magicmirror.builders/topic/11430/error-when-trying-to-run-mmm-assistantmk2/5
