    Please help me...........
    19 Posts 4 Posters 3.7k Views 4 Watching
      daegon-jjiya
      This is my first mirror. Even if you follow the video on YouTube, there are a lot of errors…
      Install, delete, install, delete, repeat 30 times I’m tired.
      board : raspverry pi 3 b+
      install root >
      (I’m Korean, so I did a Korean patch.)
      step.1
      sudo apt-get install fonts-nanum fonts-synbola
      reboot
      Success up to here
      step.2
      sudo apt-get update
      sudo apt-get upgrade
      Success up to here
      step. 3
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      * > 1 error
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
      > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      successfully dowloaded and extracted!
      > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      > magicmirror@2.9.0 install /home/pi/MagicMirror
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      added 82 packages from 57 contributors and audited 220 packages in 23.983s
      found 5 vulnerabilities (4 low, 1 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
      > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
      We'll remove from the repository the css/custom.css
      This script apply git update-index --skip-worktree css/custom.css
      rm 'css/custom.css'
      MagicMirror installation successful!
      No more progress after this. I can’t even run a magic mirror.
      The goal is to install Hotwords and Google Assist MK2, but I can’t.
      If you have ever installed a magic mirror with your Raspberry pi B +,
      please let me know how to install it. , but I can only follow.
      I want to make it to my children like the link below. See also how to make. Please ask again
      https://www.youtube.com/watch?v=6mrfwOO0OEg&list=PL46rwaN5jZCkC_ZVdg2qvu6GxVMxM-zGK&index=4
      If you solve it, I will buy rice in Korea ^^
        sdetweil @daegon-jjiya
        @daegon-jjiya
        what happens?
        maybe try the udpated installer
        https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        you will have to erase the MagicMirror folder to start over
        cd ~
        rm -rf MagicMirror
          daegon-jjiya @sdetweil
          Thanks for the answer, but only the error indication for the same problem
            @daegon-jjiya can u show me the contents of ~/install.log please
            • lavolp3L Offline
              lavolp3 Module Developer
              @daegon-jjiya sorry i cant find the Error in your post. Seems the mirror had been installed successfully.
              Have you fully followed the described procedure in the readme?
              Have you tried to actually run it?
              cd MagicMirror && npm start
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
                pi@raspberrypi:~ $
                pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
                $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
                $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
                $$$$$$ $$ | _
                $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
                $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
                $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
                _
                | _
                | _
                | _
                $$ |_| _
                |_| _|_|_| __| _
                / _| _______|
                _
                ____/
                Updating packages …
                기존:1 http://archive.raspberrypi.org/debian buster InRelease
                받기:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                받기:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
                내려받기 12.8 M바이트, 소요시간 36초 (352 k바이트/초)
                패키지 목록을 읽는 중입니다… 완료
                Installing helper tools …
                패키지 목록을 읽는 중입니다… 완료
                의존성 트리를 만드는 중입니다
                상태 정보를 읽는 중입니다… 완료
                build-essential is already the newest version (12.6).
                curl is already the newest version (7.64.0-4).
                git is already the newest version (1:2.20.1-2).
                unzip is already the newest version (6.0-23+deb10u1).
                wget is already the newest version (1.20.1-1.1).
                0개 업그레이드, 0개 새로 설치, 0개 제거 및 71개 업그레이드 안 함.
                Check current Node installation …
                Minimum Node version: v5.1.0
                Installed Node version: v10.15.2
                No Node.js upgrade necessary.
                Check current NPM installation …
                Minimum npm version: V6.0.0
                Installed npm version: V6.13.0
                No npm upgrade necessary.
                Cloning MagicMirror …
                'MagicMirror’에 복제합니다…
                remote: Enumerating objects: 331, done.
                remote: Counting objects: 100% (331/331), done.
                remote: Compressing objects: 100% (295/295), done.
                remote: Total 331 (delta 40), reused 198 (delta 22), pack-reused 0
                오브젝트를 받는 중: 100% (331/331), 662.32 KiB | 785.00 KiB/s, 완료.
                델타를 알아내는 중: 100% (40/40), 완료.
                Cloning MagicMirror Done!
                Installing dependencies …
                node install.js
                Downloading tmp-5191-1-SHASUMS256.txt-3.0.13
                [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                added 82 packages from 57 contributors and audited 220 packages in 23.801s
                We’ll remove from the repository the css/custom.css
                rm ‘css/custom.css’
                magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                cd fonts && npm install
                added 1 package from 1 contributor and audited 1 package in 7.296s
                npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                added 1062 packages from 1314 contributors and audited 3479 packages in 369.335s
                7 packages are looking for funding.
                Run “npm fund” to find out more.
                Dependencies installation Done!
                Check plymouth installation …
                Splashscreen: Checking themes directory.
                Splashscreen: Create theme directory if not exists.
                Splashscreen: Theme copied successfully.
                Splashscreen: Changed theme to MagicMirror successfully.
                Do you want use pm2 for auto starting of your MagicMirror (y/N)?n
                Do you want to disable the screen saver? (y/N)?y
                We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                The screen is dark or flickers even if the magic mirror is triggered by npm war.
                Can I ignore it and move on to the next step?
                  daegon-jjiya @lavolp3
                  @lavolp3 Yes, but no picture or flickers
                  S lavolp3L 2 Replies Last reply Reply Quote 0
                    @daegon-jjiya sounds like a bad hdmi cable
                    • lavolp3L Offline
                      lavolp3 Module Developer @daegon-jjiya
                      @daegon-jjiya the installation was successful. From the software side you don’t have any errors yet (only “warnings” from npm that can be ignored for now).
                      Flickering screen sounds like a hardware problem. How is your monitor connected?
                      Run
                      as described and let us know what happens.
                      If it’s only a black screen after a minute or so run
                      npm start dev
                      and let us know if there are errors coming up in your console.
                        @lavolp3
                        Ignored the error and finished the installation. However, after running the Magic Mirror, I want to test it, but as soon as the voice recognition function is turned on, it pops out and the following message appears.
                        magicmirror@2.9.0 start /home/pi/MagicMirror
                        sh run-start.sh
                        Starting MagicMirror: v2.9.0
                        Loading config …
                        Loading module helpers …
                        Module helper loaded: MMM-Hotword
                        Module helper loaded: MMM-AssistantMk2
                        All module helpers loaded.
                        Starting server on port 8080 …
                        Server started …
                        Starting module: newsfeed
                        Connecting socket for: MMM-Hotword
                        [HOTWORD] MMM-Hotword starts
                        Connecting socket for: MMM-AssistantMk2
                        Sockets connected & modules started …
                        Launching application.
                        Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                        Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                        [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                        [AMK2] Recipe is loaded: reboot.js
                        [AMK2] Recipe is loaded: screen_onoff.js
                        [AMK2] Recipe is loaded: shutdown.js
                        [AMK2] Temporal storage directory is clearing.
                        [HOTWORD] begins.
                        [HOTWORD] Detector starts listening.
                        [HOTWORD] stops.
                        [HOTWORD] Final Result: { detected: false }
                        [HOTWORD] begins.
                        [AMK2] assistant ready
                        /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
                        npm ERR! code ELIFECYCLE
                        npm ERR! syscall spawn
                        npm ERR! file sh
                        npm ERR! errno ENOENT
                        npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                        npm ERR! spawn ENOENT
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.9.0 start script.
                        npm ERR! /home/pi/.npm/_logs/2019-11-14T03_53_11_525Z-debug.log
                        I tried translating but it doesn’t make sense. If you know how, please answer.
