    Please help me...........
    19 Posts 4 Posters 3.6k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      @daegon-jjiya sorry i cant find the Error in your post. Seems the mirror had been installed successfully.
      Have you fully followed the described procedure in the readme?
      Have you tried to actually run it?
      cd MagicMirror && npm start
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        daegon-jjiya @sdetweil
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)”
        $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
        $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
        $$$$$$ $$ | _
        $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
        $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
        $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
        _
        | _
        | _
        | _
        $$ |_| _
        |_| _|_|_| __| _
        / _| _______|
        _
        ____/
        Updating packages …
        기존:1 http://archive.raspberrypi.org/debian buster InRelease
        받기:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
        받기:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
        내려받기 12.8 M바이트, 소요시간 36초 (352 k바이트/초)
        패키지 목록을 읽는 중입니다… 완료
        Installing helper tools …
        패키지 목록을 읽는 중입니다… 완료
        의존성 트리를 만드는 중입니다
        상태 정보를 읽는 중입니다… 완료
        build-essential is already the newest version (12.6).
        curl is already the newest version (7.64.0-4).
        git is already the newest version (1:2.20.1-2).
        unzip is already the newest version (6.0-23+deb10u1).
        wget is already the newest version (1.20.1-1.1).
        0개 업그레이드, 0개 새로 설치, 0개 제거 및 71개 업그레이드 안 함.
        Check current Node installation …
        Minimum Node version: v5.1.0
        Installed Node version: v10.15.2
        No Node.js upgrade necessary.
        Check current NPM installation …
        Minimum npm version: V6.0.0
        Installed npm version: V6.13.0
        No npm upgrade necessary.
        Cloning MagicMirror …
        'MagicMirror’에 복제합니다…
        remote: Enumerating objects: 331, done.
        remote: Counting objects: 100% (331/331), done.
        remote: Compressing objects: 100% (295/295), done.
        remote: Total 331 (delta 40), reused 198 (delta 22), pack-reused 0
        오브젝트를 받는 중: 100% (331/331), 662.32 KiB | 785.00 KiB/s, 완료.
        델타를 알아내는 중: 100% (40/40), 완료.
        Cloning MagicMirror Done!
        Installing dependencies …
        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
        npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
        electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
        node ./download-chromedriver.js
        successfully dowloaded and extracted!
        electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
        node install.js
        Downloading tmp-5191-1-SHASUMS256.txt-3.0.13
        [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
        magicmirror@2.9.0 install /home/pi/MagicMirror
        cd vendor && npm install
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
        added 82 packages from 57 contributors and audited 220 packages in 23.801s
        magicmirror@2.9.0 postinstall /home/pi/MagicMirror
        sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
        We’ll remove from the repository the css/custom.css
        This script apply git update-index --skip-worktree css/custom.css
        rm ‘css/custom.css’
        MagicMirror installation successful!
        magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
        cd fonts && npm install
        added 1 package from 1 contributor and audited 1 package in 7.296s
        npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
        added 1062 packages from 1314 contributors and audited 3479 packages in 369.335s
        7 packages are looking for funding.
        Run “npm fund” to find out more.
        Dependencies installation Done!
        Check plymouth installation …
        Splashscreen: Checking themes directory.
        Splashscreen: Create theme directory if not exists.
        Splashscreen: Theme copied successfully.
        Splashscreen: Changed theme to MagicMirror successfully.
        Do you want use pm2 for auto starting of your MagicMirror (y/N)?n
        Do you want to disable the screen saver? (y/N)?y
        We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
        The screen is dark or flickers even if the magic mirror is triggered by npm war.
        Can I ignore it and move on to the next step?
          daegon-jjiya @lavolp3
          @lavolp3 Yes, but no picture or flickers
          S lavolp3L 2 Replies Last reply Reply Quote 0
            sdetweil @daegon-jjiya
            @daegon-jjiya sounds like a bad hdmi cable
            • lavolp3L Offline
              lavolp3 Module Developer @daegon-jjiya
              @daegon-jjiya the installation was successful. From the software side you don’t have any errors yet (only “warnings” from npm that can be ignored for now).
              Flickering screen sounds like a hardware problem. How is your monitor connected?
              Run
              as described and let us know what happens.
              If it’s only a black screen after a minute or so run
              npm start dev
              and let us know if there are errors coming up in your console.
                @lavolp3
                Ignored the error and finished the installation. However, after running the Magic Mirror, I want to test it, but as soon as the voice recognition function is turned on, it pops out and the following message appears.
                magicmirror@2.9.0 start /home/pi/MagicMirror
                sh run-start.sh
                Starting MagicMirror: v2.9.0
                Loading config …
                Loading module helpers …
                Module helper loaded: MMM-Hotword
                Module helper loaded: MMM-AssistantMk2
                All module helpers loaded.
                Starting server on port 8080 …
                Server started …
                Starting module: newsfeed
                Connecting socket for: MMM-Hotword
                [HOTWORD] MMM-Hotword starts
                Connecting socket for: MMM-AssistantMk2
                Sockets connected & modules started …
                Launching application.
                Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                [AMK2] Recipe is loaded: reboot.js
                [AMK2] Recipe is loaded: screen_onoff.js
                [AMK2] Recipe is loaded: shutdown.js
                [AMK2] Temporal storage directory is clearing.
                [HOTWORD] begins.
                [HOTWORD] Detector starts listening.
                [HOTWORD] stops.
                [HOTWORD] Final Result: { detected: false }
                [HOTWORD] begins.
                [AMK2] assistant ready
                /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
                npm ERR! code ELIFECYCLE
                npm ERR! syscall spawn
                npm ERR! file sh
                npm ERR! errno ENOENT
                npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                npm ERR! spawn ENOENT
                npm ERR!
                npm ERR! Failed at the magicmirror@2.9.0 start script.
                npm ERR! /home/pi/.npm/_logs/2019-11-14T03_53_11_525Z-debug.log
                I tried translating but it doesn’t make sense. If you know how, please answer.
                  @daegon-jjiya said in Please help me...........:
                  __atomic_store_8
                  see this reply for the steps to recover… one of the libraries that module uses has a bug
                  https://forum.magicmirror.builders/topic/11430/error-when-trying-to-run-mmm-assistantmk2/5
                    @sdetweil Thank you for answer. We are going to the link you tell us.
                      I tried using the link above, but when I ran Red text and Magic Mirror, the following characters were displayed and the Magic Mirror screen did not appear.
                      pi@raspberrypi:~ $ cd MagicMirror
                      sh run-start.sh
                      Loading config …
                      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                      Expected directory: electron-v3.0-linux-arm-glibc
                      Found: [node-v64-linux-arm-glibc]
                      This problem can often be fixed by running “npm rebuild” on the current system
                      Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node’
                      App threw an error during load
                      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:64:3)
                      at Module._compile (internal/modules/cjs/loader.js:711:30)
                      at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                      at Module.load (internal/modules/cjs/loader.js:620:32)
                      at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                      at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                      at Module.require (internal/modules/cjs/loader.js:658:17)
                      at require (internal/modules/cjs/helpers.js:20:18)
                      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
                      Whoops! There was an uncaught exception…
                      { Error: Failed to load gRPC binary module because it was not installed for the current system
                      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: ‘MODULE_NOT_FOUND’ }
                      Shutting down server…
                      Stopping module helper: updatenotification
                      Stopping module helper: calendar
                      Stopping module helper: newsfeed
                      Stopping module helper: MMM-Hotword
                      I think you need to know the order in order to follow the link mentioned above.
                      If you have time, can you easily arrange the order of installing Magic Mirror MMM-HOTWARD and MMM-AssistantMK2?
                      For the first time, it’s all new and hard But I want to finish it.
                      You can only imitate while watching YouTube videos. But I want to give me and my children a new experience.
                      please …
                      • raspberry pi 3+
                      • Raspbian Buster with desktop and recommended software 2019-09-26
                      • Work directly on the board rather than remotely
                      • The above specification is the environment I am working on.
                      S Mykle1M 2 Replies Last reply Reply Quote 0
                        @daegon-jjiya
                        did you do this step
                        npm rebuild
