    temperature sensors
    17 Posts 11 Posters 8.9k Views 12 Watching
    • brobergB Offline
      broberg Project Sponsor @s.monti.74
      @s-monti-74
      zigbee does need a gateway since it talks on another protocoll than regular wifi (even if it is on the same bandwidth).
      try building esp8266 nodes with temperature sensors and run espeasy on them. should cost you around 10-15usd each, without power supplies.
      otherwise you have ready made Shelly Temp Sensors that runs on wifi, they are a bit pricey though.
      Shelly :
      https://www.amazon.com/Shelly-Temperature-Hygrometer-Automation-Application/dp/B07L97LBSG
      esp temperature build guide :
      https://randomnerdtutorials.com/esp8266-ds18b20-temperature-sensor-web-server-with-arduino-ide/
        s.monti.74 @broberg
        @broberg Not bad the “Shelly solution” but with which module can I read the values ?
        • brobergB Offline
          @s-monti-74 Don’t think there are any modules written for shelly yet. It’s not impossible but don’t think anyone have done it.
          Same goes for the esp8266, don’t think there are any modules for temperature for those either.
            s.monti.74 @broberg
            @broberg , usually, in this moment, @sdetweil pull the module we need out of the cylinder …
              sdetweil @s.monti.74
              @s-monti-74 @broberg Sadly, I do not have any magic solution for this
                ardenking
                probably found a solution by next now
                but I use a combination esp8266 and mysensors with dht22
                  s.monti.74
                  @ardenking said in temperature sensors:
                  no i haven’t find yet
                  I’ m trying with openhab and home assistant to read shelly h&t but I don’t understand how to setup
                  dht22 are connected to the PI ? do you have one Pi in each room ?
                  thanks
                  • N Offline
                    namanjohnson101
                    I have a SmartThings hub and Alexa and I’m looking for a cheap, reliable way to measure temperature across the house. What I’ve tried:
                    Xiaomi Aqara temperature sensors, which are super cheap but are reliable if and only if they’re close to the hub - they quickly lose connection and won’t reconnect if they’re distant (repeaters make it worse).
                    Centralite temperature/humidity sensor seems to work reasonably well, but needs CR2 batteries and goes through them quite quickly. Looks like they’ve stopped making them anyway kamukta
                    Samsung Multisensor, but it seems wasteful to have 6 measurements and only look at one of them
                    Boesch motion sensor, ditto
                    VIsonic door sensor, ditto, also only reports temperature a couple times a day
                    Are there temperature (or temperature/humidity) sensors for Zigbee or Z-wave that cost $15 or less that I can actually expect to work for more than a week at a time?
                    • BKeyportB Offline
                      BKeyport Module Developer
                      I’m playing with a DHT 11 sensor I got out of a kit and https://github.com/ryck/MMM-DHT-Sensor. cheapest ever - free on the sensor + software.
                        stampeder
                        ESP32 with DS18B20. ESP32 can run micropython so code is easy. ESP32 is cheap and so is the DS18B20. Simple compact and is WIFI.
