    temperature sensors
    17 Posts 11 Posters 8.9k Views 12 Watching
      s.monti.74
      HI
      which is the chepest way to manage temperature sensors with MM ? I mean, I’m searching cheap hardware sensors to retrieve temperature in one or more rooms
      thanks
      StoffbeuteluweS lavolp3L 2 Replies Last reply Reply Quote 0
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @s.monti.74
        @s-monti-74
        https://github.com/mirko3000/MMM-xiaomi
        • lavolp3L Offline
          lavolp3 Module Developer @s.monti.74
          @s-monti-74 If you’re only looking for cheap temp sensors only (so only measuring and not controlling), you should go with the DHT11 or DHT22
          http://www.circuitbasics.com/how-to-set-up-the-dht11-humidity-sensor-on-the-raspberry-pi/
          https://www.raspberrypi-spy.co.uk/2017/09/dht11-temperature-and-humidity-sensor-raspberry-pi/
          I guess it will not get cheaper, but of course wiring and coding is necessary.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            seychellch
            I have just installed a DS18B20. I bought it for €0.85, complete with wires. But you need to get a 4.7k ohm resistor, which is not expensive. It is not waterproof and it does not read humidity. It is just a thermometer. Very straightforward installation.
              s.monti.74 @seychellch
              @seychellch
              OK but I would measure the temperature of various rooms, so I was thinking about wifi or zeegbee sensors without using the gateway or a cheap gateway
              • brobergB Offline
                broberg Project Sponsor @s.monti.74
                @s-monti-74
                zigbee does need a gateway since it talks on another protocoll than regular wifi (even if it is on the same bandwidth).
                try building esp8266 nodes with temperature sensors and run espeasy on them. should cost you around 10-15usd each, without power supplies.
                otherwise you have ready made Shelly Temp Sensors that runs on wifi, they are a bit pricey though.
                Shelly :
                https://www.amazon.com/Shelly-Temperature-Hygrometer-Automation-Application/dp/B07L97LBSG
                esp temperature build guide :
                https://randomnerdtutorials.com/esp8266-ds18b20-temperature-sensor-web-server-with-arduino-ide/
                  s.monti.74 @broberg
                  @broberg Not bad the “Shelly solution” but with which module can I read the values ?
                  • brobergB Offline
                    @s-monti-74 Don’t think there are any modules written for shelly yet. It’s not impossible but don’t think anyone have done it.
                    Same goes for the esp8266, don’t think there are any modules for temperature for those either.
                      s.monti.74 @broberg
                      @broberg , usually, in this moment, @sdetweil pull the module we need out of the cylinder …
                        sdetweil @s.monti.74
                        @s-monti-74 @broberg Sadly, I do not have any magic solution for this
