    temperature sensors
    17 Posts 11 Posters 10.1k Views 12 Watching
      s.monti.74
      HI
      which is the chepest way to manage temperature sensors with MM ? I mean, I’m searching cheap hardware sensors to retrieve temperature in one or more rooms
      thanks
      StoffbeuteluweS lavolp3L 2 Replies Last reply Reply Quote 0
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @s.monti.74
        @s-monti-74
        https://github.com/mirko3000/MMM-xiaomi
        • lavolp3L Offline
          lavolp3 Module Developer @s.monti.74
          @s-monti-74 If you’re only looking for cheap temp sensors only (so only measuring and not controlling), you should go with the DHT11 or DHT22
          http://www.circuitbasics.com/how-to-set-up-the-dht11-humidity-sensor-on-the-raspberry-pi/
          https://www.raspberrypi-spy.co.uk/2017/09/dht11-temperature-and-humidity-sensor-raspberry-pi/
          I guess it will not get cheaper, but of course wiring and coding is necessary.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            seychellch
            I have just installed a DS18B20. I bought it for €0.85, complete with wires. But you need to get a 4.7k ohm resistor, which is not expensive. It is not waterproof and it does not read humidity. It is just a thermometer. Very straightforward installation.
              s.monti.74 @seychellch
              @seychellch
              OK but I would measure the temperature of various rooms, so I was thinking about wifi or zeegbee sensors without using the gateway or a cheap gateway
                broberg Project Sponsor @s.monti.74
                @s-monti-74
                zigbee does need a gateway since it talks on another protocoll than regular wifi (even if it is on the same bandwidth).
                try building esp8266 nodes with temperature sensors and run espeasy on them. should cost you around 10-15usd each, without power supplies.
                otherwise you have ready made Shelly Temp Sensors that runs on wifi, they are a bit pricey though.
                Shelly :
                https://www.amazon.com/Shelly-Temperature-Hygrometer-Automation-Application/dp/B07L97LBSG
                esp temperature build guide :
                https://randomnerdtutorials.com/esp8266-ds18b20-temperature-sensor-web-server-with-arduino-ide/
                  s.monti.74 @broberg
                  @broberg Not bad the “Shelly solution” but with which module can I read the values ?
                    @s-monti-74 Don’t think there are any modules written for shelly yet. It’s not impossible but don’t think anyone have done it.
                    Same goes for the esp8266, don’t think there are any modules for temperature for those either.
                      s.monti.74 @broberg
                      @broberg , usually, in this moment, @sdetweil pull the module we need out of the cylinder …
                        sdetweil @s.monti.74
                        @s-monti-74 @broberg Sadly, I do not have any magic solution for this
                          ardenking
                          probably found a solution by next now
                          but I use a combination esp8266 and mysensors with dht22
                            s.monti.74
                            @ardenking said in temperature sensors:
                            no i haven’t find yet
                            I’ m trying with openhab and home assistant to read shelly h&t but I don’t understand how to setup
                            dht22 are connected to the PI ? do you have one Pi in each room ?
                            thanks
                            • N Offline
                              namanjohnson101
                              I have a SmartThings hub and Alexa and I’m looking for a cheap, reliable way to measure temperature across the house. What I’ve tried:
                              Xiaomi Aqara temperature sensors, which are super cheap but are reliable if and only if they’re close to the hub - they quickly lose connection and won’t reconnect if they’re distant (repeaters make it worse).
                              Centralite temperature/humidity sensor seems to work reasonably well, but needs CR2 batteries and goes through them quite quickly. Looks like they’ve stopped making them anyway kamukta
                              Samsung Multisensor, but it seems wasteful to have 6 measurements and only look at one of them
                              Boesch motion sensor, ditto
                              VIsonic door sensor, ditto, also only reports temperature a couple times a day
                              Are there temperature (or temperature/humidity) sensors for Zigbee or Z-wave that cost $15 or less that I can actually expect to work for more than a week at a time?
                              • BKeyportB Offline
                                BKeyport Module Developer
                                I’m playing with a DHT 11 sensor I got out of a kit and https://github.com/ryck/MMM-DHT-Sensor. cheapest ever - free on the sensor + software.
                                  stampeder
                                  ESP32 with DS18B20. ESP32 can run micropython so code is easy. ESP32 is cheap and so is the DS18B20. Simple compact and is WIFI.
                                  • T Offline
                                    titoof @BKeyport
                                    @BKeyport Hello,
                                    I’m desperately trying to download the module: https://github.com/ryck/MMM-DHT-Sensor
                                    This one seems to be the most “DAY”. I have a DHT 11 to install but this one refuses to soul to make data returns. Thank you for your help.
                                    • BKeyportB Offline
                                      BKeyport Module Developer @titoof
                                      @titoof Not quite understanding your wording, there.
                                      Once you follow the instructions in the readme - exactly - and reboot your system, it will work.
                                      			module: "MMM-DHT-Sensor",
                                      			position: "bottom_right",
                                      			header: "Room Temp",
                                      				sensorPin: 26, // Use the GPIO number. GPIO 26/Pin 37.
                                      				sensorType: 22, // DHT 22 (DHT 11 change to 11)
                                      				updateInterval: 60 * 60 * 1000,
                                      				initialLoadDelay: 0,
                                      				animationSpeed: 1000,
                                      				units: "imperial",
                                      				relativeScale: 35,
                                      				debug: false
