    trouble with config file
    12 Posts 5 Posters 12.7k Views 4 Watching
    • N Offline
      nuckinfutz
      If you still haven’t gotten anywhere I’ll zip up and send you my entire directory structure and a step by step instruction sheet I wrote for myself to get the basic mirror up and running. You can compare them to yours and see where we differ. That should give you some insight.
      I 1 Reply Last reply Reply Quote 1
      • I Offline
        II12yanII @nuckinfutz
        @nuckinfutz said in trouble with config file:
        that would be awesome. i still havent gotten anywhere. i reinstalled node.js along with reinstalling magic mirror and so on. the only thing i havent tried reinstalling is raspbain. but i still get the same startup script failed electron.js
        • cowboysdudeC Offline
          cowboysdude Module Developer @II12yanII
          @II12yanII said in trouble with config file:
          My suggestion would be this…
          Format your card using this [please read the entire thing]->
          https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/3
          and reinstall raspbian… This one -> RASPBIAN JESSIE WITH PIXEL from: https://www.raspberrypi.org/downloads/raspbian/
          From there open a terminal window and run:
          [Download and install the latest Node.js version]
          curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
          sudo apt-get install -y nodejs
          After that is done then:
          git clone https://github.com/MichMich/MagicMirror.git
          go to the MagicMirror folder and run:
          npm install
          Once that’s completed run:
          npm start
          IF you get any errors post a screen shot as that helps VERY much :)
          • N Offline
            nuckinfutz
            Sorry about the delay. Here’s my solution.
            If you still have a problem I’ll zip everything up and send it to you.
            my solution and cowboys are similar but I always make sure with linux flavors everything is up to date. It’s just a habbit I also made everything so you could just copy entire commands then paste them into the terminal to save time
            Install jessie using this Noobs link.
            Its super easy to follow and takes care of a lot of basic steps automatically
            https://www.raspberrypi.org/downloads/noobs/
            Follow the directions
            If you need to set up a wireless card go here scroll down and
            follow the wireless instructions then come back here
            https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6
            Now to configure your Pi go to superkey(Windows key) - preferences - raspberry pi configuration
            Set up location, keyboard, time zone and time. The correct time is very important.
            open up a terminal and run this the following command to get everything up to date
            sudo apt-get update ; sudo apt-get upgrade
            Now run the following to update the RPi firmware
            sudo rpi-update
            When done reboot
            Now install the MM software
            Open a terminal and run
            curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
            Rotate your screen if you want by doing this. I didnt bother for now
            sudo nano /boot/config.txt
            Rotate display vertically
            display_rotate=1
            ctrl-x to save then Y for yes
            Now do this Or just use your file manager to make your copy of the config file.
            I never modify the .sample file
            cd /home/pi/MagicMirror/config
            cp config.js.sample config.js
            now change to the MM folder
            Use the following to start your mirror
            DISPLAY=:0 npm start
            • I Offline
              II12yanII @cowboysdude
              @cowboysdude said in trouble with config file:
              npm install
              npm start
              Thanks so much that fixed it for me. it now runs without errors. but im back to my original problem of my config file. the weather and news just stay at loading … and never update. here is a copy of my config file. i believe i put in my api key and everything correctly.
              Edit. i got the fox news portion of my config file to work but the weather still doesn’t update at all.
              /* Magic Mirror Config Sample
              • MIT Licensed.
              var config = {
              port: 8080,
              language: 'en',
              timeFormat: 12,
              units: 'imperial',
              		module: 'alert',
              		module: 'clock',
              		position: 'top_left'
              		module: 'calendar',
              		header: 'US Holidays',
              		position: 'top_left',
              					symbol: 'calendar-check-o ',
              		module: 'compliments',
              		position: 'lower_third'
              		module: 'currentweather',
              		position: 'top_right',
              			locationID: '23',  //ID from http://www.openweathermap.org
              			appid: 'cea6dc928b7d5437e5883dcda250fa8e'
              		module: 'weatherforecast',
              		header: 'Weather Forecast',
              		module: 'newsfeed',
              		position: 'bottom_bar',
              			feeds: [
              					title: "Fox News",
              					url: "http://www.foxnews.com/about/rss/"
              			showSourceTitle: true,
              			showPublishDate: true
              if (typeof module !== ‘undefined’) {module.exports = config;}
              • bheplerB Offline
                bhepler Module Developer
                Just a suggestion: Try replacing that location id of locationID: '23' with locationID: '2173741'.
                • I Offline
                  II12yanII @bhepler
                  @bhepler said in trouble with config file:
                  that fixed it for me thanks. i guess using the map to get the ID for my location wasn’t the right ID.
                  Thank you everyone for your help my config file is the way i want it and it runs without any errors.
