    [MMM-Remote-Control] Cannot GET /api
    12 Posts 10 Posters 9.0k Views 8 Watching
      AxLed Module Developer
      @Carsten
      Are you sure your link example is complete?
      Is the following example $ curl -X GET http://magicmirrorip:8080/api/module/alert/showalert?message=Hello&timer=2000 working?
      Details see https://github.com/Jopyth/MMM-Remote-Control/blob/master/API/README.md
      AxLED
        Carsten
        Yes i,m sure. It is from the Documentation you,ve posted.
        But also your link Example don‘t work.
        Cannot GET /api/module/alert/showalert
        What i‘ve read till now it seems that the api folder isn‘t published.
        I‘ve did an update of MM but didn‘t helped.
        Further help is much appreciated.
        • T Offline
          teemuoksanen
          I have exactly the same problem - all API calls result in error “Cannot GET /api/whatevermoduleitrytocall”. However, remote.html loads just fine.
            mohace @teemuoksanen
            @teemuoksanen said in [MMM-Remote-Control] Cannot GET /api:
            As I have.
            Edited: It was a mistake, sorry. I have same problem.
              mlcampbe
              Same here too. I thought that perhaps we needed to have MMM-Api module installed but when I install that my MM won’t even start due to errors.
                @AxLed said in [MMM-Remote-Control] Cannot GET /api:
                it looks like the api was changed, but not documented…
                looking thru node_helper.js you can see all the commands
                ip:port/remote?action=xxxxx&parms=???&parms2=???
                the code lists these actions
                            if (query.action === "SHUTDOWN") {
                            if (query.action === "REBOOT") {
                            if (query.action === "RESTART" || query.action === "STOP") {
                            if (query.action === "USER_PRESENCE") {
                            if (["MONITORON", "MONITOROFF", "MONITORTOGGLE", "MONITORSTATUS"].indexOf(query.action) !== -1) {
                                this.monitorControl(query.action, opts, res);
                            if (query.action === "HIDE" || query.action === "SHOW" || query.action === "TOGGLE") {
                                self.sendSocketNotification(query.action, query);
                            if (query.action === "BRIGHTNESS") {
                                self.sendSocketNotification(query.action, query.value);
                            if (query.action === "SAVE") {
                            if (query.action === "MODULE_DATA") {
                            if (query.action === "INSTALL") {
                            if (query.action === "REFRESH") {
                                self.sendSocketNotification(query.action);
                            if (query.action === "HIDE_ALERT") {
                            if (query.action === "SHOW_ALERT") {
                                self.sendSocketNotification(query.action, {
                            if (query.action === "UPDATE") {
                            if (query.action === 'NOTIFICATION') {
                                    this.sendSocketNotification(query.action, { 'notification': query.notification, 'payload': payload });
                            if (["MINIMIZE", "TOGGLEFULLSCREEN", "DEVTOOLS"].indexOf(query.action) !== -1) {
                                    switch (query.action) {
                            if (query.action === "DELAYED") {
                to send an alert thru the api
                http://mirror_ip:mirror_port/remote?action=SHOW_ALERT&message=foo&title=help&timer=10&type=alert
                the remote.html does NOT use the api, but uses the socketNotifications pipe under the covers.
                which is why it works, but the older /api/modulename… approach doesn’t
                J A 2 Replies Last reply Reply Quote 3
                  jvanoost @sdetweil
                  @sdetweil oh thank you so much !! I couldn’t find the way to use it :)
                    PolaricBear
                    I think I solved the problem. At least it worked for me.
                    Just delete file ./modules/package-lock.json. And restart the system.
                    S S 2 Replies Last reply Reply Quote 1
                      sdetweil @PolaricBear
                      @PolaricBear did u post this to the wrong topic?
                        Smolo @PolaricBear
                        @PolaricBear
                        Thx i had the same problem and your tip solved it :-)
                          AmazingUpHotel @sdetweil
                          @sdetweil THANKS YOU! That’s the problem, we dont need to use API!
