    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      A Former User @jani.karna
      @jani-karna
      try http instead of https
        @jani-karna
        put your ical file into ~/MagicMirror/modules/MMM-CalendarExt2 then, try to use this URL;
        http://localhost:8080/modules/MMM-CalendarExt2/Pyhat.ics
          jani.karna
          @Sean said in MMM-CalendarExt2:
          For some reason “localhost” tries to use 127.0.0.1 which gives error, but I tried “http://192.168.1.187:8080/modules/MMM-CalendarExt2/Pyhat.ics” and that worked! Thank you!
          • BKeyportB
            BKeyport Module Developer
            Hey, Just started using this module, and today’s update blew up everything… It and MMM-CalendarExtMinimonth fails now.
            Am I doing something wrong?
            			module: 'MMM-CalendarExt2',
            					calendars : [
            							url: "https://calendar.google.com/calendar/ical/mycalendar/info/basic.ics",
            							name: "Main Calendar", // Optional, Recommended
            							maxItems: 100,
            							scanInterval: 1000*60*1, // 1000*Seconds*minutes
            							beforeDays: 0,
            							afterDays: 999,
            							maxIterations: 100,
            							forceLocalTZ: false,
            					views: [
            							mode: "daily",
            							position: "top_center",
            							slotCount: 20,
            					scenes: [
            			module: "MMM-CalendarExtMinimonth",
            			position: "bottom_right",
            			refreshInterval: 60*2.5*1000,
            Thanks!
            ? 1 Reply Last reply
              A Former User @BKeyport
              @BKeyport
              Sorry, Yesterday I fixed something but it made another bug. I fixed it now.
              • BKeyportB
                Thanks, that fixed it.
                The only thing I can’t figure out then is massive space between the end of the previous day’s activities, and the next day.
                Is there a way to solve this? Loving it otherwise.
                  @BKeyport
                  Controll that margin with hideOverflow and slotMaxHeight .
                  https://github.com/eouia/MMM-CalendarExt2/wiki/2c.-Configuration:View
                  BKeyportB 1 Reply Last reply
                    Mariba
                    I’m really satisfied with this module. Thank you.
                    Although, I’m facing an issue. I want to display two calendars in the same view and same scene. The calendars just won’t show. It works individually but not together.
                    Replace My URL with the original url. Sorry for the indentations.
                    My config:
                    url: "My URL",
                    url: "my URL",
                    views: [
                    title: "Calendar",
                    mode: "daily", fromNow:2, slotCount:2,
                    type: "row",
                    position: "upper_third",
                    calendars: ["Regular", "University"],
                    scenes: [
                    My CSS:
                    body {
                    /* .CX2 .slot .event {
                    background: inherit;
                     .CX2 .slot .slotHeader {
                    background-color: inherit;
                    text-transform: uppercase;
                    font-size: 12px;
                    font-family: "Roboto Condensed", Arial, helvetica, sans-serif;
                    font-weight: 400;
                    color: #999;
                    .CX2 .event[data-calendar-name="Regular"] {
                    border-left: #0098e9 solid;
                    .CX2 .event[data-calendar-name="University"] {
                    border-left: #60bb41 solid;
                      mrmagoo_83
                      Don’t you need to call out the view name the scene?
                        A Former User @Mariba
                        @Mariba
                        Well, I haven’t inspected your code yet, but most of the cases, it would be maxItems issue of view. For the performance, default maxItems of view is set to 100. If your calendars might have many events, set that option to a bigger value. You can estimate the number needed with your serverside log.
                        M 1 Reply Last reply
                        • BKeyportB
                          BKeyport Module Developer @Guest
                          @Sean Neither of those are what I would want. No matter how many items I have, there is a space there. I want to rid myself of the excess blank space, so that I can fit more real items into the display. When the day is empty there is very little space between days.
                            Mariba @Guest
                            @Sean Hello,
                            I tried with maxItems set to 10. I’m definitely sure that I dont have more than 8 items with the calendars combined. It still doesn’t solve the problem.
                              mrmagoo_83
                              How does one replace a parentheses in the title of an event?
                              • BKeyportB
                                BKeyport Module Developer @mrmagoo_83
                                @mrmagoo_83 Regex would be “\(” and “\)” to find both.
                                  @BKeyport
                                    @Mariba
                                    In that case, I should have real data to inspect.
                                      mmmmh Project Sponsor
                                      I have two views in one scene and need some layout/styling help. One row view shows the next 7 days and a column should show as many events as possible from 8 days onwards (a preview). For more precise placement, I created my own regions and added them to the index.html template.
                                      The next-7-days daily view is at the bottom of the screen and behaves nicely. The preview column is in the center of the screen and regrettably runs over the next-7-days view.
                                      In a daily column view, how can I skip days without events?
                                      Which style element do I need to modify in custom.css to have the column content to stop at precise coordinates and not spill over other modules?
                                      I tried limiting the region either with a bottom-margin or height value, both do not apply.
                                      Here’s the style that doesn’t work
                                      .region .preview {
                                          border: 1px #831e4d solid;
                                          position: absolute;
                                          left: 480px;
                                          width: 400px;
                                          top: 390px;
                                          height: 550px;
                                        A Former User @mmmmh
                                        @mmmmh
                                        1. Give your view className to control more precisely.
                                          For example,
                                          title: "Remove Empty Slot",
                                          mode: "daily",
                                          calendars: [],
                                          position:"top_left",
                                          hideOverflow: false,
                                          slotCount: 7,
                                          className: "remove_empty_slot"
                                        Then modify your css/custom.css
                                        .CX2 .remove_empty_slot .eventCount_0 {
                                          display:none;
                                          @Sean That works nicely for skipping days without events, thanks.
                                          What can I do about the overlap of the content. I can’t limit the view height in the config file or in the class style.
                                            @mmmmh
                                            can u tell me more details? even picture would be a help to understand your expect.
                                            • 24
                                            • 25
                                            • 7 / 25
