    My second Magic Mirror (without a mirror)
    18 Posts 7 Posters 16.0k Views 11 Watching
      MadsChaves @cyberphox
      @cyberphox - the pages just cycle through every 30 seconds, I am thinking of adding options for external intervention i.e. voice commands but am not there yet :)
      Be nice! Peace!
      O 1 Reply Last reply
      • O
        OldSunGuy @MadsChaves
        @MadsChaves Very nice. What non default modules are you using?
        M 1 Reply Last reply
          MadsChaves @OldSunGuy
          @OldSunGuy I used: calendar_monthly (tweaked to also show previous and next month), MMM-BackgroundSlideshow, MMM-pages, MMM-Page-Indicator, MMM-GooglePhotos,worldclock…
          Be nice! Peace!
          • L
            Leobo
            Hi @MadsChaves,
            Nice job. Can you explain to me how did you calendar_monthly Next and Prev do that? Please
              mrdenmark @Leobo
              @Leobo said in My second Magic Mirror (without a mirror):
              Hi @MadsChaves,
              I was going to ask the exact same question!
                MadsChaves @mrdenmark
                @mrdenmark & @Leobo - I am not a programmer but I can understand a little bit of code :) Anyways, I essentially replicated/tweaked the calendar_monthly module of Ashley M, Kirchner - big thanks (& apologies as well) to him for this module!!
                This calendar_monthly is basically using the moment() function. So for the next month module I used the "moment().add(1,‘months’)"to re-define the var month variables and for the previous month I used the “moment().subtract(1,‘months’)”…and since I was going to show prev, currrent and next months at thesame time, I removed the days (grayed days) of the other months that did not belong. I also played with the font size that was pre-defined in the wrapper as well as tweaked the cssStyle. Hope this helps :)
                Be nice! Peace!
                • L
                  Leobo
                  Thank you for your answer @MadsChaves . I do not understand about programs and code. I like this calendar_monthly module and I won’t show next month. Can you post your next month code here? Please.
                    MadsChaves @Leobo
                    @Leobo Oh, if you just want the monthly calendar, checkout the calendar_monthly module by KirAsh4 under the Utility / IOT / 3rd Party / Integration modules. The same one I used.
                    Be nice! Peace!
                    • L
                      Leobo
                      Sorry for asking so many, I want two calendars, one with this month and second with next month. I do not know in which place I have to integrate the moment.add (1, ‘months’). Sorry vor my bad English (translator).
                        MadsChaves
                        So sorry for the late reply…here’s an example of what I changed…
                        // Override dom generator
                        getDom: function() {
                        	if ((moment() > this.midnight) || (!this.loaded)) {
                        		var month = moment().add(1,'months');
                        		var year = moment().year();
                        		var monthName = moment().add(1,'months').format("MMMM");
                        		var monthLength = moment().add(1,'months').daysInMonth();
                        		// Find first day of the month, LOCALE aware
                        		var startingDay = moment().add(1,'months').date(1).weekday();
                        Be nice! Peace!
                        • L
                          Leobo
                          Thank you very mutch @MadsChaves . You are the best. That works really well. Thank you for your answer.
                            maxs
                            Hi, I would like to have also 3 calendars like @MadsChaves have, but it only shows me 1 calendar, and over the hole width from the screen, so too big. Can you help me a little bit more? Greetings Maxs.
                            • L
                              Leobo
                              You have to rename all three calendars module. For example one with "calendar_monthly Prev’ one ‘calendar_monthly’ and one ‘calendar_monthly Next’. In your config.js you must also enter the three calendars.
                              				module: 'calendar_monthly Prev',
                              				position: 'top_left',
                              				module: 'calendar_monthly',
                              				module: 'calendar_monthly Next',
                                maxs
                                Thanks gone a give it a try.
                                Update, now it works…
                                • L
                                  Leobo
                                  Nice.:thumbs_up_light_skin_tone:
                                  • earnestrichardsE
                                    earnestrichards
                                    Very nice mirror. I really like the framing as well as your content choices.
                                    I’m working on copying some of what you did… I successfully installed the before-current-next month calendars. I figured out how to copy what you did with the ‘extra’ days on the beginning and end of each month. What I can’t seem to get going is how to have only the current month’s current day highlighted.
                                    Pointer? Please.
