    MMM-Sunrise-Sunset
    44 Posts 9 Posters 23.6k Views 10 Watching
      sdetweil @pugsly
      @pugsly open the developers window on your blank screen MM, using ctrl-shift-i on the keyboard… select the tab labeled console and scroll up to find any errors
      pugslyP 1 Reply Last reply Reply Quote 0
      • pugslyP Offline
        pugsly @sdetweil
        Uncaught ReferenceError: $ is not defined
        at Class.updateSun (MMM-Sunrise-Sunset.js:33)
        at Class.start (MMM-Sunrise-Sunset.js:12)
        at startModules (loader.js:55)
        at loader.js:40
        at HTMLLinkElement.stylesheet.onload (loader.js:200)
          sdetweil @pugsly
          @pugsly said in MMM-Sunrise-Sunset:
          this module depends on jquery library being installed for this module, but its not…,
          I am working on instructions for you… hang on
          do
          cd ~/MagicMirror/modules/MMM-Sunrise-Sunset
          npm install jquery
          # note the trailing dot (.) on the next line
          cp node_modules/jquery/dist/jquery.js .
          then start your mirror again
          pugslyP D 2 Replies Last reply Reply Quote 0
          • pugslyP Offline
            pugsly @sdetweil
            @sdetweil said in MMM-Sunrise-Sunset:
            Slightly better, its displaying now but just says ‘Loading’
              sdetweil @pugsly
              @pugsly ok, open the developers window again
              this usually means that the api key is wrong … the api isn’t returning data
              • pugslyP Offline
                pugsly @sdetweil
                Its not passing the API key in the HTML request.
                https://api.ipgeolocation.io/astronomy?apiKey=&lang=en&lat=39.2907&long=-75.6344 401
                  sdetweil @pugsly
                  apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                  yep, case sensitive, it apiKey
                  • pugslyP Offline
                    pugsly @pugsly
                    @pugsly NVM… the K in apiKey is a capital. Its working now.
                      dankerthrone @sdetweil
                      @sdetweil: Thank you so much for your help here. I’m having the exact same problem as @pugsly did, but unfortunately your suggestions seem to not do the trick. I was wondering if you could help me out, too. So far I got:
                      			module: "MMM-Sunrise-Sunset",
                      			position: "bottom_bar",
                      				apiKey: "xxx",
                      				latitude: "xx.03586",
                      				longitude: "xx.06379",
                      				timezone: "Europe/Berlin",
                      				layout: "inline"
                      My screen stays black, though, and the developer console is giving me this:
                      at loader.js:40
                      I even tried executing your suggestions as root, thinking that I must’ve done something wrong, but I got the same error messages as before:
                      root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# npm install jquery
                      npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                      npm WARN modules No description
                      npm WARN modules No repository field.
                      npm WARN modules No README data
                      npm WARN modules No license field.
                      + jquery@3.4.1
                      removed 1 package, updated 1 package and audited 1 package in 4.09s
                      found 0 vulnerabilities
                      root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# cp node/modules/jquery/dist/jquery.js .
                      cp: cannot stat 'node/modules/jquery/dist/jquery.js': No such file or directory
                      What am I missing here?
                        sdetweil @dankerthrone
                        @dankerthrone said in MMM-Sunrise-Sunset:
                        should be (notice the underscore, _ instead of the slash /)
                          dankerthrone
                          That seems to have been a copy/paste-error. My terminal history shows it with the underscore. To make sure, I tried it once again, but still get
                          pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ cp node_modules/jquery/dist/jquery.js .
                          cp: cannot stat 'node_modules/jquery/dist/jquery.js': No such file or directory
                            @dankerthrone weird
                            show the output of
                            ls node_modules -laF
                              pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ ls node_modules -laF
                              ls: cannot access 'node_modules': No such file or directory
                              … I’m starting to wonder if I messed up something bigger in the beginning since almost any change I apply to config.js results in weird errors.
                                dankerthrone
                                after rebooting, the black screen of MagicMirror now shows this in the developer console:
                                Starting module: MMM-Sunrise-Sunset
                                MMM-Sunrise-Sunset.js:50 Uncaught ReferenceError: $ is not defined
                                    at Class.updateSun (MMM-Sunrise-Sunset.js:50)
                                    at loader.js:40
                                DailyXKCD.js:77 https://imgs.xkcd.com/comics/hotel_room_party.png
                                DailyXKCD.js:177 Uncaught TypeError: Cannot read property 'naturalHeight' of null
                                    at Class.scrollComic (DailyXKCD.js:177)
                                    at DailyXKCD.js:51
                                    at DailyXKCD.js:51
                                I’m really starting to think I do something stupid everytime I install/clone a module from github. I do follow each readme.md for installation, but somehow keep messing up :-/
                                  @dankerthrone installing a new module is pretty easy
                                  cd MagicMirror/modules
                                  git clone http:// the url of the git repo
                                  cd the name of the module
                                  if there is a package.,json file, then to load its dependencies do
                                  npm install
                                  then
                                  cd ~/MagicMirror/config
                                  nano config.js
                                  insert the module definition  info, (see the module readme.md)
                                  save
                                  then restart mirror app
                                  this module does NOT list its dependency on jquery as it should
                                  so, you have to fix it manually.
                                  SO, i don’t know where you were when u did the npm install jquery
                                  lets find it
                                  find . | grep jquery\.js
                                    DailyXKCD
                                    the XKCD errors look like poor programming by the author
                                    he tries to find the web content before its there, but doesn’t check if he got the location
                                      finding jquery as you suggested returns
                                      pi@raspberrypi:~/MagicMirror $ find . | grep jquery\.js
                                      ./node_modules/nwmatcher/src/modules/nwmatcher-jquery.js
                                        @dankerthrone hm… not where I would have expected it…
                                        so. lets try this again
                                        npm install jquery
                                        ls node_modules/jquery
                                        you should see this
                                        AUTHORS.txt  LICENSE.txt  README.md  bower.json  dist  external  package.json  src
                                        then do
                                        then
                                        ls jquery.js
                                        to prove the file is in the module folder
                                        i just did it all here step by step
                                          siggmur
                                          Late to the game, but I also am getting black screen after installing the module and adding it to my config. Ill try to give you the steps:
                                          Did the git pull. Went into the folder, npm install.
                                          Added this to my config:
                                          module: 'MMM-Sunrise-Sunset',
                                          position: "bottom_center",
                                          latitude: "69.13",
                                          longitude: "18.59",
                                          apiKey: "myAPI",
                                          layout: "inline",
                                          I also tried @sdetweil post, without any difference. I find the files as listed, did pm2 restart mm without any help.
                                          Ideas?
                                            sdetweil @siggmur
                                            @siggmur latitude and longitude are numbers, remove the quotes.
                                            general rule, for values to the right of :
                                            number or true/false - not quoted
                                            all else, quoted, doesn’t matter which one, just matching.
                                            also, lat/long usually are 6 digits
                                            xx.yyyy
                                            • 2 / 3
