    MMM-Sunrise-Sunset
    44 Posts 9 Posters 27.4k Views 10 Watching
      sdetweil @pugsly
      @pugsly not in config… you have to edit the actual module code
        pugsly @sdetweil
        @sdetweil Not sure I know what you mean. When I put this in my config the screen is all blank:
                module: "MMM-Sunrise-Sunset",
                header: "Sunrise",
                    latitude: "39.2907",
                    longitude: "-75.6344",
                    apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                    layout: "inline"
          sdetweil @pugsly
          @pugsly open the developers window on your blank screen MM, using ctrl-shift-i on the keyboard… select the tab labeled console and scroll up to find any errors
            pugsly @sdetweil
            Uncaught ReferenceError: $ is not defined
            at Class.updateSun (MMM-Sunrise-Sunset.js:33)
            at Class.start (MMM-Sunrise-Sunset.js:12)
            at startModules (loader.js:55)
            at loader.js:40
            at HTMLLinkElement.stylesheet.onload (loader.js:200)
              sdetweil @pugsly
              @pugsly said in MMM-Sunrise-Sunset:
              this module depends on jquery library being installed for this module, but its not…,
              I am working on instructions for you… hang on
              do
              cd ~/MagicMirror/modules/MMM-Sunrise-Sunset
              npm install jquery
              # note the trailing dot (.) on the next line
              cp node_modules/jquery/dist/jquery.js .
              then start your mirror again
              P D 2 Replies Last reply Reply Quote 0
                pugsly @sdetweil
                @sdetweil said in MMM-Sunrise-Sunset:
                Slightly better, its displaying now but just says ‘Loading’
                  sdetweil @pugsly
                  @pugsly ok, open the developers window again
                  this usually means that the api key is wrong … the api isn’t returning data
                    pugsly @sdetweil
                    Its not passing the API key in the HTML request.
                    https://api.ipgeolocation.io/astronomy?apiKey=&lang=en&lat=39.2907&long=-75.6344 401
                      sdetweil @pugsly
                      yep, case sensitive, it apiKey
                        pugsly @pugsly
                        @pugsly NVM… the K in apiKey is a capital. Its working now.
                          dankerthrone @sdetweil
                          @sdetweil: Thank you so much for your help here. I’m having the exact same problem as @pugsly did, but unfortunately your suggestions seem to not do the trick. I was wondering if you could help me out, too. So far I got:
                          			position: "bottom_bar",
                          				apiKey: "xxx",
                          				latitude: "xx.03586",
                          				longitude: "xx.06379",
                          				timezone: "Europe/Berlin",
                          				layout: "inline"
                          My screen stays black, though, and the developer console is giving me this:
                          at loader.js:40
                          I even tried executing your suggestions as root, thinking that I must’ve done something wrong, but I got the same error messages as before:
                          root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# npm install jquery
                          npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                          npm WARN modules No description
                          npm WARN modules No repository field.
                          npm WARN modules No README data
                          npm WARN modules No license field.
                          + jquery@3.4.1
                          removed 1 package, updated 1 package and audited 1 package in 4.09s
                          found 0 vulnerabilities
                          root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# cp node/modules/jquery/dist/jquery.js .
                          cp: cannot stat 'node/modules/jquery/dist/jquery.js': No such file or directory
                          What am I missing here?
                            sdetweil @dankerthrone
                            @dankerthrone said in MMM-Sunrise-Sunset:
                            should be (notice the underscore, _ instead of the slash /)
                              dankerthrone
                              That seems to have been a copy/paste-error. My terminal history shows it with the underscore. To make sure, I tried it once again, but still get
                              pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ cp node_modules/jquery/dist/jquery.js .
                              cp: cannot stat 'node_modules/jquery/dist/jquery.js': No such file or directory
                                @dankerthrone weird
                                show the output of
                                ls node_modules -laF
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ ls node_modules -laF
                                  ls: cannot access 'node_modules': No such file or directory
                                  … I’m starting to wonder if I messed up something bigger in the beginning since almost any change I apply to config.js results in weird errors.
                                    dankerthrone
                                    after rebooting, the black screen of MagicMirror now shows this in the developer console:
                                    Starting module: MMM-Sunrise-Sunset
                                    MMM-Sunrise-Sunset.js:50 Uncaught ReferenceError: $ is not defined
                                        at Class.updateSun (MMM-Sunrise-Sunset.js:50)
                                        at loader.js:40
                                    DailyXKCD.js:77 https://imgs.xkcd.com/comics/hotel_room_party.png
                                    DailyXKCD.js:177 Uncaught TypeError: Cannot read property 'naturalHeight' of null
                                        at Class.scrollComic (DailyXKCD.js:177)
                                        at DailyXKCD.js:51
                                        at DailyXKCD.js:51
                                    I’m really starting to think I do something stupid everytime I install/clone a module from github. I do follow each readme.md for installation, but somehow keep messing up :-/
                                      @dankerthrone installing a new module is pretty easy
                                      cd MagicMirror/modules
                                      git clone http:// the url of the git repo
                                      cd the name of the module
                                      if there is a package.,json file, then to load its dependencies do
                                      npm install
                                      then
                                      cd ~/MagicMirror/config
                                      nano config.js
                                      insert the module definition  info, (see the module readme.md)
                                      save
                                      then restart mirror app
                                      this module does NOT list its dependency on jquery as it should
                                      so, you have to fix it manually.
                                      SO, i don’t know where you were when u did the npm install jquery
                                      lets find it
                                      find . | grep jquery\.js
                                        DailyXKCD
                                        the XKCD errors look like poor programming by the author
                                        he tries to find the web content before its there, but doesn’t check if he got the location
                                          finding jquery as you suggested returns
                                          pi@raspberrypi:~/MagicMirror $ find . | grep jquery\.js
                                          ./node_modules/nwmatcher/src/modules/nwmatcher-jquery.js
                                            @dankerthrone hm… not where I would have expected it…
                                            so. lets try this again
                                            npm install jquery
                                            ls node_modules/jquery
                                            you should see this
                                            AUTHORS.txt  LICENSE.txt  README.md  bower.json  dist  external  package.json  src
                                            then do
                                            then
                                            ls jquery.js
                                            to prove the file is in the module folder
                                            i just did it all here step by step
                                            • 2 / 3
