    MMM-Sunrise-Sunset
    44 Posts 9 Posters 28.1k Views 10 Watching
      pugsly @sdetweil
      Uncaught ReferenceError: $ is not defined
      at Class.updateSun (MMM-Sunrise-Sunset.js:33)
      at Class.start (MMM-Sunrise-Sunset.js:12)
      at startModules (loader.js:55)
      at loader.js:40
      at HTMLLinkElement.stylesheet.onload (loader.js:200)
        sdetweil @pugsly
        @pugsly said in MMM-Sunrise-Sunset:
        this module depends on jquery library being installed for this module, but its not…,
        I am working on instructions for you… hang on
        do
        cd ~/MagicMirror/modules/MMM-Sunrise-Sunset
        npm install jquery
        # note the trailing dot (.) on the next line
        cp node_modules/jquery/dist/jquery.js .
        then start your mirror again
        P D 2 Replies Last reply
          pugsly @sdetweil
          @sdetweil said in MMM-Sunrise-Sunset:
          Slightly better, its displaying now but just says ‘Loading’
            sdetweil @pugsly
            @pugsly ok, open the developers window again
            this usually means that the api key is wrong … the api isn’t returning data
            P 1 Reply Last reply
              pugsly @sdetweil
              Its not passing the API key in the HTML request.
              https://api.ipgeolocation.io/astronomy?apiKey=&lang=en&lat=39.2907&long=-75.6344 401
                sdetweil @pugsly
                apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                yep, case sensitive, it apiKey
                  pugsly @pugsly
                  @pugsly NVM… the K in apiKey is a capital. Its working now.
                    dankerthrone @sdetweil
                    @sdetweil: Thank you so much for your help here. I’m having the exact same problem as @pugsly did, but unfortunately your suggestions seem to not do the trick. I was wondering if you could help me out, too. So far I got:
                    			module: "MMM-Sunrise-Sunset",
                    			position: "bottom_bar",
                    				apiKey: "xxx",
                    				latitude: "xx.03586",
                    				longitude: "xx.06379",
                    				timezone: "Europe/Berlin",
                    				layout: "inline"
                    My screen stays black, though, and the developer console is giving me this:
                    at loader.js:40
                    I even tried executing your suggestions as root, thinking that I must’ve done something wrong, but I got the same error messages as before:
                    root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# npm install jquery
                    npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                    npm WARN modules No description
                    npm WARN modules No repository field.
                    npm WARN modules No README data
                    npm WARN modules No license field.
                    + jquery@3.4.1
                    removed 1 package, updated 1 package and audited 1 package in 4.09s
                    found 0 vulnerabilities
                    root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# cp node/modules/jquery/dist/jquery.js .
                    cp: cannot stat 'node/modules/jquery/dist/jquery.js': No such file or directory
                    What am I missing here?
                      sdetweil @dankerthrone
                      @dankerthrone said in MMM-Sunrise-Sunset:
                      should be (notice the underscore, _ instead of the slash /)
                        dankerthrone
                        That seems to have been a copy/paste-error. My terminal history shows it with the underscore. To make sure, I tried it once again, but still get
                        pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ cp node_modules/jquery/dist/jquery.js .
                        cp: cannot stat 'node_modules/jquery/dist/jquery.js': No such file or directory
                          @dankerthrone weird
                          show the output of
                          ls node_modules -laF
                          D 1 Reply Last reply
                            pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ ls node_modules -laF
                            ls: cannot access 'node_modules': No such file or directory
                            … I’m starting to wonder if I messed up something bigger in the beginning since almost any change I apply to config.js results in weird errors.
                              dankerthrone
                              after rebooting, the black screen of MagicMirror now shows this in the developer console:
                              Starting module: MMM-Sunrise-Sunset
                              MMM-Sunrise-Sunset.js:50 Uncaught ReferenceError: $ is not defined
                                  at Class.updateSun (MMM-Sunrise-Sunset.js:50)
                                  at loader.js:40
                              DailyXKCD.js:77 https://imgs.xkcd.com/comics/hotel_room_party.png
                              DailyXKCD.js:177 Uncaught TypeError: Cannot read property 'naturalHeight' of null
                                  at Class.scrollComic (DailyXKCD.js:177)
                                  at DailyXKCD.js:51
                                  at DailyXKCD.js:51
                              I’m really starting to think I do something stupid everytime I install/clone a module from github. I do follow each readme.md for installation, but somehow keep messing up :-/
                              S 2 Replies Last reply
                                @dankerthrone installing a new module is pretty easy
                                cd MagicMirror/modules
                                git clone http:// the url of the git repo
                                cd the name of the module
                                if there is a package.,json file, then to load its dependencies do
                                npm install
                                then
                                cd ~/MagicMirror/config
                                nano config.js
                                insert the module definition  info, (see the module readme.md)
                                save
                                then restart mirror app
                                this module does NOT list its dependency on jquery as it should
                                so, you have to fix it manually.
                                SO, i don’t know where you were when u did the npm install jquery
                                lets find it
                                find . | grep jquery\.js
                                  DailyXKCD
                                  the XKCD errors look like poor programming by the author
                                  he tries to find the web content before its there, but doesn’t check if he got the location
                                    finding jquery as you suggested returns
                                    pi@raspberrypi:~/MagicMirror $ find . | grep jquery\.js
                                    ./node_modules/nwmatcher/src/modules/nwmatcher-jquery.js
                                      @dankerthrone hm… not where I would have expected it…
                                      so. lets try this again
                                      npm install jquery
                                      ls node_modules/jquery
                                      you should see this
                                      AUTHORS.txt  LICENSE.txt  README.md  bower.json  dist  external  package.json  src
                                      then do
                                      then
                                      ls jquery.js
                                      to prove the file is in the module folder
                                      i just did it all here step by step
                                        siggmur
                                        Late to the game, but I also am getting black screen after installing the module and adding it to my config. Ill try to give you the steps:
                                        Did the git pull. Went into the folder, npm install.
                                        Added this to my config:
                                        module: 'MMM-Sunrise-Sunset',
                                        position: "bottom_center",
                                        latitude: "69.13",
                                        longitude: "18.59",
                                        apiKey: "myAPI",
                                        layout: "inline",
                                        I also tried @sdetweil post, without any difference. I find the files as listed, did pm2 restart mm without any help.
                                        Ideas?
                                          sdetweil @siggmur
                                          @siggmur latitude and longitude are numbers, remove the quotes.
                                          general rule, for values to the right of :
                                          number or true/false - not quoted
                                          all else, quoted, doesn’t matter which one, just matching.
                                          also, lat/long usually are 6 digits
                                          xx.yyyy
                                            siggmur
                                            Thanks for the quick reply, I forgot the quotation marks, but it should throw a config error, not a black screen like I am getting?
                                            • 2 / 3
