    MMM-Sunrise-Sunset
    44 Posts 9 Posters 28.1k Views 10 Watching
      sdetweil @pugsly
      @pugsly said in MMM-Sunrise-Sunset:
      apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
      yep, case sensitive, it apiKey
        pugsly @pugsly
        @pugsly NVM… the K in apiKey is a capital. Its working now.
          dankerthrone @sdetweil
          @sdetweil: Thank you so much for your help here. I’m having the exact same problem as @pugsly did, but unfortunately your suggestions seem to not do the trick. I was wondering if you could help me out, too. So far I got:
          			module: "MMM-Sunrise-Sunset",
          			position: "bottom_bar",
          				apiKey: "xxx",
          				latitude: "xx.03586",
          				longitude: "xx.06379",
          				timezone: "Europe/Berlin",
          				layout: "inline"
          My screen stays black, though, and the developer console is giving me this:
          Uncaught ReferenceError: $ is not defined
          at Class.updateSun (MMM-Sunrise-Sunset.js:33)
          at Class.start (MMM-Sunrise-Sunset.js:12)
          at startModules (loader.js:55)
          at loader.js:40
          at HTMLLinkElement.stylesheet.onload (loader.js:200)
          I even tried executing your suggestions as root, thinking that I must’ve done something wrong, but I got the same error messages as before:
          root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# npm install jquery
          npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
          npm WARN modules No description
          npm WARN modules No repository field.
          npm WARN modules No README data
          npm WARN modules No license field.
          + jquery@3.4.1
          removed 1 package, updated 1 package and audited 1 package in 4.09s
          found 0 vulnerabilities
          root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# cp node/modules/jquery/dist/jquery.js .
          cp: cannot stat 'node/modules/jquery/dist/jquery.js': No such file or directory
          What am I missing here?
            sdetweil @dankerthrone
            @dankerthrone said in MMM-Sunrise-Sunset:
            should be (notice the underscore, _ instead of the slash /)
            cp node_modules/jquery/dist/jquery.js .
              dankerthrone
              That seems to have been a copy/paste-error. My terminal history shows it with the underscore. To make sure, I tried it once again, but still get
              pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ cp node_modules/jquery/dist/jquery.js .
              cp: cannot stat 'node_modules/jquery/dist/jquery.js': No such file or directory
                @dankerthrone weird
                show the output of
                cd  ~/MagicMirror/modules/MMM-Sunrise-Sunset
                ls node_modules -laF
                D 1 Reply Last reply
                  pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ ls node_modules -laF
                  ls: cannot access 'node_modules': No such file or directory
                  … I’m starting to wonder if I messed up something bigger in the beginning since almost any change I apply to config.js results in weird errors.
                    dankerthrone
                    after rebooting, the black screen of MagicMirror now shows this in the developer console:
                    Starting module: MMM-Sunrise-Sunset
                    MMM-Sunrise-Sunset.js:50 Uncaught ReferenceError: $ is not defined
                        at Class.updateSun (MMM-Sunrise-Sunset.js:50)
                        at loader.js:40
                    DailyXKCD.js:77 https://imgs.xkcd.com/comics/hotel_room_party.png
                    DailyXKCD.js:177 Uncaught TypeError: Cannot read property 'naturalHeight' of null
                        at Class.scrollComic (DailyXKCD.js:177)
                        at DailyXKCD.js:51
                        at DailyXKCD.js:51
                    I’m really starting to think I do something stupid everytime I install/clone a module from github. I do follow each readme.md for installation, but somehow keep messing up :-/
                    S 2 Replies Last reply
                      @dankerthrone installing a new module is pretty easy
                      cd MagicMirror/modules
                      git clone http:// the url of the git repo
                      cd the name of the module
                      if there is a package.,json file, then to load its dependencies do
                      npm install
                      then
                      cd ~/MagicMirror/config
                      nano config.js
                      insert the module definition  info, (see the module readme.md)
                      save
                      then restart mirror app
                      this module does NOT list its dependency on jquery as it should
                      so, you have to fix it manually.
                      SO, i don’t know where you were when u did the npm install jquery
                      lets find it
                      find . | grep jquery\.js
                        DailyXKCD
                        the XKCD errors look like poor programming by the author
                        he tries to find the web content before its there, but doesn’t check if he got the location
                          finding jquery as you suggested returns
                          pi@raspberrypi:~/MagicMirror $ find . | grep jquery\.js
                          ./node_modules/nwmatcher/src/modules/nwmatcher-jquery.js
                            @dankerthrone hm… not where I would have expected it…
                            so. lets try this again
                            npm install jquery
                            ls node_modules/jquery
                            you should see this
                            AUTHORS.txt  LICENSE.txt  README.md  bower.json  dist  external  package.json  src
                            then do
                            then
                            ls jquery.js
                            to prove the file is in the module folder
                            i just did it all here step by step
                              siggmur
                              Late to the game, but I also am getting black screen after installing the module and adding it to my config. Ill try to give you the steps:
                              Did the git pull. Went into the folder, npm install.
                              Added this to my config:
                              module: 'MMM-Sunrise-Sunset',
                              position: "bottom_center",
                              latitude: "69.13",
                              longitude: "18.59",
                              apiKey: "myAPI",
                              layout: "inline",
                              I also tried @sdetweil post, without any difference. I find the files as listed, did pm2 restart mm without any help.
                              Ideas?
                                sdetweil @siggmur
                                @siggmur latitude and longitude are numbers, remove the quotes.
                                general rule, for values to the right of :
                                number or true/false - not quoted
                                all else, quoted, doesn’t matter which one, just matching.
                                also, lat/long usually are 6 digits
                                xx.yyyy
                                  siggmur
                                  Thanks for the quick reply, I forgot the quotation marks, but it should throw a config error, not a black screen like I am getting?
                                    sdetweil @siggmur
                                    @siggmur black screen usually means missing library file.
                                    look at the startup.messages
                                    either
                                    pm2 logs --lines=100
                                    or the terminal window where do
                                    npm start
                                      siggmur
                                      @sdetweil ah, now we might be cooking. I find to suspected issues, but I am a bit to noobish to understand:
                                      [2020-08-01 01:35:48.402] [LOG] No helper found for module: MMM-Sunrise-Sunset.
                                      and:
                                      Fontconfig warning: “/etc/fonts/fonts.conf”, line 100: unknown element “blank”
                                      [2020-08-01 01:35:50.724] [ERROR] Whoops! There was an uncaught exception…
                                      [2020-08-01 01:35:50.727] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                      at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                                      at listenInCluster (net.js:1274:12)
                                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
                                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
                                      code: ‘EADDRINUSE’,
                                      errno: ‘EADDRINUSE’,
                                      syscall: ‘listen’,
                                      address: ‘127.0.0.1’,
                                      port: 8080
                                      Any idea what it could be?
                                        sdetweil @siggmur
                                        @siggmur eaddr in use means something is still using that port 8080,
                                        pm2’s job is to start at boot, so you can have more than one running
                                        keep stopping
                                        check w
                                        ps -ef | grep node |grep -v grep
                                        kill things til u get none.
                                        then
                                        npm start
                                        • 2 / 3
