    MMM-Sunrise-Sunset
    44 Posts 9 Posters 27.2k Views 10 Watching
      sdetweil @pugsly
      @pugsly said in MMM-Sunrise-Sunset:
      Uncaught ReferenceError: $ is not defined
      this module depends on jquery library being installed for this module, but its not…,
      I am working on instructions for you… hang on
      do
      cd ~/MagicMirror/modules/MMM-Sunrise-Sunset
      npm install jquery
      # note the trailing dot (.) on the next line
      cp node_modules/jquery/dist/jquery.js .
      then start your mirror again
      P D 2 Replies Last reply Reply Quote 0
        pugsly @sdetweil
        @sdetweil said in MMM-Sunrise-Sunset:
        Slightly better, its displaying now but just says ‘Loading’
          sdetweil @pugsly
          @pugsly ok, open the developers window again
          this usually means that the api key is wrong … the api isn’t returning data
            pugsly @sdetweil
            Its not passing the API key in the HTML request.
            https://api.ipgeolocation.io/astronomy?apiKey=&lang=en&lat=39.2907&long=-75.6344 401
              sdetweil @pugsly
              apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
              yep, case sensitive, it apiKey
                pugsly @pugsly
                @pugsly NVM… the K in apiKey is a capital. Its working now.
                  dankerthrone @sdetweil
                  @sdetweil: Thank you so much for your help here. I’m having the exact same problem as @pugsly did, but unfortunately your suggestions seem to not do the trick. I was wondering if you could help me out, too. So far I got:
                  			module: "MMM-Sunrise-Sunset",
                  			position: "bottom_bar",
                  				apiKey: "xxx",
                  				latitude: "xx.03586",
                  				longitude: "xx.06379",
                  				timezone: "Europe/Berlin",
                  				layout: "inline"
                  My screen stays black, though, and the developer console is giving me this:
                  at Class.updateSun (MMM-Sunrise-Sunset.js:33)
                  at Class.start (MMM-Sunrise-Sunset.js:12)
                  at startModules (loader.js:55)
                  at loader.js:40
                  at HTMLLinkElement.stylesheet.onload (loader.js:200)
                  I even tried executing your suggestions as root, thinking that I must’ve done something wrong, but I got the same error messages as before:
                  root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# npm install jquery
                  npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                  npm WARN modules No description
                  npm WARN modules No repository field.
                  npm WARN modules No README data
                  npm WARN modules No license field.
                  + jquery@3.4.1
                  removed 1 package, updated 1 package and audited 1 package in 4.09s
                  found 0 vulnerabilities
                  root@raspberrypi:/home/pi/MagicMirror/modules/MMM-Sunrise-Sunset# cp node/modules/jquery/dist/jquery.js .
                  cp: cannot stat 'node/modules/jquery/dist/jquery.js': No such file or directory
                  What am I missing here?
                    sdetweil @dankerthrone
                    @dankerthrone said in MMM-Sunrise-Sunset:
                    should be (notice the underscore, _ instead of the slash /)
                      dankerthrone
                      That seems to have been a copy/paste-error. My terminal history shows it with the underscore. To make sure, I tried it once again, but still get
                      pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ cp node_modules/jquery/dist/jquery.js .
                      cp: cannot stat 'node_modules/jquery/dist/jquery.js': No such file or directory
                        @dankerthrone weird
                        show the output of
                        ls node_modules -laF
                          pi@raspberrypi:~/MagicMirror/modules/MMM-Sunrise-Sunset $ ls node_modules -laF
                          ls: cannot access 'node_modules': No such file or directory
                          … I’m starting to wonder if I messed up something bigger in the beginning since almost any change I apply to config.js results in weird errors.
                            dankerthrone
                            after rebooting, the black screen of MagicMirror now shows this in the developer console:
                            Starting module: MMM-Sunrise-Sunset
                            MMM-Sunrise-Sunset.js:50 Uncaught ReferenceError: $ is not defined
                                at Class.updateSun (MMM-Sunrise-Sunset.js:50)
                                at loader.js:40
                            DailyXKCD.js:77 https://imgs.xkcd.com/comics/hotel_room_party.png
                            DailyXKCD.js:177 Uncaught TypeError: Cannot read property 'naturalHeight' of null
                                at Class.scrollComic (DailyXKCD.js:177)
                                at DailyXKCD.js:51
                                at DailyXKCD.js:51
                            I’m really starting to think I do something stupid everytime I install/clone a module from github. I do follow each readme.md for installation, but somehow keep messing up :-/
                              @dankerthrone installing a new module is pretty easy
                              cd MagicMirror/modules
                              git clone http:// the url of the git repo
                              cd the name of the module
                              if there is a package.,json file, then to load its dependencies do
                              npm install
                              then
                              cd ~/MagicMirror/config
                              nano config.js
                              insert the module definition  info, (see the module readme.md)
                              save
                              then restart mirror app
                              this module does NOT list its dependency on jquery as it should
                              so, you have to fix it manually.
                              SO, i don’t know where you were when u did the npm install jquery
                              lets find it
                              find . | grep jquery\.js
                                DailyXKCD
                                the XKCD errors look like poor programming by the author
                                he tries to find the web content before its there, but doesn’t check if he got the location
                                  finding jquery as you suggested returns
                                  pi@raspberrypi:~/MagicMirror $ find . | grep jquery\.js
                                  ./node_modules/nwmatcher/src/modules/nwmatcher-jquery.js
                                    @dankerthrone hm… not where I would have expected it…
                                    so. lets try this again
                                    npm install jquery
                                    ls node_modules/jquery
                                    you should see this
                                    AUTHORS.txt  LICENSE.txt  README.md  bower.json  dist  external  package.json  src
                                    then do
                                    then
                                    ls jquery.js
                                    to prove the file is in the module folder
                                    i just did it all here step by step
                                      siggmur
                                      Late to the game, but I also am getting black screen after installing the module and adding it to my config. Ill try to give you the steps:
                                      Did the git pull. Went into the folder, npm install.
                                      Added this to my config:
                                      module: 'MMM-Sunrise-Sunset',
                                      position: "bottom_center",
                                      latitude: "69.13",
                                      longitude: "18.59",
                                      apiKey: "myAPI",
                                      layout: "inline",
                                      I also tried @sdetweil post, without any difference. I find the files as listed, did pm2 restart mm without any help.
                                      Ideas?
                                        sdetweil @siggmur
                                        @siggmur latitude and longitude are numbers, remove the quotes.
                                        general rule, for values to the right of :
                                        number or true/false - not quoted
                                        all else, quoted, doesn’t matter which one, just matching.
                                        also, lat/long usually are 6 digits
                                        xx.yyyy
                                          siggmur
                                          Thanks for the quick reply, I forgot the quotation marks, but it should throw a config error, not a black screen like I am getting?
                                            sdetweil @siggmur
                                            @siggmur black screen usually means missing library file.
                                            look at the startup.messages
                                            either
                                            pm2 logs --lines=100
                                            or the terminal window where do
                                            npm start
                                            • 2 / 3
