    Autorestart
    15 Posts 6 Posters 5.8k Views 6 Watching
      sdetweil @cornusandu
      @cornusandu create a little script
      pm2 stop ?? (id or name)
      shutdown -r now
      but you shouldn’t have to shutdown MM manually
      • FoziF Offline
        Fozi Project Sponsor
        For executing a reboot you need sudo privileges for the crontab. Try this
        Open crontab with root privileges (sudo):
        $ sudo crontab -e
        Add the cronjob:
        # - reboots the MM everyday at 1:05 and 13:05
        # - redirects stdout and stderror to dev/null
        5 1,13 * * * sudo reboot >dev/null 2>&1
        Save and exit crontab.
        Please note the ‚sudo‘ before ‚crontab -e’ and don‘t forget ‚sudo‘ before ‚reboot‘.
          sdetweil @Fozi
          @Fozi don’t use reboot…
          it is violent… use shutdown -r (restart)
          to close the file system properly
          • FoziF Offline
            Fozi Project Sponsor @sdetweil
            @sdetweil why violent? As far as I know reboot is an alias for shutdown -r and does exactly the same. At least that is info I found in multiple posts on stackexchange. Could you elaborate a bit on that? Just eager to understand the difference and to avoid a mistake in the future.
              sdetweil @Fozi
              @Fozi i wasn’t aware of that… seems to me reboot always was forced hard…
              so… maybe you are right…
              • FoziF Offline
                @sdetweil no, it‘s not a hard shutoff. You can easily check the activity on the SD card when executing reboot before it powers off. Means it stops obviously process and writes necessary data to the card first, just like shutdown.
                  cornusandu
                  Thank you guys. It works now. I have a secondary issue. The calendar have on top a title , I called it “my calendar” , how can I increase the font size only if the title ? The events I already increased them but the title of the module is very small
                    Mykle1 Project Sponsor Module Developer @cornusandu
                    @cornusandu said in Autorestart:
                    Assuming the default calendar module, add this to your custom.css file and adjust accordingly…
                    .calendar .module-header {
                      color: yellow;
                      text-align: center;
                      font-size: 34px;
                      cornusandu @Mykle1
                      @Mykle1 thank you very much
                        thank you very much
                        I’m guessing that worked for you. Cool. Enjoy your experience.
                          Ben4x4 @Mykle1
                          @Mykle1 Similar issue but how can i increase the font size of the dates? Thanks
                            Mykle1 Project Sponsor Module Developer @Ben4x4
                            @Ben4x4
                            The dates? As in Thanksgiving and Christmas?
                            .calendar .title.bright {
                              font-size: 24px;
                            Keep in mind that the calendar module makes use of a table, including cells and line heights. If you make the text too large it will get ugly in a hurry. You might want to try zoom for the entire module. Just a thought.
