    Hi, there is a new Alexa Module
    98 Posts 13 Posters 80.6k Views 15 Watching
    • FoziF Offline
      Fozi Project Sponsor @techcoderun
      @techcoderun you just bought a new Dot and the mirror was detected?
      techcoderunT 1 Reply Last reply Reply Quote 0
      • techcoderunT Offline
        techcoderun @Fozi
        @Fozi Yes, literally just the new dot. But I had literally had the first Alexa that came out a few years ago, so it might of had some issues.
        FoziF 2 Replies Last reply Reply Quote 0
        • FoziF Offline
          @techcoderun That’s interesting. I am somewhat buffeled because even with the a the mirror isn’t detected.
            techcoderun @Fozi
            @Fozi Agreed, no clue what fixed the problem. I tried @Stoffbeuteluwe’s config file with the old Alexa, no luck. I received my Dot a few hours later, plugged it in, and voilà, “I’ve discovered 18 new devices.” My guess is maybe some outdated WiFi related hardware on the 1st Gen Alexa?
            • FoziF Offline
              @techcoderun As the cyberweek on Amazon comes closer and I need another Dot anyways, I‘m curious if I’ lol succeed, too.
              • FoziF Offline
                @techcoderun
                Suddenly my MM got detected on with my old Echo Dot Gen. 1 and without the installation of the other modules. I can‘t say why. Alexas feedback after scanning for new devices was misleading, too. She answers that no new devices were detected, but I found four new devices in the device list. Anyways, it seems to work and now I‘m thinking about a fitting use case for my needs.
                  BD0G
                  Hmm, Perhaps I need to revisit this module?
                    techcoderun
                    Now that everything is working, here is a video of this module in ACTION!
                    Alexa Controlled Magic Mirror
                    FoziF 1 Reply Last reply Reply Quote 1
                    • FoziF Offline
                      @techcoderun Thanks for the video, well done!
                      techcoderunT 1 Reply Last reply Reply Quote 1
                        techcoderun @Fozi
                        @Fozi Thank you!
                        • K Offline
                          KJHedges
                          Hi, if I currently have 8 pages configured. and these are discovered in alexa devices, then I wish to change the 8 pages to lets say 12. Is the discover devices part suppose to find then 12 pages.
                            JoChef2 Module Developer @KJHedges
                            @KJHedges Hi, yes that should work but then some other devices couldn’t work. For that I made some changes. You have to update the repository. For that run in /MagicMirror/modules/MMM-AlexaControl the following command: git pull. Then you can change the number of pages without any problems. But you have to delete all your devices one time after updating and discover them new.
                              sdetweil @JoChef2
                              @JoChef2 i did not add any pecific devices, and came up with refresh, shutdown, restart as devices…
                              not particularly useful… I will have 5 MM running… so need to address each…
                              my devices don’t support either tvservice or dpms… so I created MMM-SleepWake that does hide for those that need it. I am changing your module to support HIDE too…
                              • rubenixR Offline
                                rubenix
                                hello there, I have all set up with 6 pages on the mirror, page indicator and alexa discovered everything. lovely!
                                just one thing that bothers me: on my 2nd page I have my calendar with CalendarExt2. everyime I go ‘Alexa turn on page 2’ it switches correctly but calendar then (kind of duplicate) and overlaps with other modules on page rotate…
                                its like it duplicates the calendar and it overlaps over the next page rotation (and following ones too).
                                Its the clearest way to indicate my problem (english its not my first nor second spoken language) and i cannot post any picture to show it to yus…
                                im just wondering if someone have such behaviour…
                                or if any of you are using MMM-Pages, MMM-PagesIndicator, MMM-AlexaControl & MMM-CalendarExt2 working togheter…
                                cannot post my code here, im just reading this away from home and mirror switched off (damm it).
                                il post it sooner anyway (need to solve it to finish the MM)
                                S J 2 Replies Last reply Reply Quote 0
                                  sdetweil @rubenix
                                  @rubenix @Sean had a post a few days ago about pages and calext2.
                                  Don’t remember exact topic
                                    JoChef2 Module Developer @rubenix
                                    @rubenix Hi, have you tested MMM-Pages without my module and the Calender? Because my module only sends a notification to the Pages module. I think also there is a problem with the Calender module.
                                    • rubenixR Offline
                                      rubenix
                                      thanks @sdetweil will check for @Sean post!
                                      & thank to you too @JoChef2 , im pretty sure it has nothing to do with your module either…
                                      • rubenixR Offline
                                        rubenix
                                        I’ve seen Sean’s post abot MMM-Pages & CalendarExt2; thanks @sdetweil and Thanks @Sean (love your well documented modules) Well, @JoChef2 I might be wrong but maybe there’s something with AlexaControl but can’t say that @100%
                                        There’s obviously something wrong in my config and Im starting to suspect that its the interaction with AlexaControl module (I don’t know for sure yet). Anyway, If I leave the MMM-Pages rotate itself everythings works as expected; 60 second rotation and every single pages shows as it should as per my config (CalendarExt2 on page 2 too).
                                        The only “problem” its when I change to the second page from Alexa (page that must be showing the calendarExt2 module view). It switches to page & shows the scene but it duplicates the calendar & then after that it shows the calendar overlapped on Pages below.
                                        It does not happen with any other page; I can change to them with no problems at all and there’s no overlapping over any module after I call them with AlexaControl. It must be something easy but cannot find it at my own…
                                        Help here will be much appreciated; any thoughts @Sean @JoChef2 ?
                                        Config MMM-Pages:
                                                    module: "MMM-pages",
                                                     modules:
                                                            [["clock", "currentweather", "calendar", "weatherforecast", "MMM-MoonPhase", "MMM-LocalTemperature", "MMM-AirQuality", "MMM-CoinMarketCap", "MMM-EARTH", "nagios", "newsfeed"],
                                                            [ "clock", "currentweather", "MMM-MoonPhase"],
                                                            [ "MMM-PlexSlideshow"],
                                                            [ "clock", "currentweather", "MMM-AirQuality", "MMM-TomTomTraffic"],
                                                            [ "clock", "currentweather", "MMM-MoonPhase", "MMM-GmailFeed", "MMM-Covid19"]
                                                        fixed: ["MMM-page-indicator", "MMM-CalendarExt2", "MMM-Remote-Control", "MMM-Admin-Interface", "MMM-Alexa-Control"],
                                                        rotationTime: "60000",
                                                    module: "MMM-AlexaControl",
                                                    position: "top_center",
                                                    config:{
                                                    image: "true",
                                        	    height: "35",
                                                    width:   "35",
                                                    pm2ProcessName: "mm",
                                                    vcgencmd: true,
                                                    pages:'5',
                                        config MMM-CalendarExt2:
                                          module: 'MMM-CalendarExt2',
                                          position: "middle_center",
                                            rotateInterval: 0,
                                            updateInterval: 1000 * 60 * 60,
                                            calendars : [
                                                url: "mycalendar.ics",        //obviously my correct ics address here
                                            views: [
                                                mode: "month",
                                        		locale: "es_ES",
                                                slotCount: 1,
                                                calendars: ["Family"],
                                            scenes: [
                                                views:["VIEW1"],
                                                className: "fakeScene"
                                                views:["VIEW1"],
                                                views:["VIEW1"],
                                                views:["VIEW1"],
                                                views:["VIEW1"],
                                            notifications: {
                                              "PAGE_INCREMENT" : {
                                                exec: "sceneNext",
                                              "PAGE_DECREMENT" : {
                                                exec: "scenePrevious",
                                        Added on my custom css as per @Sean indications:
                                        .CX2.fakeScene {
                                          display:none;
                                        It must be easy as I only want to show one calendar in one view (nothing complicated), isn’t it?
                                        These are my three beauties for MM and would be nice to get them working together as per my needs:
                                        MMM-Pages
                                        MMM-CalendarExt2
                                        MMM-AlexaControl
                                        MMM-page-indicator
                                        sorry 4 actually :smiling_face_with_open_mouth_cold_sweat: :smiling_face_with_open_mouth_cold_sweat:
                                        Thanks in advance!
                                          @rubenix I don’t really know the MMM-CalenderExt2 module and first I was wondering why you use this config. I read a little bit the documention and I understand why you use this config. The problem is that you added the notifications “PAGE_INCREMENT” and “PAGE_DECREMENT”. My module use “PAGE_CHANGED” I found this in the documention. I hope that helps you.
                                          • rubenixR Offline
                                            rubenix
                                            thanks @JoChef2. So its actually an interaction with the two modules and my config; to be honest read that calendarExt2 usage page lots of times. do not know how to accomplish to solve that misconfiguration; so would think about a way to solve it. Am not a coder and thats why asked here.
                                            If I put the Calendarext2 on page0 on MMM-Pages (with no notifications) I can call the calendar from Alexa by stating an Alexa Routine to actually refresh the mirror (as it restarts it shows the first page which is the calendar) --> Tried that already and it works but would love to make it working the way I want to. So many test (try-error) coming :fearful_face:
                                            If anyone think of something I can try would be really appreciated :thumbs_up_light_skin_tone:
                                            @Sean can you throw any word here? Thanks so much; I’m quite confused…
                                            • 4 / 5
