    Hi, there is a new Alexa Module
    98 Posts 13 Posters 82.5k Views 15 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @BD0G
      @BD0G
                 module: 'MMM-page-indicator',
                 position: 'bottom_bar',
                 pages: 10,
      techcoderunT B 3 Replies Last reply
      • techcoderunT
        techcoderun @Stoffbeuteluwe
        @Stoffbeuteluwe Really appreciate the post! Everything appears to be working properly, but Alexa still does not detect my mirror. I have the 1st Gen Alexa, so its possible that is my issue. Thanks for all your help!
        • techcoderunT
          @Stoffbeuteluwe UPDATE: I purchased a new Alexa (Echo Dot) and I got everything working properly. Thanks again!
          StoffbeuteluweS FoziF 2 Replies Last reply
            BD0G @Stoffbeuteluwe
            @Stoffbeuteluwe Thanks for posting your config settings! Everytime I enable the AlexaControl Module My DarkSkyWeather Forecase, Lunartic, and US Holidays dont load. They just indicate “Loading”. When I pull the AlexaControl section out of the config.js they load without issue.
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @techcoderun
              @techcoderun perfect :slightly_smiling_face:
                sdetweil @BD0G
                @BD0G open the developers window, ctrl-shift-i, select the console tab, and see if there are any errors
                B 1 Reply Last reply
                  BD0G @sdetweil
                  @sdetweil Still have not been able to open the Dev Console using Ctrl- Shift -i. :(
                  • FoziF
                    Fozi Project Sponsor @techcoderun
                    @techcoderun you just bought a new Dot and the mirror was detected?
                    techcoderunT 1 Reply Last reply
                    • techcoderunT
                      techcoderun @Fozi
                      @Fozi Yes, literally just the new dot. But I had literally had the first Alexa that came out a few years ago, so it might of had some issues.
                      • FoziF
                        @techcoderun That’s interesting. I am somewhat buffeled because even with the a the mirror isn’t detected.
                        • techcoderunT
                          techcoderun @Fozi
                          @Fozi Agreed, no clue what fixed the problem. I tried @Stoffbeuteluwe’s config file with the old Alexa, no luck. I received my Dot a few hours later, plugged it in, and voilà, “I’ve discovered 18 new devices.” My guess is maybe some outdated WiFi related hardware on the 1st Gen Alexa?
                          FoziF 1 Reply Last reply
                          • FoziF
                            @techcoderun As the cyberweek on Amazon comes closer and I need another Dot anyways, I‘m curious if I’ lol succeed, too.
                            • FoziF
                              @techcoderun
                              Suddenly my MM got detected on with my old Echo Dot Gen. 1 and without the installation of the other modules. I can‘t say why. Alexas feedback after scanning for new devices was misleading, too. She answers that no new devices were detected, but I found four new devices in the device list. Anyways, it seems to work and now I‘m thinking about a fitting use case for my needs.
                                BD0G
                                Hmm, Perhaps I need to revisit this module?
                                • techcoderunT
                                  techcoderun
                                  Now that everything is working, here is a video of this module in ACTION!
                                  Alexa Controlled Magic Mirror
                                  • FoziF
                                    @techcoderun Thanks for the video, well done!
                                    • techcoderunT
                                      techcoderun @Fozi
                                      @Fozi Thank you!
                                      • K
                                        KJHedges
                                        Hi, if I currently have 8 pages configured. and these are discovered in alexa devices, then I wish to change the 8 pages to lets say 12. Is the discover devices part suppose to find then 12 pages.
                                        J 1 Reply Last reply
                                          JoChef2 Module Developer @KJHedges
                                          @KJHedges Hi, yes that should work but then some other devices couldn’t work. For that I made some changes. You have to update the repository. For that run in /MagicMirror/modules/MMM-AlexaControl the following command: git pull. Then you can change the number of pages without any problems. But you have to delete all your devices one time after updating and discover them new.
                                            sdetweil @JoChef2
                                            @JoChef2 i did not add any pecific devices, and came up with refresh, shutdown, restart as devices…
                                            not particularly useful… I will have 5 MM running… so need to address each…
                                            my devices don’t support either tvservice or dpms… so I created MMM-SleepWake that does hide for those that need it. I am changing your module to support HIDE too…
                                            • 4 / 5
