    Hi, there is a new Alexa Module
    98 Posts 13 Posters 82.5k Views 15 Watching
    • techcoderunT
      techcoderun @Stoffbeuteluwe
      @Stoffbeuteluwe Installed both, but no luck so far.
      • techcoderunT
        @Stoffbeuteluwe I’ll take a look, thanks!
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @BD0G
          @BD0G tonight I will send you my config for the other modules…pages and page indicator
            BD0G
            Thanks! It would be helpful to understand what commands can be issued using voice to Amazon Echo devices / Alexa and what they do.
            For instance if I say Alexa Turn off page one. Is that valid and what should I expect as a result?
            If I say Alexa Show Notification 1 does that do anything and if so -what?
            The instructions dont really go into usage examples (if you know what I mean?)
            Send tonight? Where are you located? Its 9:49 PM here presently LOL!
            StoffbeuteluweS 3 Replies Last reply
            • StoffbeuteluweS
              @BD0G from Germany
              techcoderunT 1 Reply Last reply
              • techcoderunT
                @Stoffbeuteluwe Thanks! The modules would be extremely helpful!
                • StoffbeuteluweS
                  @BD0G
                             module: 'MMM-pages',
                             modules:
                                 [[ "clock", "currentweather", "weatherforecast", "MMM-MyCalendar", "MMM-Lunartic", "MMM-MyWastePickup", "MMM-xiaomi", "MMM-Todoist", "MMM-Sonos", "newsfeed", "compliments", "MMM-AlexaControl"],
                                  [ "clock", "MMM-RandomPhoto"],
                                  [ "MMM-EasyBack" ],
                                  [ "MMM-ImagesPhotos" ],
                                  [ "MMM-Globe" ],
                                  [ "MMM-WordClock" ],
                                  [ "MMM-EyeCandy" ],
                                  [ "MMM-EasyPix" ],
                                  [ "clock","MMM-MyScoreboard", "MMM-MyStandings"],
                             fixed: [""],
                             rotationTime:"0",
                  • StoffbeuteluweS
                    @BD0G
                               module: 'MMM-page-indicator',
                               position: 'bottom_bar',
                               pages: 10,
                    techcoderunT B 3 Replies Last reply
                    • techcoderunT
                      @Stoffbeuteluwe Really appreciate the post! Everything appears to be working properly, but Alexa still does not detect my mirror. I have the 1st Gen Alexa, so its possible that is my issue. Thanks for all your help!
                      • techcoderunT
                        @Stoffbeuteluwe UPDATE: I purchased a new Alexa (Echo Dot) and I got everything working properly. Thanks again!
                        StoffbeuteluweS FoziF 2 Replies Last reply
                          BD0G @Stoffbeuteluwe
                          @Stoffbeuteluwe Thanks for posting your config settings! Everytime I enable the AlexaControl Module My DarkSkyWeather Forecase, Lunartic, and US Holidays dont load. They just indicate “Loading”. When I pull the AlexaControl section out of the config.js they load without issue.
                          • StoffbeuteluweS
                            Stoffbeuteluwe Project Sponsor @techcoderun
                            @techcoderun perfect :slightly_smiling_face:
                              sdetweil @BD0G
                              @BD0G open the developers window, ctrl-shift-i, select the console tab, and see if there are any errors
                              B 1 Reply Last reply
                                BD0G @sdetweil
                                @sdetweil Still have not been able to open the Dev Console using Ctrl- Shift -i. :(
                                • FoziF
                                  Fozi Project Sponsor @techcoderun
                                  @techcoderun you just bought a new Dot and the mirror was detected?
                                  • techcoderunT
                                    techcoderun @Fozi
                                    @Fozi Yes, literally just the new dot. But I had literally had the first Alexa that came out a few years ago, so it might of had some issues.
                                    • FoziF
                                      @techcoderun That’s interesting. I am somewhat buffeled because even with the a the mirror isn’t detected.
                                      • techcoderunT
                                        techcoderun @Fozi
                                        @Fozi Agreed, no clue what fixed the problem. I tried @Stoffbeuteluwe’s config file with the old Alexa, no luck. I received my Dot a few hours later, plugged it in, and voilà, “I’ve discovered 18 new devices.” My guess is maybe some outdated WiFi related hardware on the 1st Gen Alexa?
                                        FoziF 1 Reply Last reply
                                        • FoziF
                                          @techcoderun As the cyberweek on Amazon comes closer and I need another Dot anyways, I‘m curious if I’ lol succeed, too.
                                          • FoziF
                                            @techcoderun
                                            Suddenly my MM got detected on with my old Echo Dot Gen. 1 and without the installation of the other modules. I can‘t say why. Alexas feedback after scanning for new devices was misleading, too. She answers that no new devices were detected, but I found four new devices in the device list. Anyways, it seems to work and now I‘m thinking about a fitting use case for my needs.
                                            • 3 / 5
