    Hi, there is a new Alexa Module
    98 Posts 13 Posters 82.5k Views 15 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @techcoderun
      @techcoderun no, you don’t need to install wemo or fauxmo
        BD0G @Stoffbeuteluwe
        @Stoffbeuteluwe Some progress actually. I used your config. Had Alexa Discover Devices and she did discover 18 new devices. 10 of them were labeled Page 1-10
        Then there was some like PM2 Restart 0 . Refresh, etc.
        When I issue a command like Alexa Turn off page 4 . I get “Page 4 is not responding -please checks its power supply or network connection”
        I get that with every page I try.
        I need to define the pages , but need the exact files to modify for MMM-Pages and MMM-PageIndicator
        I have MMM-RemoteControl installed , but not the version that is custom for Alexa. I bet I need to yank that module and install the custom one.
        StoffbeuteluweS 1 Reply Last reply
        • techcoderunT
          techcoderun @Stoffbeuteluwe
          @Stoffbeuteluwe Installed both, but no luck so far.
          • techcoderunT
            @Stoffbeuteluwe I’ll take a look, thanks!
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @BD0G
              @BD0G tonight I will send you my config for the other modules…pages and page indicator
                BD0G
                Thanks! It would be helpful to understand what commands can be issued using voice to Amazon Echo devices / Alexa and what they do.
                For instance if I say Alexa Turn off page one. Is that valid and what should I expect as a result?
                If I say Alexa Show Notification 1 does that do anything and if so -what?
                The instructions dont really go into usage examples (if you know what I mean?)
                Send tonight? Where are you located? Its 9:49 PM here presently LOL!
                StoffbeuteluweS 3 Replies Last reply
                • StoffbeuteluweS
                  @BD0G from Germany
                  techcoderunT 1 Reply Last reply
                  • techcoderunT
                    @Stoffbeuteluwe Thanks! The modules would be extremely helpful!
                    • StoffbeuteluweS
                      @BD0G
                                 module: 'MMM-pages',
                                 modules:
                                     [[ "clock", "currentweather", "weatherforecast", "MMM-MyCalendar", "MMM-Lunartic", "MMM-MyWastePickup", "MMM-xiaomi", "MMM-Todoist", "MMM-Sonos", "newsfeed", "compliments", "MMM-AlexaControl"],
                                      [ "clock", "MMM-RandomPhoto"],
                                      [ "MMM-EasyBack" ],
                                      [ "MMM-ImagesPhotos" ],
                                      [ "MMM-Globe" ],
                                      [ "MMM-WordClock" ],
                                      [ "MMM-EyeCandy" ],
                                      [ "MMM-EasyPix" ],
                                      [ "clock","MMM-MyScoreboard", "MMM-MyStandings"],
                                 fixed: [""],
                                 rotationTime:"0",
                      • StoffbeuteluweS
                        @BD0G
                                   module: 'MMM-page-indicator',
                                   position: 'bottom_bar',
                                   pages: 10,
                        techcoderunT B 3 Replies Last reply
                        • techcoderunT
                          @Stoffbeuteluwe Really appreciate the post! Everything appears to be working properly, but Alexa still does not detect my mirror. I have the 1st Gen Alexa, so its possible that is my issue. Thanks for all your help!
                          • techcoderunT
                            @Stoffbeuteluwe UPDATE: I purchased a new Alexa (Echo Dot) and I got everything working properly. Thanks again!
                            StoffbeuteluweS FoziF 2 Replies Last reply
                              @Stoffbeuteluwe Thanks for posting your config settings! Everytime I enable the AlexaControl Module My DarkSkyWeather Forecase, Lunartic, and US Holidays dont load. They just indicate “Loading”. When I pull the AlexaControl section out of the config.js they load without issue.
                              • StoffbeuteluweS
                                @techcoderun perfect :slightly_smiling_face:
                                  sdetweil @BD0G
                                  @BD0G open the developers window, ctrl-shift-i, select the console tab, and see if there are any errors
                                  B 1 Reply Last reply
                                    BD0G @sdetweil
                                    @sdetweil Still have not been able to open the Dev Console using Ctrl- Shift -i. :(
                                    • FoziF
                                      Fozi Project Sponsor @techcoderun
                                      @techcoderun you just bought a new Dot and the mirror was detected?
                                      • techcoderunT
                                        techcoderun @Fozi
                                        @Fozi Yes, literally just the new dot. But I had literally had the first Alexa that came out a few years ago, so it might of had some issues.
                                        • FoziF
                                          @techcoderun That’s interesting. I am somewhat buffeled because even with the a the mirror isn’t detected.
                                          • techcoderunT
                                            techcoderun @Fozi
                                            @Fozi Agreed, no clue what fixed the problem. I tried @Stoffbeuteluwe’s config file with the old Alexa, no luck. I received my Dot a few hours later, plugged it in, and voilà, “I’ve discovered 18 new devices.” My guess is maybe some outdated WiFi related hardware on the 1st Gen Alexa?
                                            FoziF 1 Reply Last reply
                                            • 3 / 5
