    MMM-Lunartic not working
    17 Posts 6 Posters 6.4k Views 6 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @Mykle1
      @Mykle1 Works :thumbs_up_medium_skin_tone:
        BD0G
        Works! April till its operational? Thats ~6 months from now.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @BD0G
          @BD0G said in MMM-Lunartic not working:
          The module works with the fix I’ve provided. You won’t notice the difference, but yes, the USNO api is undergoing maintenance and has set that date for its completion.
          F 1 Reply Last reply
          • F
            ForeverBrewing @Mykle1
            @Mykle1 Thank you for the fix! and for the module, its awesome
              BD0G
              So you just pulled the static images from that USNO site and have them stored locally on the Pi. Then just call each static image as the phases of the moon change. Correct? With this approach it hardly seems like we are missing anything by not connecting to the USNO site and downloading them.
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @ForeverBrewing
                @ForeverBrewing said in MMM-Lunartic not working:
                Thank you for your kind words. I’m glad you enjoy it! :thumbsup:
                • Mykle1M
                  Visually, you’re not missing much. There is not a static image for every percentage of illumination, whether waxing or waning but it will do for now. However, I like knowing that the images are the most recent even though you can’t see a difference. When the API resumes, I’ll switch back. The fix will always be available. You can continue to use it even when the API resumes.
                  D 1 Reply Last reply
                    djarufes
                      djarufes @Mykle1
                      @Mykle1 After making the changes mentioned, for some odd reason, I’m just getting “When the Moon hits your eye…”
                      Not sure how to fix it :/
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @djarufes
                        @djarufes
                        The only change is swapping the MMM-Lunartic.js file with the one that is in the temporary fix folder.
                          djarufes @Mykle1
                          @Mykle1 It seems that changing single quotes to double quotes in the lines below made it work:
                          module: ‘MMM-Lunartic’,
                          position: ‘bottom_center’ ,
                          module: “MMM-Lunartic”,
                          position: “bottom_center” ,
                          Not sure why, but thanks! The moon looks incredible O_O
                          • Mykle1M
                            @djarufes said in MMM-Lunartic not working:
                            Glad you got it working. The config sample entry in the repo does not have double quotes on those so I don’t know where you got them from. :-)
