    Black screen instead of desktop after installing PIR sensor
    31 Posts 5 Posters 20.6k Views 6 Watching
    • 0
      09succotash @sdetweil
      @sdetweil Exactly. It seems to be running, but my wallpaper, taskbar, and icons are gone. Black screen shows in its place.
        sdetweil @09succotash
        @09succotash this is stretch or???
        lsb_release -a in the terminal window
        0 1 Reply Last reply Reply Quote 0
        • 0
          @sdetweil This is Raspbian Stretch, yep.
            @09succotash if u right click, does the popup menu have desktop preferences?
            is should
            https://forum.lxde.org/viewtopic.php?f=8&t=31338
            • 0
              @sdetweil This is what mine looks like. The white bar at the top of the screen is vnc viewer, not the screen. I’m using vnc viewer on my laptop.
                @09succotash ok, select Desktops or reconfigure
                • 0
                  @sdetweil Clicked reconfigure, nothing shows up. Clicked desktop, just shows a list of desktops. Shows 4 desktops. I’ve been through them all, shows the same black screen.
                    @09succotash in the terminal window, if u run sudo raspi-config
                    and look at boot options…
                    beyond that there are 1 few (hundred) posts about problems like this if u search google
                    • 0
                      @sdetweil Boot options, and then what?
                        @09succotash I might try to change desktop with login
                        • 0
                          @sdetweil Been there, done that, didn’t work. I’ve been searching Google for this issue, and came up short. Didn’t find much results, but I will try some more searching,
                            diccon
                            I had a similar problem when I used MMM-PIR-Sensor module. Everything had been working for about 6 months then I updated something and it stoped working. I re-installed everything several times and through a process of elimination and google searches it acmes down to this particular module.
                            I have now got it a working again by finding the latest update from a branched version of MMM-PIR-Sensor module.
                            I never did find the cause.
                            • L
                              Lightspeed
                              I had a simmilar Problem an had to use my old Backup after investigating hours. It seems that there are Problems between versions of node and electron. Do you have a white Window shortly and then the black desktop screen?
