    Black screen instead of desktop after installing PIR sensor
    31 Posts 5 Posters 20.0k Views 6 Watching
      sdetweil @09succotash
      @09succotash if u right click, does the popup menu have desktop preferences?
      is should
      https://forum.lxde.org/viewtopic.php?f=8&t=31338
      0 1 Reply Last reply Reply Quote 0
      • 0 Offline
        09succotash @sdetweil
        @sdetweil This is what mine looks like. The white bar at the top of the screen is vnc viewer, not the screen. I’m using vnc viewer on my laptop.
          @09succotash ok, select Desktops or reconfigure
          • 0 Offline
            @sdetweil Clicked reconfigure, nothing shows up. Clicked desktop, just shows a list of desktops. Shows 4 desktops. I’ve been through them all, shows the same black screen.
              @09succotash in the terminal window, if u run sudo raspi-config
              and look at boot options…
              beyond that there are 1 few (hundred) posts about problems like this if u search google
              • 0 Offline
                @sdetweil Boot options, and then what?
                  @09succotash I might try to change desktop with login
                  • 0 Offline
                    @sdetweil Been there, done that, didn’t work. I’ve been searching Google for this issue, and came up short. Didn’t find much results, but I will try some more searching,
                      diccon
                      I had a similar problem when I used MMM-PIR-Sensor module. Everything had been working for about 6 months then I updated something and it stoped working. I re-installed everything several times and through a process of elimination and google searches it acmes down to this particular module.
                      I have now got it a working again by finding the latest update from a branched version of MMM-PIR-Sensor module.
                      I never did find the cause.
                      • L Offline
                        Lightspeed
                        I had a simmilar Problem an had to use my old Backup after investigating hours. It seems that there are Problems between versions of node and electron. Do you have a white Window shortly and then the black desktop screen?
