    Black screen instead of desktop after installing PIR sensor
    31 Posts 5 Posters 21.0k Views 6 Watching
    • FoziF
      Fozi Project Sponsor @09succotash
      @09succotash As said, copy the whole MM-folder, eg. via scp to another PC and then reinstall Raspbian.
      I’m sorry that I can’t provide a more satisfying solution:disappointed_face:
      • 0
        09succotash
        • 0
          09succotash
          @Fozi Ahh, its ok. Thanks for your help, I’ll figure something out.
            sdetweil @09succotash
            @09succotash can u ssh into the machine?
            is MM running on pm2? do pm2 status, and if not stopped do pm2 stop for each line (use number or name)
            0 1 Reply Last reply
            • 0
              09succotash @sdetweil
              @sdetweil I cannot ssh into it. I am able to access the terminal though. MM is running on pm2, I just setup an autostart script for it. I don’t think MM is causing the issue, because the issue started just when I was setting up the PIR sensor.
                @09succotash but it can’t hurt to stop it…
                if you can get to terminal, then its not a desktop problem…
                • 0
                  @sdetweil I could only get to terminal, by right clicking somewhere on the screen. I tried stopping MM using pm2, didn’t have any effect.
                    @09succotash said in Black screen instead of desktop after installing PIR sensor:
                    ok, so desktop is running, even tho u might not be able to see it…
                    • 0
                      @sdetweil Exactly. It seems to be running, but my wallpaper, taskbar, and icons are gone. Black screen shows in its place.
                        @09succotash this is stretch or???
                        lsb_release -a in the terminal window
                        • 0
                          @sdetweil This is Raspbian Stretch, yep.
                            @09succotash if u right click, does the popup menu have desktop preferences?
                            is should
                            https://forum.lxde.org/viewtopic.php?f=8&t=31338
                            • 0
                              @sdetweil This is what mine looks like. The white bar at the top of the screen is vnc viewer, not the screen. I’m using vnc viewer on my laptop.
                              S 2 Replies Last reply
                                @09succotash ok, select Desktops or reconfigure
                                • 0
                                  @sdetweil Clicked reconfigure, nothing shows up. Clicked desktop, just shows a list of desktops. Shows 4 desktops. I’ve been through them all, shows the same black screen.
                                    @09succotash in the terminal window, if u run sudo raspi-config
                                    and look at boot options…
                                    beyond that there are 1 few (hundred) posts about problems like this if u search google
                                    • 0
                                      @sdetweil Boot options, and then what?
                                        @09succotash I might try to change desktop with login
                                        • 0
                                          @sdetweil Been there, done that, didn’t work. I’ve been searching Google for this issue, and came up short. Didn’t find much results, but I will try some more searching,
                                            diccon
                                            I had a similar problem when I used MMM-PIR-Sensor module. Everything had been working for about 6 months then I updated something and it stoped working. I re-installed everything several times and through a process of elimination and google searches it acmes down to this particular module.
                                            I have now got it a working again by finding the latest update from a branched version of MMM-PIR-Sensor module.
                                            I never did find the cause.
