    MMM-Calendar Position
    6 Posts 3 Posters 1.8k Views 3 Watching
      sdetweil @rastaa
      @rastaa tell us more… show us the config setting
        rastaa
        i edited the custom.css file:
        .clock{
        position: relative;
        left: 100px;
        top: 20px;
        .calendar{
        position: relative;
        left: 100px;
        top: 100px;
        I changed the pixlenumbers often and nothing changed. The clock works perfectly
          sdetweil @rastaa
          @rastaa so, there are 2 position settings…
          in config.js is the gross position
          in custom .css is smaller adjustments from there…
          also, not every module has a BIG definition… calendar has 4
          from readme
          symbolClass	Add a class to the cell of symbol.
          titleClass	Add a class to the title's cell.
          timeClass	Add a class to the time's cell.
          tableClass
          this last one YOU need to name in the config.js
          and then USE in the custom.css
          you can also use the module position
          as shown in index.html
          	< div class="region fullscreen below">< div class="container">< /div>< /div>
          	< div class="region top bar">
          		< div class="region top left">< div class="container">< /div>< /div>
          		< div class="region top center"><d iv class="container">< /div>< /div>
          		< div class="region top right">< div class="container">< /div>< /div>
          	< /div>
          	< div class="region upper third"><div class="container">< /div>< /div>
          	< div class="region middle center"><div class="container">< /div>< /div>
          	< div class="region lower third"><div class="container">< br/>< /div>< /div>
          	< div class="region bottom bar">
          		< div class="region bottom left">< div class="container">< /div>< /div>
          		< div class="region bottom center"><  div class="container">< /div>< /div>
          		< div class="region bottom right">< div class="container">< /div>< /div>
          	< /div>
          	< div class="region fullscreen above">< div class="container">< /div>< /div>
          the space in the names is replaced by an underscore when u use it in config.js
          bottom center = bottom_center
            rastaa
            thank you very much :)
            I am a newbie, sorry for that.
            So i have to add all 4 classes in the custom.css and add some pixles ?
            I just want the whole calendar to be 100px more to the right.
              @rastaa
              In that case, assuming you mean the default “calendar” module, these values should move the entire module. Adjust to your liking in the custom.css file.
              .calendar {
                margin-top: 0px;
                margin-bottom: 0px;
                margin-left: 0px;
                margin-right: 0px;
