    V2.10.0
    Scheduled Pinned Locked Moved MagicMirror
    2 Posts 2 Posters 3.2k Views 2 Watching
    • MichMichM Offline
      MichMich
      ♥ Donate: Enjoying MagicMirror²? Please consider a donation! With your help we can continue to improve the MagicMirror² core.
      https://github.com/MichMich/MagicMirror/releases/tag/v2.10.0
      [2.10.0] - 2020-01-01
      Special thanks to @sdetweil for all his great contributions!
      ℹ️ Note: This update uses new dependencies. Please update using the following command: git pull && npm install.
      Added
      • Timestamps in log output.
      • Padding in dateheader mode of the calendar module.
      • New upgrade script to help users consume regular updates installers/upgrade-script.sh.
      • New script to help setup pm2, without install installers/fixuppm2.sh.
      Updated
      • Updated lower bound of lodash and helmet dependencies for security patches.
      • Updated compliments.js to handle newline in text, as textfields to not interpolate contents.
      • Updated raspberry.sh installer script to handle new platform issues, split node/npm, pm2, and screen saver changes.
      • Improve handling for armv6l devices, where electron support has gone away, add optional serveronly config option.
      • Improved run-start.sh to handle for serveronly mode, by choice, or when electron not available.
      • Only check for xwindows running if not on macOS.
      Fixed
      • Fixed issue in weatherforecast module where predicted amount of rain was not using the decimal symbol specified in config.js.
      • Module header now updates correctly, if a module need to dynamically show/hide its header based on a condition.
      • Fix handling of config.js for serverOnly mode commented out.
      • Fixed issue in calendar module where the debug script didn’t work correctly with authentication.
      • Fixed issue that some full day events were not correctly recognized as such.
      • Display full day events lasting multiple days as happening today instead of some days ago if they are still ongoing.
        sdetweil @MichMich
        @MichMich please use the new update script. Not just pull, see the new update instructions
        see here
        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
        official version has a bug, testing fix, hopefully hotifx
