    Problem with updating to 2.10.0 from 2.9.0 using update script
    15 Posts 3 Posters 6.9k Views 3 Watching
    • O Offline
      outlying
      so I’m quitte fresh user and I installed 2.9.0 version just few days ago, started doing some config edits and suddenly I got update info on my mirror today, cool
      So I went to https://github.com/MichMich/MagicMirror/blob/master/README.md#updating for update steps, done first (dry/test run) and failed on actual update which resulted with
      error: The following untracked working tree files would be overwritten by merge: installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd you should examine and resolve them
      Well, I’ve done full backup of my directory so I assumed that I can risk deletion of installers/dumpactivemodules.js, so I did
      rm ~/MagicMirror/installers/dumpactivemodules.js
      and run update script again
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)" apply
      but it resulted with the same error The following untracked working tree files would be overwritten by merge: installers/dumpactivemodules.js
      So obviously something is wrong with update script as far as I can tell, I changed almost nothing in my MM, only config + I started doing some custom CSS so nothing out of ordinary IMO
        yeh, a bug got thru … i have a temporary updated script
        see here.
        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
        also posted after Mich’s topic of the version update yesterday…
        https://forum.magicmirror.builders/topic/11899/v2-10-0
        • O Offline
          outlying
          Unluckily scripts under 1st post
          https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing/1
          have the same issue at the ones I already tried, I’m not sure if I should go through whole thread, I admit I didn’t
            sdetweil @outlying
            @outlying show me the log file, ~/MagicMirror/installers/upgrade.log
              @sdetweil u need to erase the ~/MagicMirror/installers/dumpactivemodules.js file…
              then run the updated script.
              sorry, forgot that
              • O Offline
                outlying
                Oh, my bad, I just deleted file rm ~/MagicMirror/installers/dumpactivemodules.js
                and I did run update script, with result
                the log will be /home/pi/MagicMirror/installers/upgrade.log
                No LSB modules are available.
                doing test run = false
                saving custom.css
                upgrading from version 2.9.0 to 2.10.0
                fetching latest revisions
                apply: line 244: npm: command not found
                no modules found needing npm refresh
                restoring custom.css
                So I restarted pm2 restart mm but now MM is in error, according to pm2 status
                Running standard pm2 start mm.sh does not start MM anymore, it just go to errored status
                  sdetweil @outlying
                  @outlying but npm had to be installed before… I just use it
                  that line 244 is npm install
                  and I don’t know where the 'apply: ’ came from
                    this is what my MM/installers/upgrade.log says
                    Upgrade started - Thu Jan  2 06:29:19 CST 2020
                    system is Linux raspberrypi4 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                    the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                    user requested to apply changes
                    saving custom.css
                    remote name = origin
                    git fetch rc=0
                    current branch = master
                    On branch master
                    Your branch is behind 'origin/master' by 2832 commits, and can be fast-forwarded.
                      (use "git pull" to update your local branch)
                    Changes to be committed:
                      (use "git reset HEAD <file>..." to unstage)
                    	deleted:    css/custom.css
                      (use "git add <file>..." to update what will be committed)
                      (use "git checkout -- <file>..." to discard changes in working directory)
                    	modified:   package-lock.json
                    	modified:   package.json
                    Untracked files:
                      (use "git add <file>..." to include in what will be committed)
                    	css/save_custom.css
                    	somefile
                    there are 2 local files that are different than the master repo
                       package-lock.json
                       package.json
                    save/restore files selection = n
                    restoring package-lock.json from repo
                    restoring package.json from repo
                    test merge result rc='' , if empty, no conflicts
                    executing merge, apply specified
                    merge result rc= 0
                     Updating 500147e..b595cdd Fast-forward  .gitignore
                        6 -  .snyk
                       14 -  .travis.yml
                        8 +-  CHANGELOG.md
                       28 +-  README.md
                       17 +-  config/config.js.sample
                        7 +-  css/custom.css
                       14 -  installers/dumpactivemodules.js
                       15 +  installers/fixuppm2.sh
                      183 +  installers/raspberry.sh
                      560 ++-  installers/screensaveroff.sh
                      101 +  installers/upgrade-script.sh
                      361 ++  js/app.js
                        6 +  js/main.js
                       17 +-  .../node_helper/index.js => js/node_helper.js
                        2 +-  js/server.js
                        2 +-  modules/default/calendar/calendar.js
                        1 +  modules/default/calendar/calendarfetcher.js
                        7 +-  modules/default/calendar/debug.js
                        4 +-  modules/default/compliments/compliments.js
                       39 +-  modules/default/weatherforecast/weatherforecast.js
                        4 +-  package-lock.json
                     4187 +++++++++++---------  package.json
                       17 +-  run-start.sh
                       64 +-  tests/e2e/modules/weather_spec.js
                      138 +-  tests/e2e/vendor_spec.js
                        5 +-  untrack-css.sh
                        2 +-  vendor/package-lock.json
                        2 +-  28 files changed, 3648 insertions(+), 2163 deletions(-)  delete mode 100644 .snyk  delete mode 100644 css/custom.css
                    create mode 100644 installers/dumpactivemodules.js
                    create mode 100755 installers/fixuppm2.sh
                    mode change 100644 => 100755 installers/raspberry.sh
                    create mode 100755 installers/screensaveroff.sh
                    create mode 100755 installers/upgrade-script.sh  rename modules/node_modules/node_helper/index.js => js/node_helper.js (98%)
                    mode change 100644 => 100755 run-start.sh
                    processor architecture is armv7l
                    • O Offline
                      outlying
                      @sdetweil I don’t know how to respond in that case, ofc I have to had it installed earlier in order for MM to work, but right now it seems system is not seeing it, only bash: npm: command not found sooooo … I think since it’s fresh install I will reinstall everything
                        sdetweil @outlying
                        @outlying close that terminal window and reopen it, npm should not have been removed…
                        • O Offline
                          outlying @sdetweil
                          @sdetweil I’ve done it right away it but it’s not there anymore, somehow it’s messed up
                            sdetweil @outlying
                            @outlying weird… sudo apt-get install npm
                            then sudo npm i -g npm to get latest
                            node -v
                            and
                            npm -v
                            to verify levels
                              ChrizZz
                              sorry to use the same topic. I have also trouble with the update to 2.10.0. The update script works, but I still have the notification that there is an update for MM. But the update log ends with “Upgrade ended - Do Jan 2 20:24:45 CET 2020”.
                              • O Offline
                                outlying
                                @sdetweil I appreciate your fast responses :-) it’s really inspiring, but it would be way easier for me to set it up again in a matter of few minutes instead of trying to figure out what went wrong
                                Right now I have lock on dpkg files
                                E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
                                E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
                                So it all messed up :-/ this is very fresh setup so I really don’t mind purging it
                                  sdetweil @outlying
                                  @outlying save your magicmirror config.js at least!
