    328 Posts 27 Posters 727.1k Views 24 Watching
      surger13 Project Sponsor @sdetweil
      pi@MagicMirrorPi:~/MagicMirror $ locale
      LANG=de_DE.UTF-8
      LANGUAGE=
      LC_CTYPE="de_DE.UTF-8"
      LC_NUMERIC="de_DE.UTF-8"
      LC_TIME="de_DE.UTF-8"
      LC_COLLATE="de_DE.UTF-8"
      LC_MONETARY="de_DE.UTF-8"
      LC_MESSAGES="de_DE.UTF-8"
      LC_PAPER="de_DE.UTF-8"
      LC_NAME="de_DE.UTF-8"
      LC_ADDRESS="de_DE.UTF-8"
      LC_TELEPHONE="de_DE.UTF-8"
      LC_MEASUREMENT="de_DE.UTF-8"
      LC_IDENTIFICATION="de_DE.UTF-8"
      LC_ALL=
        sdetweil @surger13
        @surger13 wild… a THIRD way to indicate language setting
        want to try the script again?
          @sdetweil said in new update/upgrade script, ready for testing:
          I did. Unfortunately, no change.
          but thanks for your efforts.
          evroomE S 3 Replies Last reply Reply Quote 0
          • evroomE Offline
            evroom @surger13
            @surger13
            You can try adding the missing variables
            $ sudo cat /etc/default/locale
            LANGUAGE=de_DE.UTF-8
            LC_ALL=de_DE.UTF-8
            And / or do a reconfigure:
            $ sudo dpkg-reconfigure locales
            Make sure de_DE.UTF-8 UTF-8 is checked.
            Tab to OK
            Tab to OK
            $ sudo reboot
            MagicMirror version: 2.37.0
            • evroomE Offline
              evroom @sdetweil
              yeh, the website with the file broke the download…
              Version 3.0.13 only takes 2 minutes.
              Strangely enough version 3.1.13 takes ages and causes a timeout / connection reset.
              Perhaps a local issue, although I have 57Mbps download.
              Is there a reason for 3.1.13 and not @latest ?
              Dependencies perhaps ?
              Not that I want or need it, just asking.
                sdetweil @evroom
                @evroom no… i need to handle it, can’t expect users to do stuff to make the script work…
                  sdetweil @surger13
                  @surger13 willing to send me the log again?
                    sdetweil @evroom
                    @evroom Is there a reason for 3.1.13 and not @latest ?
                    should be 3.0.13
                    yes, V7 doesn’t run right,
                    v6 needs some other changes,
                    V3 is the last one on armv6 (pi 0)
                    • evroomE Offline
                      evroom
                      Okay, just that you know that my current 2.8.0 to 2.10.0 upgrade is trying to get 3.1.13.
                      > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
                      > node install.js
                      Downloading tmp-21342-0-electron-v3.1.13-linux-armv7l.zip
                      [==========================>                  ] 61.8% of 45.65 MB (720.69 B/s)
                      This was in the log for the 2.9.0 to 2.10.0 upgrade:
                      > node install.js
                      Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip
                      Error: read ECONNRESET
                      /home/pi/MagicMirror/node_modules/electron/install.js:49
                        throw err
                          at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                      Do you catch and evaluate the output or only the exit value?
                        sdetweil @evroom
                        @evroom weird… the package.json says
                        "electron": "^3.0.13"
                        same as we have been running on for a couple years now
                          sdetweil @evroom
                          @evroom i don’t on the npm install… expect it to work… as we’ve been thru test on this for a long time.
                            sdetweil @surger13
                            @surger13 ok, looks like we have to fight the manual way
                            do
                            git stash
                            git merge
                            npm install
                            C S 2 Replies Last reply Reply Quote 0
                            • evroomE Offline
                              evroom @sdetweil
                              Which exact package.json would that be?
                              Perhaps mine tells to use 3.1.13?
                              Although:
                              pi@raspberrypi:~ $ grep electron ~/MagicMirror/package.json
                                "main": "js/electron.js",
                                sdetweil @evroom
                                @evroom ah, it say CLOSE TO 3.0.13 (the hat char), not exactly 3.0.13
                                so, do the manual step
                                npm install electron@3.0.13
                                evroomE 2 Replies Last reply Reply Quote 0
                                • evroomE Offline
                                  evroom @sdetweil
                                  ~version “Approximately equivalent to version”, will update you to the next patch version.
                                  ^version Will update you to the next minor version.
                                  version Will update you to the exact given version.
                                  • evroomE Offline
                                    evroom @sdetweil
                                    Sam, shall I update my ~/MagicMirror/package.json file and try again?
                                    Edit:
                                    Just did.
                                    It says I am on 2.10.0 already, even though it was interrupted on the electro download.
                                    How can I force the upgrade or make it believe 2.9.0 is still active?
                                    In the package.json file?
                                    Edit 2:
                                    Changed from 2.10.0 to 2.9.0 and now it is running.
                                      sdetweil @evroom
                                      @evroom no… just issue the command on the commandline
                                      Is this a pi 0?
                                        ChrizZz @sdetweil
                                        do
                                        git stash
                                        git merge
                                        npm install
                                        took the manual way too because of the same probs. Now my Pi is downloading the electron v3.1.13 version with 3.01 kB/s. can I stop the installation process to update electron manually?
                                        S evroomE 2 Replies Last reply Reply Quote 0
                                          sdetweil @ChrizZz
                                          @ChrizZz I do not know
                                            do
                                            git stash
                                            git merge
                                            npm install
                                            the fight was an easy one. everything worked. just had to restore the custom.css from a backup.
                                            thanks again Sam
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
