    328 Posts 27 Posters 726.9k Views 24 Watching
      sdetweil @surger13
      @surger13 ok, how about output of
      locale
      thx…
        surger13 Project Sponsor @sdetweil
        pi@MagicMirrorPi:~/MagicMirror $ locale
        LANG=de_DE.UTF-8
        LANGUAGE=
        LC_CTYPE="de_DE.UTF-8"
        LC_NUMERIC="de_DE.UTF-8"
        LC_TIME="de_DE.UTF-8"
        LC_COLLATE="de_DE.UTF-8"
        LC_MONETARY="de_DE.UTF-8"
        LC_MESSAGES="de_DE.UTF-8"
        LC_PAPER="de_DE.UTF-8"
        LC_NAME="de_DE.UTF-8"
        LC_ADDRESS="de_DE.UTF-8"
        LC_TELEPHONE="de_DE.UTF-8"
        LC_MEASUREMENT="de_DE.UTF-8"
        LC_IDENTIFICATION="de_DE.UTF-8"
        LC_ALL=
          sdetweil @surger13
          @surger13 wild… a THIRD way to indicate language setting
          want to try the script again?
            @sdetweil said in new update/upgrade script, ready for testing:
            I did. Unfortunately, no change.
            but thanks for your efforts.
            evroomE S 3 Replies Last reply Reply Quote 0
            • evroomE Offline
              evroom @surger13
              @surger13
              You can try adding the missing variables
              $ sudo cat /etc/default/locale
              LANGUAGE=de_DE.UTF-8
              LC_ALL=de_DE.UTF-8
              And / or do a reconfigure:
              $ sudo dpkg-reconfigure locales
              Make sure de_DE.UTF-8 UTF-8 is checked.
              Tab to OK
              Tab to OK
              $ sudo reboot
              MagicMirror version: 2.37.0
              • evroomE Offline
                evroom @sdetweil
                yeh, the website with the file broke the download…
                Version 3.0.13 only takes 2 minutes.
                Strangely enough version 3.1.13 takes ages and causes a timeout / connection reset.
                Perhaps a local issue, although I have 57Mbps download.
                Is there a reason for 3.1.13 and not @latest ?
                Dependencies perhaps ?
                Not that I want or need it, just asking.
                  sdetweil @evroom
                  @evroom no… i need to handle it, can’t expect users to do stuff to make the script work…
                    sdetweil @surger13
                    @surger13 willing to send me the log again?
                      sdetweil @evroom
                      @evroom Is there a reason for 3.1.13 and not @latest ?
                      should be 3.0.13
                      yes, V7 doesn’t run right,
                      v6 needs some other changes,
                      V3 is the last one on armv6 (pi 0)
                      • evroomE Offline
                        evroom
                        Okay, just that you know that my current 2.8.0 to 2.10.0 upgrade is trying to get 3.1.13.
                        > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
                        > node install.js
                        Downloading tmp-21342-0-electron-v3.1.13-linux-armv7l.zip
                        [==========================>                  ] 61.8% of 45.65 MB (720.69 B/s)
                        This was in the log for the 2.9.0 to 2.10.0 upgrade:
                        > node install.js
                        Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip
                        Error: read ECONNRESET
                        /home/pi/MagicMirror/node_modules/electron/install.js:49
                          throw err
                            at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                        Do you catch and evaluate the output or only the exit value?
                          sdetweil @evroom
                          @evroom weird… the package.json says
                          "electron": "^3.0.13"
                          same as we have been running on for a couple years now
                            sdetweil @evroom
                            @evroom i don’t on the npm install… expect it to work… as we’ve been thru test on this for a long time.
                              sdetweil @surger13
                              @surger13 ok, looks like we have to fight the manual way
                              do
                              git stash
                              git merge
                              npm install
                              C S 2 Replies Last reply Reply Quote 0
                              • evroomE Offline
                                evroom @sdetweil
                                Which exact package.json would that be?
                                Perhaps mine tells to use 3.1.13?
                                Although:
                                pi@raspberrypi:~ $ grep electron ~/MagicMirror/package.json
                                  "main": "js/electron.js",
                                  sdetweil @evroom
                                  @evroom ah, it say CLOSE TO 3.0.13 (the hat char), not exactly 3.0.13
                                  so, do the manual step
                                  npm install electron@3.0.13
                                  evroomE 2 Replies Last reply Reply Quote 0
                                  • evroomE Offline
                                    evroom @sdetweil
                                    ~version “Approximately equivalent to version”, will update you to the next patch version.
                                    ^version Will update you to the next minor version.
                                    version Will update you to the exact given version.
                                    • evroomE Offline
                                      evroom @sdetweil
                                      Sam, shall I update my ~/MagicMirror/package.json file and try again?
                                      Edit:
                                      Just did.
                                      It says I am on 2.10.0 already, even though it was interrupted on the electro download.
                                      How can I force the upgrade or make it believe 2.9.0 is still active?
                                      In the package.json file?
                                      Edit 2:
                                      Changed from 2.10.0 to 2.9.0 and now it is running.
                                        sdetweil @evroom
                                        @evroom no… just issue the command on the commandline
                                        Is this a pi 0?
                                          ChrizZz @sdetweil
                                          do
                                          git stash
                                          git merge
                                          npm install
                                          took the manual way too because of the same probs. Now my Pi is downloading the electron v3.1.13 version with 3.01 kB/s. can I stop the installation process to update electron manually?
                                          S evroomE 2 Replies Last reply Reply Quote 0
                                            sdetweil @ChrizZz
                                            @ChrizZz I do not know
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
