    328 Posts 27 Posters 727.1k Views 24 Watching
      surger13 Project Sponsor @sdetweil
      both empty.
      pi@MagicMirrorPi:~/MagicMirror $ echo $LC_ALL
      pi@MagicMirrorPi:~/MagicMirror $ locale | grep LANGUAGE
      LANGUAGE=
        sdetweil @surger13
        @surger13 weird, but the system is in german… so the message I was looking for the output of
        git status, with the content of ‘modified’ in english
        how about the output of
        alias
          yes the language is german.
          pi@MagicMirrorPi:~/MagicMirror $ alias
          alias egrep='egrep --color=auto'
          alias fgrep='fgrep --color=auto'
          alias grep='grep --color=auto'
          alias ls='ls --color=auto'
            sdetweil @surger13
            @surger13 ok, how about output of
            locale
            thx…
              LANG=de_DE.UTF-8
              LANGUAGE=
              LC_CTYPE="de_DE.UTF-8"
              LC_NUMERIC="de_DE.UTF-8"
              LC_TIME="de_DE.UTF-8"
              LC_COLLATE="de_DE.UTF-8"
              LC_MONETARY="de_DE.UTF-8"
              LC_MESSAGES="de_DE.UTF-8"
              LC_PAPER="de_DE.UTF-8"
              LC_NAME="de_DE.UTF-8"
              LC_ADDRESS="de_DE.UTF-8"
              LC_TELEPHONE="de_DE.UTF-8"
              LC_MEASUREMENT="de_DE.UTF-8"
              LC_IDENTIFICATION="de_DE.UTF-8"
              LC_ALL=
                sdetweil @surger13
                @surger13 wild… a THIRD way to indicate language setting
                want to try the script again?
                  @sdetweil said in new update/upgrade script, ready for testing:
                  I did. Unfortunately, no change.
                  but thanks for your efforts.
                  evroomE S 3 Replies Last reply Reply Quote 0
                  • evroomE Offline
                    evroom @surger13
                    @surger13
                    You can try adding the missing variables
                    $ sudo cat /etc/default/locale
                    LANGUAGE=de_DE.UTF-8
                    LC_ALL=de_DE.UTF-8
                    And / or do a reconfigure:
                    $ sudo dpkg-reconfigure locales
                    Make sure de_DE.UTF-8 UTF-8 is checked.
                    Tab to OK
                    Tab to OK
                    $ sudo reboot
                    MagicMirror version: 2.37.0
                    • evroomE Offline
                      evroom @sdetweil
                      yeh, the website with the file broke the download…
                      Version 3.0.13 only takes 2 minutes.
                      Strangely enough version 3.1.13 takes ages and causes a timeout / connection reset.
                      Perhaps a local issue, although I have 57Mbps download.
                      Is there a reason for 3.1.13 and not @latest ?
                      Dependencies perhaps ?
                      Not that I want or need it, just asking.
                        sdetweil @evroom
                        @evroom no… i need to handle it, can’t expect users to do stuff to make the script work…
                          sdetweil @surger13
                          @surger13 willing to send me the log again?
                            sdetweil @evroom
                            @evroom Is there a reason for 3.1.13 and not @latest ?
                            should be 3.0.13
                            yes, V7 doesn’t run right,
                            v6 needs some other changes,
                            V3 is the last one on armv6 (pi 0)
                            • evroomE Offline
                              evroom
                              Okay, just that you know that my current 2.8.0 to 2.10.0 upgrade is trying to get 3.1.13.
                              > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
                              > node install.js
                              Downloading tmp-21342-0-electron-v3.1.13-linux-armv7l.zip
                              [==========================>                  ] 61.8% of 45.65 MB (720.69 B/s)
                              This was in the log for the 2.9.0 to 2.10.0 upgrade:
                              > node install.js
                              Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip
                              Error: read ECONNRESET
                              /home/pi/MagicMirror/node_modules/electron/install.js:49
                                throw err
                                  at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                              Do you catch and evaluate the output or only the exit value?
                                sdetweil @evroom
                                @evroom weird… the package.json says
                                "electron": "^3.0.13"
                                same as we have been running on for a couple years now
                                  sdetweil @evroom
                                  @evroom i don’t on the npm install… expect it to work… as we’ve been thru test on this for a long time.
                                    sdetweil @surger13
                                    @surger13 ok, looks like we have to fight the manual way
                                    do
                                    git stash
                                    git merge
                                    npm install
                                    C S 2 Replies Last reply Reply Quote 0
                                    • evroomE Offline
                                      evroom @sdetweil
                                      Which exact package.json would that be?
                                      Perhaps mine tells to use 3.1.13?
                                      Although:
                                      pi@raspberrypi:~ $ grep electron ~/MagicMirror/package.json
                                        "main": "js/electron.js",
                                        sdetweil @evroom
                                        @evroom ah, it say CLOSE TO 3.0.13 (the hat char), not exactly 3.0.13
                                        so, do the manual step
                                        npm install electron@3.0.13
                                        evroomE 2 Replies Last reply Reply Quote 0
                                        • evroomE Offline
                                          evroom @sdetweil
                                          ~version “Approximately equivalent to version”, will update you to the next patch version.
                                          ^version Will update you to the next minor version.
                                          version Will update you to the exact given version.
                                          • evroomE Offline
                                            evroom @sdetweil
                                            Sam, shall I update my ~/MagicMirror/package.json file and try again?
                                            Edit:
                                            Just did.
                                            It says I am on 2.10.0 already, even though it was interrupted on the electro download.
                                            How can I force the upgrade or make it believe 2.9.0 is still active?
                                            In the package.json file?
                                            Edit 2:
                                            Changed from 2.10.0 to 2.9.0 and now it is running.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
