    328 Posts 27 Posters 740.6k Views 24 Watching
    • evroomE
      evroom
      Sam, the 2.9.0 threw an error on the electron update, but then continued.
      I am apparently on 2.10.0 now, but probably I am not running the latest electron version.
      pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
        "version": "2.10.0",
      This was the part where the error occured:
      > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip
      Error: read ECONNRESET
      /home/pi/MagicMirror/node_modules/electron/install.js:49
        throw err
          at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
      What would be the correct command to update electron and from which directory?
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom said in new update/upgrade script, ready for testing:
        yeh, the website with the file broke the download…
        u can try
        npm install electron@3.0.13
          sdetweil @surger13
          @surger13 thanks for the log…
          can u do
          echo $LC_ALL
          and
          locale | grep LANGUAGE
          thx
            surger13 Project Sponsor @sdetweil
            both empty.
            pi@MagicMirrorPi:~/MagicMirror $ echo $LC_ALL
            pi@MagicMirrorPi:~/MagicMirror $ locale | grep LANGUAGE
            LANGUAGE=
              sdetweil @surger13
              @surger13 weird, but the system is in german… so the message I was looking for the output of
              git status, with the content of ‘modified’ in english
              how about the output of
              alias
                yes the language is german.
                pi@MagicMirrorPi:~/MagicMirror $ alias
                alias egrep='egrep --color=auto'
                alias fgrep='fgrep --color=auto'
                alias grep='grep --color=auto'
                alias ls='ls --color=auto'
                  sdetweil @surger13
                  @surger13 ok, how about output of
                  locale
                  thx…
                    LANG=de_DE.UTF-8
                    LANGUAGE=
                    LC_CTYPE="de_DE.UTF-8"
                    LC_NUMERIC="de_DE.UTF-8"
                    LC_TIME="de_DE.UTF-8"
                    LC_COLLATE="de_DE.UTF-8"
                    LC_MONETARY="de_DE.UTF-8"
                    LC_MESSAGES="de_DE.UTF-8"
                    LC_PAPER="de_DE.UTF-8"
                    LC_NAME="de_DE.UTF-8"
                    LC_ADDRESS="de_DE.UTF-8"
                    LC_TELEPHONE="de_DE.UTF-8"
                    LC_MEASUREMENT="de_DE.UTF-8"
                    LC_IDENTIFICATION="de_DE.UTF-8"
                    LC_ALL=
                      sdetweil @surger13
                      @surger13 wild… a THIRD way to indicate language setting
                      want to try the script again?
                        @sdetweil said in new update/upgrade script, ready for testing:
                        I did. Unfortunately, no change.
                        but thanks for your efforts.
                        evroomE S 3 Replies Last reply Reply Quote 0
                        • evroomE
                          evroom @surger13
                          @surger13
                          You can try adding the missing variables
                          $ sudo cat /etc/default/locale
                          LANGUAGE=de_DE.UTF-8
                          LC_ALL=de_DE.UTF-8
                          And / or do a reconfigure:
                          $ sudo dpkg-reconfigure locales
                          Make sure de_DE.UTF-8 UTF-8 is checked.
                          Tab to OK
                          Tab to OK
                          $ sudo reboot
                          • evroomE
                            evroom @sdetweil
                            Version 3.0.13 only takes 2 minutes.
                            Strangely enough version 3.1.13 takes ages and causes a timeout / connection reset.
                            Perhaps a local issue, although I have 57Mbps download.
                            Is there a reason for 3.1.13 and not @latest ?
                            Dependencies perhaps ?
                            Not that I want or need it, just asking.
                              sdetweil @evroom
                              @evroom no… i need to handle it, can’t expect users to do stuff to make the script work…
                                sdetweil @surger13
                                @surger13 willing to send me the log again?
                                  sdetweil @evroom
                                  @evroom Is there a reason for 3.1.13 and not @latest ?
                                  should be 3.0.13
                                  yes, V7 doesn’t run right,
                                  v6 needs some other changes,
                                  V3 is the last one on armv6 (pi 0)
                                  • evroomE
                                    evroom
                                    Okay, just that you know that my current 2.8.0 to 2.10.0 upgrade is trying to get 3.1.13.
                                    > node install.js
                                    Downloading tmp-21342-0-electron-v3.1.13-linux-armv7l.zip
                                    [==========================>                  ] 61.8% of 45.65 MB (720.69 B/s)
                                    This was in the log for the 2.9.0 to 2.10.0 upgrade:
                                    > node install.js
                                      throw err
                                    Do you catch and evaluate the output or only the exit value?
                                      sdetweil @evroom
                                      @evroom weird… the package.json says
                                      "electron": "^3.0.13"
                                      same as we have been running on for a couple years now
                                        sdetweil @evroom
                                        @evroom i don’t on the npm install… expect it to work… as we’ve been thru test on this for a long time.
                                          sdetweil @surger13
                                          @surger13 ok, looks like we have to fight the manual way
                                          do
                                          git stash
                                          git merge
                                          npm install
                                          C S 2 Replies Last reply Reply Quote 0
                                          • evroomE
                                            evroom @sdetweil
                                            Which exact package.json would that be?
                                            Perhaps mine tells to use 3.1.13?
                                            Although:
                                            pi@raspberrypi:~ $ grep electron ~/MagicMirror/package.json
                                              "main": "js/electron.js",
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
