    328 Posts 27 Posters 727.1k Views 24 Watching
    • evroomE Offline
      evroom
      @sdetweil said in new update/upgrade script, ready for testing:
      grep version ~/MagicMirror/package.json
      This MM install has
      pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
        "version": "2.8.0",
      Apparently I did not upgrade to 2.9.0. :-)
      In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
      Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
      Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
      MagicMirror version: 2.37.0
      • G Offline
        gonzonia @sdetweil
        @sdetweil Thanks! I thought I’d tried that as well. Guess not. All good now!
          sdetweil @evroom
          @evroom >In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script).
          old? I updated the dropbox file so, it should have been fixed…
          the install script is now part of the base.
          “version”: “2.8.0”,
          actually the upgrade log should have said, upgrading from 2.8 to 2.10,
          also shown on the screen
          the upgrade.log is located in the MagicMirror/installers folder
          • evroomE Offline
            evroom
            I mean before you said “give it another try please…”.
            Old is always relative :-)
            The upgrade log did say```
            upgrading from version 2.8.0 to 2.10.0
            The upgrade that I still running says```
            upgrading from version 2.9.0 to 2.10.0
            The test run on the 2.8.0 install currently outputs this:
            pi@MagicPi:~ $ date; bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
            Fri Jan  3 15:34:42 CET 2020
            the log will be /home/pi/MagicMirror/installers/upgrade.log
            No LSB modules are available.
            doing test run = true
            saving custom.css
            fetching latest revisions
            there are 1 local files that are different than the master repo
               css/custom.css
            do you want to save these files for later   (Y/n)?Y
            processing for module MMM-PublicTransportHafas please wait
            skipped processing for MMM-PublicTransportHafas, doing test run
            processing complete for module MMM-PublicTransportHafas
            processing for module MMM-soccer please wait
            skipped processing for MMM-soccer, doing test run
            processing complete for module MMM-soccer
            restoring custom.css
            test run, restoring files stashed
            error: Your local changes to the following files would be overwritten by merge:
            	css/custom.css
            Please commit your changes or stash them before you merge.
            Aborting
              sdetweil @evroom
              @evroom yeh, thats because of the test run against 2.8
              on apply this will be fixed…
                surger13 Project Sponsor
                i have tried the script now to upgrade MM to the new version. but nothing changes in the version.
                in upgrade.log are the following errors:
                test merge result rc='' , if empty, no conflicts
                executing merge, apply specified
                merge result rc= 1
                 error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	css/custom.css 	package-lock.json 	vendor/package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen. Abbruch Aktualisiere b508a62..b595cdd
                there were merge errors
                you should examine and resolve them
                  sdetweil @surger13
                  @surger13 did u save the changed files when prompted?
                  what version are u on? 2.8?
                  do
                    surger13 Project Sponsor @sdetweil
                    pi@MagicMirrorPi:~/MagicMirror $ grep version ~/MagicMirror/package.json
                      "version": "2.7.1",
                      sdetweil @surger13
                      can u show me the log , ~/MagicMirror/installers/upgrade.log
                      thx
                        there was no request to save the files?!
                        I will send you the logfile by mail.
                        • evroomE Offline
                          evroom
                          Sam, the 2.9.0 threw an error on the electron update, but then continued.
                          I am apparently on 2.10.0 now, but probably I am not running the latest electron version.
                          pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                            "version": "2.10.0",
                          This was the part where the error occured:
                          > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
                          > node install.js
                          Error: read ECONNRESET
                          /home/pi/MagicMirror/node_modules/electron/install.js:49
                            throw err
                              at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                          What would be the correct command to update electron and from which directory?
                            sdetweil @evroom
                            @evroom said in new update/upgrade script, ready for testing:
                            yeh, the website with the file broke the download…
                            u can try
                            npm install electron@3.0.13
                              sdetweil @surger13
                              @surger13 thanks for the log…
                              can u do
                              echo $LC_ALL
                              and
                              locale | grep LANGUAGE
                              thx
                                both empty.
                                pi@MagicMirrorPi:~/MagicMirror $ echo $LC_ALL
                                pi@MagicMirrorPi:~/MagicMirror $ locale | grep LANGUAGE
                                LANGUAGE=
                                  sdetweil @surger13
                                  @surger13 weird, but the system is in german… so the message I was looking for the output of
                                  git status, with the content of ‘modified’ in english
                                  how about the output of
                                  alias
                                    yes the language is german.
                                    pi@MagicMirrorPi:~/MagicMirror $ alias
                                    alias egrep='egrep --color=auto'
                                    alias fgrep='fgrep --color=auto'
                                    alias grep='grep --color=auto'
                                    alias ls='ls --color=auto'
                                      sdetweil @surger13
                                      @surger13 ok, how about output of
                                      locale
                                      thx…
                                        LANG=de_DE.UTF-8
                                        LANGUAGE=
                                        LC_CTYPE="de_DE.UTF-8"
                                        LC_NUMERIC="de_DE.UTF-8"
                                        LC_TIME="de_DE.UTF-8"
                                        LC_COLLATE="de_DE.UTF-8"
                                        LC_MONETARY="de_DE.UTF-8"
                                        LC_MESSAGES="de_DE.UTF-8"
                                        LC_PAPER="de_DE.UTF-8"
                                        LC_NAME="de_DE.UTF-8"
                                        LC_ADDRESS="de_DE.UTF-8"
                                        LC_TELEPHONE="de_DE.UTF-8"
                                        LC_MEASUREMENT="de_DE.UTF-8"
                                        LC_IDENTIFICATION="de_DE.UTF-8"
                                        LC_ALL=
                                          sdetweil @surger13
                                          @surger13 wild… a THIRD way to indicate language setting
                                          want to try the script again?
                                            I did. Unfortunately, no change.
                                            but thanks for your efforts.
                                            evroomE S 3 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
