    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @trividar
      @trividar yeh, he assumes MagicMirror is THE folder where things are installed…
      • G
        gonzonia
        Test runs fine…This is the result when I try to apply the log will be ```
        code_text
        No LSB modules are available.
        doing test run = false
        saving custom.css
        upgrading from version 2.9.0 to 2.10.0
        fetching latest revisions
        there were merge errors
        error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
        you should examine and resolve them
        using the command git log --oneline --decorate
        500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
        restoring custom.css
          sdetweil @gonzonia
          @gonzonia yes, the upgrade script from the master github site has a bug,
          please erase that one file
          ~/MagicMirror/installers/dumpactivemodules.js
          and then use the link to the script from this topic page1
          https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
          evroomE G 2 Replies Last reply Reply Quote 0
          • evroomE
            evroom @sdetweil
            Hi Sam, updating MM to 2.10.0 using your script. At the end the test run says:
            any *-lock.json files do not need to be saved
            do you want to save these files for later   (Y/n)?Y
            git: 'git_user_name' is not a git command. See 'git --help'.
            no modules found needing npm refresh
            test run, restoring files stashed
            The upgrade.log file does not give a clue as to what exact command was used.
            I am not into git, so cannot give you anything more than the git version
            pi@MagicPi:~ $ git --version
            git version 2.11.0
            Any ideas ?
            Best regards,
            E.J.
            MagicMirror version: 2.37.0
              sdetweil @evroom
              @evroom great find!..
              give it another try please…
              git wants all operations to be tagged with the users email address and name.
              but if you haven’t provided one, I use a temporary approach…
              • evroomE
                evroom
                Latest run:
                here are 1 local files that are different than the master repo
                   css/custom.css
                error: Your local changes to the following files would be overwritten by merge:
                	css/custom.css
                Please commit your changes or stash them before you merge.
                Aborting
                I can of course save and restore during the apply, but I do not know if this is what you want /expect.
                  sdetweil @evroom
                  @evroom said in new update/upgrade script, ready for testing:
                  css/custom.css
                  hmm… custom.css was taken out of distribution on the 2.9 release…
                  let me examine… hang on 30 mins
                    @sdetweil can u tell me what MM version you are running?
                    grep version ~/MagicMirror/package.json
                    thanks
                    • evroomE
                      evroom
                      @sdetweil said in new update/upgrade script, ready for testing:
                      This MM install has
                      pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
                        "version": "2.8.0",
                      Apparently I did not upgrade to 2.9.0. :-)
                      In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
                      Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
                      Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
                      • G
                        gonzonia @sdetweil
                        @sdetweil Thanks! I thought I’d tried that as well. Guess not. All good now!
                          sdetweil @evroom
                          @evroom >In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script).
                          old? I updated the dropbox file so, it should have been fixed…
                          the install script is now part of the base.
                          “version”: “2.8.0”,
                          actually the upgrade log should have said, upgrading from 2.8 to 2.10,
                          also shown on the screen
                          the upgrade.log is located in the MagicMirror/installers folder
                          • evroomE
                            evroom
                            I mean before you said “give it another try please…”.
                            Old is always relative :-)
                            The upgrade log did say```
                            upgrading from version 2.8.0 to 2.10.0
                            The upgrade that I still running says```
                            The test run on the 2.8.0 install currently outputs this:
                            pi@MagicPi:~ $ date; bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                            Fri Jan  3 15:34:42 CET 2020
                            the log will be /home/pi/MagicMirror/installers/upgrade.log
                            doing test run = true
                            saving custom.css
                            there are 1 local files that are different than the master repo
                               css/custom.css
                            processing for module MMM-PublicTransportHafas please wait
                            skipped processing for MMM-PublicTransportHafas, doing test run
                            processing complete for module MMM-PublicTransportHafas
                            processing for module MMM-soccer please wait
                            skipped processing for MMM-soccer, doing test run
                            processing complete for module MMM-soccer
                            	css/custom.css
                            Aborting
                              sdetweil @evroom
                              @evroom yeh, thats because of the test run against 2.8
                              on apply this will be fixed…
                                surger13 Project Sponsor
                                i have tried the script now to upgrade MM to the new version. but nothing changes in the version.
                                in upgrade.log are the following errors:
                                test merge result rc='' , if empty, no conflicts
                                executing merge, apply specified
                                merge result rc= 1
                                 error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge überschrieben werden: 	css/custom.css 	package-lock.json 	vendor/package-lock.json Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen. Abbruch Aktualisiere b508a62..b595cdd
                                  sdetweil @surger13
                                  @surger13 did u save the changed files when prompted?
                                  what version are u on? 2.8?
                                  do
                                    surger13 Project Sponsor @sdetweil
                                    pi@MagicMirrorPi:~/MagicMirror $ grep version ~/MagicMirror/package.json
                                      "version": "2.7.1",
                                      sdetweil @surger13
                                      can u show me the log , ~/MagicMirror/installers/upgrade.log
                                      thx
                                        there was no request to save the files?!
                                        I will send you the logfile by mail.
                                        • evroomE
                                          evroom
                                          Sam, the 2.9.0 threw an error on the electron update, but then continued.
                                          I am apparently on 2.10.0 now, but probably I am not running the latest electron version.
                                          pi@raspberrypi:~ $ grep version ~/MagicMirror/package.json
                                            "version": "2.10.0",
                                          This was the part where the error occured:
                                          > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
                                          > node install.js
                                          Error: read ECONNRESET
                                          /home/pi/MagicMirror/node_modules/electron/install.js:49
                                            throw err
                                              at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                                          What would be the correct command to update electron and from which directory?
                                            sdetweil @evroom
                                            yeh, the website with the file broke the download…
                                            u can try
                                            npm install electron@3.0.13
                                            • 10
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
