    328 Posts 27 Posters 740.6k Views 24 Watching
    • T
      trividar
      Can someone write a how to instruction for mac? Thanks a lot…
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @trividar
        @trividar said in new update/upgrade script, ready for testing:
        How to run the update/upgrade script? :-/
        • T
          trividar @Mykle1
          @Mykle1 sorry for the noob question! I tried it and I got just errors…
          • Mykle1M
            No worries. :thumbsup:
            When did you run it? I’ve just done it minutes ago and it works fine. @sdetweil has been working on it but I believe he has ironed out most, if not all of the kinks.
            1. So, when did you run it?
            2. Errors during the upgrade or after the upgrade?
            3. What were the errors?
            • T
              trividar @Mykle1
              @Mykle1 I will send it tomorrow and also what I have done! Thanks for your time
              • Mykle1M
                @trividar
                Well, I would think you have nothing to lose by running the upgrade script again. Simply open a new terminal and copy and paste the script into the terminal and press enter.
                • T
                  trividar
                  this is what I get:
                  > cd - >/dev/null
                  > date +"Upgrade ended - %a %b %e %H:%M:%S %Z %Y" >>$logfile
                  > else
                  > echo It appears MagicMirror has not been installed on this system
                  > echo please run the installer, "raspberry.sh" first
                  > fi
                  Can it be because my path has the same folder name twice? /Users/s****/MagicMirror/MagicMirror
                  Mykle1M S 2 Replies Last reply Reply Quote 0
                  • Mykle1M
                    @trividar
                    Hmm, perhaps. The installer may be looking for the MM installation inside /Users/s****/MagicMirror. Can you move the MagicMirror folder with the installation OUT of the containing MagicMirror folder. Rename the containing MagicMirror folder to something else and put the MagicMirror folder containing the MM installation here /Users/s****/MagicMirror and try again?
                      sdetweil @trividar
                      @trividar yeh, he assumes MagicMirror is THE folder where things are installed…
                      • G
                        gonzonia
                        Test runs fine…This is the result when I try to apply the log will be ```
                        code_text
                        No LSB modules are available.
                        doing test run = false
                        saving custom.css
                        upgrading from version 2.9.0 to 2.10.0
                        fetching latest revisions
                        there were merge errors
                        error: The following untracked working tree files would be overwritten by merge: 	installers/dumpactivemodules.js Please move or remove them before you merge. Aborting Updating 500147e..b595cdd
                        you should examine and resolve them
                        using the command git log --oneline --decorate
                        500147e (grafted, HEAD -> master, tag: v2.9.0) Merge pull request #1776 from MichMich/develop
                        restoring custom.css
                          sdetweil @gonzonia
                          @gonzonia yes, the upgrade script from the master github site has a bug,
                          please erase that one file
                          ~/MagicMirror/installers/dumpactivemodules.js
                          and then use the link to the script from this topic page1
                          https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing?page=1
                          evroomE G 2 Replies Last reply Reply Quote 0
                          • evroomE
                            evroom @sdetweil
                            Hi Sam, updating MM to 2.10.0 using your script. At the end the test run says:
                            any *-lock.json files do not need to be saved
                            do you want to save these files for later   (Y/n)?Y
                            git: 'git_user_name' is not a git command. See 'git --help'.
                            no modules found needing npm refresh
                            test run, restoring files stashed
                            The upgrade.log file does not give a clue as to what exact command was used.
                            I am not into git, so cannot give you anything more than the git version
                            pi@MagicPi:~ $ git --version
                            git version 2.11.0
                            Any ideas ?
                            Best regards,
                            E.J.
                            MagicMirror version: 2.37.0
                              sdetweil @evroom
                              @evroom great find!..
                              give it another try please…
                              git wants all operations to be tagged with the users email address and name.
                              but if you haven’t provided one, I use a temporary approach…
                              • evroomE
                                evroom
                                Latest run:
                                here are 1 local files that are different than the master repo
                                   css/custom.css
                                error: Your local changes to the following files would be overwritten by merge:
                                	css/custom.css
                                Please commit your changes or stash them before you merge.
                                Aborting
                                I can of course save and restore during the apply, but I do not know if this is what you want /expect.
                                  sdetweil @evroom
                                  @evroom said in new update/upgrade script, ready for testing:
                                  css/custom.css
                                  hmm… custom.css was taken out of distribution on the 2.9 release…
                                  let me examine… hang on 30 mins
                                    @sdetweil can u tell me what MM version you are running?
                                    grep version ~/MagicMirror/package.json
                                    thanks
                                    • evroomE
                                      evroom
                                      @sdetweil said in new update/upgrade script, ready for testing:
                                      This MM install has
                                      pi@MagicPi:~ $ grep version ~/MagicMirror/package.json
                                        "version": "2.8.0",
                                      Apparently I did not upgrade to 2.9.0. :-)
                                      In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script). I got the same git: 'git_user_name' is not a git command.error there, but decided to do the apply anyway.
                                      Currently Downloading tmp-27972-0-electron-v3.1.13-linux-armv7l.zip which takes forever for some reason (approx. 700 B/s).
                                      Btw, I know it can be solved by other means, but I would like you to be able to tweak your script.
                                      • G
                                        gonzonia @sdetweil
                                        @sdetweil Thanks! I thought I’d tried that as well. Guess not. All good now!
                                          sdetweil @evroom
                                          @evroom >In parallel I am upgrading an 2.9.0 install (using the ‘old’ apply script).
                                          old? I updated the dropbox file so, it should have been fixed…
                                          the install script is now part of the base.
                                          “version”: “2.8.0”,
                                          actually the upgrade log should have said, upgrading from 2.8 to 2.10,
                                          also shown on the screen
                                          the upgrade.log is located in the MagicMirror/installers folder
                                          • evroomE
                                            evroom
                                            I mean before you said “give it another try please…”.
                                            Old is always relative :-)
                                            The upgrade log did say```
                                            upgrading from version 2.8.0 to 2.10.0
                                            The upgrade that I still running says```
                                            The test run on the 2.8.0 install currently outputs this:
                                            pi@MagicPi:~ $ date; bash -c  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
                                            Fri Jan  3 15:34:42 CET 2020
                                            the log will be /home/pi/MagicMirror/installers/upgrade.log
                                            doing test run = true
                                            saving custom.css
                                            there are 1 local files that are different than the master repo
                                               css/custom.css
                                            processing for module MMM-PublicTransportHafas please wait
                                            skipped processing for MMM-PublicTransportHafas, doing test run
                                            processing complete for module MMM-PublicTransportHafas
                                            processing for module MMM-soccer please wait
                                            skipped processing for MMM-soccer, doing test run
                                            processing complete for module MMM-soccer
                                            	css/custom.css
                                            Aborting
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
